About the Atari 1050 Disk Drive Power Supply,Mine is dead.
Spanner
Any of those shown in your eBay link will do and there
is no penalty for going for the cheaper ones, you will
be buying the cheaper ones at a higher price for the most
part with one or two exceptions. Don't buy the exceptions,
they are simply not required.
These are not tube type, they are just cylindrical versions
of the square type that you happen to have. No magic is
to be inferred by the shape of the container in other
words, when you buy Thermal Cutoff Fuse it matters not
what shape it comes in unless that IS the only requirement.
Just to save time, it also doesn't matter which ends
get soldered to where, the pointy end means nothing here.
It got hot and blew as designed, how can we know why at
this time? They generally just simply work as produced
so some certainty does exist that it did get that hot.
If it does it again, just buy an entirely new one and
dismember this one to include hammer and chisel damage
to windings so someone else doesn't risk their life and
limb building a supply from the transformer which would
have to be very wrong on the inside to heat like this.
Amperage rating does not matter as long as your minimum
has been met. These do not blow by amperage generally
speaking, they open by temperature as designed. They can
be forced to, but that is not their advertised purpose.
OK thanks,can I for now use it without a fuse or wait until I get one..?
I think I mentioned thermal protection and fire, please use a the thermal protection to prevent overheated winding from burning off their lacquer and releasing possible fumes, smoke, and possible arcing flames fire etc....
while a current fuse is provided... and should protect just fine, the the thermal fuse location does matter and it is there for a reason... as heat rises..... just select a close thermal locate it near the original position 113- 115 degree is fine... don't just jump it out... it's there for a reason... I replace tons of fuses, thermal and current ... it will more than likely be perfectly fine......
When repairing fans and motors, the starting cap, and thermal are often replaced together.... they often work just fine also.. it is rare to actually have burned up transformer windings.... and if you place a transformer in a bucket of vibrating vacuumed lacquer it usually heals the rubbed or burned spot on a transformer anyway... unless the winding has fused or welded and continues to touch where it should not...... then it's all over the transformer will heat up and blow the fuse again and again... time to unwind and rewind again or recycle the copper...
so please retain both fuses, if it blows you can try the lacquer repair, if it blows again... unwind lacquer rewind... or just recycle it and buy a new one... do not bypass the safety fuses... always replace them... please do not bypass the fuses, replace them! be safe!
Edited by _The Doctor__
OK got the fuses today and the power supply is working fine now,thanks.
Tested it with my drive on for half an hour and the psu is not even getting hot so thats good,,, :)
Oh thanks for all the help this community is brill ...:D
Edited by Spanner
  • Like 4
