4K Short'n'Sweet game contest
Asmusr
I'm starting a new thread in order not to pollute the SSGC racer thread any further. There has been 3-4 expressions of interest in this idea already, so probably enough to proceed.
The idea for the contest is that by limiting the size of the task hopefully more people will join. Writing a game for a 512K cartridge may seem overwhelming, but with only 4K available there's a natural limit on the time you can spend. We could also choose 2K or 8K, but I think 4K is a good compromise between having room for a bit of graphics and the time it takes to produce.
My first idea was that the 4K would be ROM, but since 4K RAM is what the Mini Memory provides we could also make this a contest for a game to run on an unexpanded console with a Mini Memory? Unexpanded means no 32K, speech, disk, RS-232, or F18A required. I think this is important to limit the task and make the entries comparable. I think it would be OK to require joysticks.
See rules here: http://atariage.com/forums/topic/273371-4k-shortnsweet-game-contest/page-2?do=findComment&comment=3919501
And one more addition here: http://atariage.com/forums/topic/273371-4k-shortnsweet-game-contest/page-3?do=findComment&comment=3920373
  • Like 9
One of the draws (for me) of the first contest was the size limitation as it kept everyone in the same ballpark and made for some very creative efforts given the size and programming language used. Assuming there is enough interest in machine code (versus using XB, for example) 4k doesn't sound overwhelming and it is a nice amount of code and data for a simple contest. (Edit: I'm not sure that everyone would be able to load and run the programs without 32K or disk system, unless this were emulation only? Or would having a certain cartridge i.e. FR99/FG99 become a requirement?)
Edited by InsaneMultitasker
To rephrase the requirements, the games should work without 32K and disk, but the games would also be expected to work with them. With the source code available it should be easy to turn any 4K cartridge image into a E/A#5 file running from 32K for those who don't have a FR99/FG99 or similar.
I don't think it will be relevant, but there are a few things that might work on the 9918A but not on the F18A, e.g. if the game runs in 'bitmap text mode' or uses undocumented features of the 5th sprite flag. Those entries would be allowed, of course, since there is no requirement that a game runs on the F18A.
For the contest all entries should be evaluated on an unexpanded console.
Does anyone have an opinion regarding the question of RAM vs ROM?
RAM. Keep it old school. That way people can load from disk using EA or MM or load from tape using MM. They don't want to be blowing EPROMS or having to use the super grom thingy cartridge.
I might have a go at this myself. Nice idea!
Sounds like a great idea!
Having MM/4k limit is perfect. There really was only a handful of games written for that platform that didn't require 32k as well (Entrapment, Defend the Cities II). Given the quality of games for other platforms with similar memory (eg: unexpanded Vic 20) always has felt like an unexplored environment.
And like you say, given its limits, more achievable.
I could even rip out some of my code from my stalled "Thrust" project to get something working.
cheers
Daryn
If it runs from the MiniMemory RAM but doesn't use it as extra RAM, then making a ROM cartridge out of it is basicaly adding a header and some padding, so any entry that wants to make that possible simply needs to keep that in mind. But I'm not proposing that as a rule. ;)
I think I can throw something together. What's the deadline?
Hi folks,
The proposal of a competition in programming of 4k playground games would be great. Thereby all guys participating in such a competition would generate a bunch of programs, which can serve as sample programs for dummies like me :P ;).
Regards
Edited by MueThor
Well, it certainly sounds interesting. But I would like to propose that the programs be developed strictly using the MiniMemory module and the line by line assembler, whether in emulation or on real hardware, nothing else, to make it truly authentic. We are all spoiled by all the programming aids available to us, from modern text editors to sophisticated compilers, and the art (or perhaps suffering?) of producing a good program within the limitations of the era is gradually being lost to the mists of time.
Yes, it will be a stiff challenge, but one you will be able to wear as a true badge of honor!
Let the tomatoes fly :grin:
Remember that the LBLA takes up a significant portion of the 4K RAM. I think you have under 1K of memory to use for your program.
Would we need to pass a lie detector test?
Having RAM instead of ROM opens a lot of possibilities, e.g. for generating and storing maps. I would certainly take advantage of that.
Regarding the deadline I'm thinking we should have around 3 months to finish. Does that seem reasonable?
Ha ha! As it happens, I've literally just come back from the opticians where we determined that I need new glasses. They were clearly right, because I thought I just read Vorticon saying to use the line-by-line assembler.
Clearly my eye sight is a LOT worse than I thought! ;-)
Remember I'm the guy who just programmed an entire AI for the Game of UR on a tiny handheld computer with a 24 character LCD...
I never claimed to be normal, merely different. :) And in a community where most of its members devote large amounts of free time on a decades old beyond obsolete platform, I think I can safely say that I am not alone!
In other words, I still think limiting ourselves to the LBLA would be a fun thing to do :-D
Afraid I'm not going to use the LBLA. I started there and have no nostalgia for going back. :) But I also don't have three months to dedicate. I know more or less what I'm going to do (and started prepping already), if it doesn't qualify in the end at least it'll still be new software! :)
From you, that will be enough!! :)
I will let comments come in for a few more days, and then I plan to make a poll to finalize the rules by majority vote.
Does anyone have an opinion on how to choose the winner? I'm thinking either anyone on AtariAge can vote, or we appoint a panel that chooses the winner.
