TI-74 and cassette capabilities
60 replies to this topic
#51 acadiel OFFLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Sat Nov 24, 2018 3:07 PM
There is a Hexbus IC on the board. I was assuming pass through, but maybe it's for something else. I'll have to pull it apart again.
Sent from my moto x4 using Tapatalk
#52 Opry99er OFFLINE
Opry99er
  • 10,744 posts
Posted Sun Nov 25, 2018 8:55 AM
Will this work with the CC40 as well?
#53 arcadeshopper OFFLINE
arcadeshopper
  • 4,411 posts
Posted Sun Nov 25, 2018 11:37 AM
If it's hexbus it's the same just a different pinout
Sent from my LG-H872 using Tapatalk
#54 Jeff_Birt OFFLINE
Jeff_Birt
    Space Invader
  • 13 posts
Posted Sun Nov 25, 2018 4:02 PM
The big IC is a 'line driver' which just means it has higher current outputs for driving a heavier load. I suspect they used it as a buffer and/or inverter for the 3 I/O lines used.
Yes, the TI-95 and TI-74 added two pins to make a 10 pin connector. The extra two pins being a 6VDC input to the calculator (which my interface supplies so when you are using the cassette interface you are not running on batteries) and a 6V output. The cable between the adapter and the CC40 would be different. I recently picked up a CC40 and have not used it yet. I'll look at making a cable for it as well. In the design files linked in the video there is a PDF of the schematic (in case you don't use Eagle)  which shows the pin outs of the TI-95 connector and adapter connector.
​If there is interest I'll see about getting a small number of PCBs made by OSHpark or someplace so if you want top make on you would just have to buy the components. If there is a really enough interest I might think about putting together 10-20 kits of the PCBs, components and 3d printed case so you can solder it together.
#55 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 435 posts
Posted Sun Nov 25, 2018 5:50 PM
Doh! Forgot the link
Hi,
While flipping though your video... I was intrigued by your mentioning the TI-74 cassette interface's ability to sense voltage or current initiated by pressing a button on the player/recorder, causing the remote line to become active. I did not catch what the response is by the TI-74.
I'm curious because I have a particular TI-99/4a which exhibits an interesting response to a particular unused input port on the 9901 being held LOW(Port 10, Pin 29,SBO\SBZ 26), normally held high by a pull-up resistor. While held LOW the system hangs indefinitely and waits for P10 to go high... at any of the times that a prompt for cassette operation would normally appear. It has been speculated that this was in provision for a more automatic type of data drive never implemented by TI. I'm now wondering if this instead was something concieved to work with regular cassette recorders.
#56 Jeff_Birt OFFLINE
Jeff_Birt
    Space Invader
  • 13 posts
Posted Sun Nov 25, 2018 6:33 PM
The 'sense' line is an output of the Commodore C2N datasette. It was made use of by the Commodore 64/VIC-20 originally. The TI-95 does not have any provision for this as far as I am aware. Since the CI-7 tape interface was designed for use with a normal cassette deck which would not have had a key sense output.
It is curious though that TI-99/4a has an input pin that acts as though it was made for that purpose given that they had a similar three wire analog tape lead, though they did use a DB9 connector on the computer side of it so there would have been extra pins for that purpose. Maybe they had thought at one point about their own tape deck? Sadly, I don't know much bout the 99/4a.
#57 acadiel OFFLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Fri Nov 30, 2018 2:32 PM
Nope, the CC-40's processor ROM (2K) doesn't have the cassette routines built in.  Someone would have to figure out how to add them by dumping the CC-40+ 4K processor ROM or extracting them from the TI-74's 4K processor ROM.
To be clear, it probably can do it.  But not without creating some assembly routines.
#58 gferluga OFFLINE
gferluga
    Space Invader
  • 17 posts
Posted Sun Dec 16, 2018 1:58 PM
I found something very strange... and it works!!!
A CI-7 interface but with a Centronics male plug.
I connect it to a standard parallel printer and it's printing...
Looks like something custom made by TI.
It doesn't looks home made.
Attached File  IMG_20181215_1508514.jpg   1.73MB   6 downloads
Attached File  IMG_20181215_1509133.jpg   1.49MB   4 downloads
#59 acadiel OFFLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Sun Dec 16, 2018 6:23 PM
Ooh.... internal pics please!!!!
#60 gferluga OFFLINE
gferluga
    Space Invader
  • 17 posts
Posted Mon Dec 17, 2018 12:47 PM
Ok. I can do it... any advise to take care how I open it?
Any risk to lose pieces or break something?
#61 acadiel OFFLINE
acadiel
  • 1,514 posts
  • www.hexbus.com
Posted Tue Dec 18, 2018 6:37 PM
If it’s like the CI-7, there are screws under the rubber feet. Just be careful and take plenty of pics. :)
