Retropie question
11 replies to this topic
#1 ClassicGMR OFFLINE
ClassicGMR
  • 1,174 posts
Posted Mon Feb 12, 2018 8:26 PM
OK I have tried to transfer files 2 ways:
1) USB method - the USB formatted to FAT32, Retropie creates the directories, I put the files in the proper rom directory and insert back to the Retropie for automatic transfer.
2) use Explorer to go to \\retropie and drag & drop over network
In both cases I get errors. The windows error that comes up states I don't have enough room. There's 26GB free on the RetroPie card, the file sizes are anywhere from 4MB to 32MB and yet when moving 886 files totaling 6.62GB there's an error. I successfully got 435 of them to transfer then:
6.22GB is needed to copy this item. Delete or move files so you have enough space.
As of this posting I am going to try and move 150 files at a time and see if that helps but I'm assuming it's something I am missing.
Also - the 522 Atari 2600 games transferred with no issues all at once.
Edited by ClassicGMR, Mon Feb 12, 2018 8:27 PM.
#2 mr_me OFFLINE
mr_me
  • 3,258 posts
Posted Mon Feb 12, 2018 11:47 PM
How are you determining how much free space is seen by Raspbian?
#3 ClassicGMR OFFLINE
ClassicGMR
  • 1,174 posts
Posted Tue Feb 13, 2018 4:14 AM
Explorer into \\Retropie
Go into the ROM directory
Select All
Properties
See how much is used
I also noticed about a 2GB disparity between SIZE and SIZE ON DISK.
EDIT: Moving 125 files at a time worked fine until I got about halfway through the list then the space error started again.
I found that if you F4 out of Emulationstation it gives you disk statistics.
Filesystem /dev/root
Size 31G
Used 1.9G
Avail 28G
Use% 7%
Mounted on /
Edited by ClassicGMR, Tue Feb 13, 2018 5:02 AM.
#4 Mr Robot OFFLINE
Mr Robot
    Chopper Commander
  • 245 posts
  • AtariArtist
Posted Tue Feb 13, 2018 8:00 AM
You should always leave at least 20% of your card space free for wear leveling, error correction, saved games files etc. etc. The system uses a chunk of space while running for swap and tmp files and other things of a mystic nature.
"Size" v's "Size on disk"... Welcome to the world of block sizes! if the block size is 4KB and you have a 1KB file, it will take up a minimum of 4KB on the disk, if a file is 4.01KB it takes up 8KB.  You'd be amazed how quick this adds up.
#5 zzip OFFLINE
zzip
  • 2,534 posts
Posted Tue Feb 13, 2018 10:09 AM
I think I know what the problem might be, even though the card has all that free space, the image you put on it has a much smaller filesystem and isn't using that space. You have to resize it. See the following thread, there's a menu option that will do this for you:
https://retropie.org...he-filesystem/3
#6 Mr Robot OFFLINE
Mr Robot
    Chopper Commander
  • 245 posts
  • AtariArtist
Posted Tue Feb 13, 2018 10:16 AM
If the image were still a shrunk image the
Size 31G
Used 1.9G
Avail 28G
Use% 7%
Mounted on /
would report the smaller size.
Is this a cheap SD card from a iffy seller on eBay or Amazon? there are a lot of cards that say 32gb or whatever on them but in reality are rejects or much smaller cards hacked to report a larger size and reprinted. The wear leveling takes care of the missing space until the real card size is filled.
#7 ClassicGMR OFFLINE
ClassicGMR
  • 1,174 posts
Posted Tue Feb 13, 2018 12:00 PM
I found the source of my problem. I decided to go the USB permanent drive route. Works flawlessly.
My conclusions based on all your help is I have a crap card. 😕
#8 toptenmaterial OFFLINE
toptenmaterial
  • 4,757 posts
Posted Wed Feb 14, 2018 7:14 PM
Here is a guide with ratings in respect to Retropie of many many cards
https://elinux.org/RPi_SD_cards
#9 Flojomojo OFFLINE
Flojomojo
    in the rain or in the snow
  • 13,960 posts
  • got the funky funky flow
Posted Wed Feb 14, 2018 8:49 PM
Crap, or not formatted to use the whole thing. Glad you've fixed things!
#10 iesposta OFFLINE
iesposta
  • 3,789 posts
  • Retro-gaming w/my VCS
Posted Wed Feb 14, 2018 9:04 PM
I doubt you were accessing the large Linux partition.
Probably you were copying to the small fat32 boot partition.
I always used an FTP/SFTP to connect and see the ext4 partition.
Now I just find premade images for 64GB or 128GB cards, and all the art, info, systems just work.
I can delete was I don't play, then SFTP over missing games / systems / new homebrews, etc.
It is way too easy to update something or mistype something and lose everything.
I had N64 Star Wars Pod Racer working great and Dragon's Lair and even Astrocade, and months of creating uploading original artwork. Now I can't remember how I got everything working.
#11 iesposta OFFLINE
iesposta
  • 3,789 posts
P.S. I never tried using the USB stick method. :D
#12 fujidude OFFLINE
fujidude
  • 4,972 posts
Posted Thu Feb 15, 2018 3:06 PM
Especially with the small files typical of retro systems.
