Loading insta-disk
5 replies to this topic
#1 anthony512 OFFLINE
anthony512
    Combat Commando
  • 6 posts
Posted Tue Jan 16, 2018 2:41 PM
First day here and loving it. bought a //e cheap. the owner did not want it. i attempted to load  disk it failed so i tried cassette load and it attempts to load 3.3 dos up to 19 sec then errors out. I am using asciiexpress files. it error out to the astric sign and I believe it dumped me into assembler. I am wondering if there may be a chip on the MB that got fried. I have tried to load with and without FD i/o board and same thing happens. tried to figure it out thru schematics but to no avail. I have tried to load other things like apple presents and it does the same thing. anthony
#2 anthony512 OFFLINE
anthony512
    Combat Commando
  • 6 posts
Posted Tue Jan 16, 2018 2:58 PM
update, ok found audio was not loud enough with phone, with laptop, it loads up to the insta-disk formatting screen then gives me a disk error after drive vibrates and says disk error, bad floppy ???
#3 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,796 posts
Posted Tue Jan 16, 2018 5:27 PM
So, where are we at and what isn't working?
Not sure what an asciiexpress file is..?
Edited by Keatah, Tue Jan 16, 2018 5:28 PM.
#4 anthony512 OFFLINE
anthony512
    Combat Commando
  • 6 posts
Posted Tue Jan 16, 2018 6:07 PM
Hello,thanks for the reply.
so at this point I am getting a disk error form the floppy drive just before the format routine. so I am not sure if its a floppy issue or a drive issue. floppies will be here thursday.
Asciiexpress.net   they have audio files in wav format to load thru the cassette port of the //e
the floppy drive is a 19 pin unit with an I/O board 655-0101-B
#5 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,796 posts
Posted Wed Jan 17, 2018 12:58 AM
Exactly what disk error?
And keep in mind you may need to clean the drive's head AND the disk's surface depending on the age of the disk itself.
Edited by Keatah, Wed Jan 17, 2018 1:13 AM.
#6 david__schmidt OFFLINE
david__schmidt
    Chopper Commander
  • 163 posts
Posted Tue Jan 23, 2018 3:31 PM
AND the disk needs to be double density, not high density.
Reply to this topic
