SDrive-MAX ATX support
676 replies to this topic
#51 DrVenkman OFFLINE
DrVenkman
  • 4,081 posts
  • Back off, man! I'm a scientist.
Posted Sun Jul 15, 2018 6:54 PM
Someone please tell me which side the black band of the diode needs to be pointing - Arduino side or Atari side? Reason I asked is, I tried it both ways, the device failed to work. As soon as I removed it completely, things work great, as you can see. Is it possible I've got a bad batch of 1N4148 diodes?
Cathode (black band) end soldered to the Arduino.
Yeah, that's what I thought! Nada when I had it wired that way.
Harrumph. I'll rewire it tomorrow and try again. Thanks for the confirmation though!
Just to put a bow on this side issue, in case someone has a similar problem in the future and runs into a similar issue, at Michael St. Pierre's suggestion, I substituted a small 1N5819 Schottky diode for the suggested 1N4818 and voila, problem solved! My SDrive-MAX works now with my 1088XEL and allows use of other SIO drives at the same time. Whew!
#52 Awch OFFLINE
Awch
    Space Invader
  • 30 posts
Posted Sun Jul 15, 2018 7:15 PM
I'm just collecting the parts to assemble and I'm not particularly experienced with electronics. Do you know if this solution is specific to the 1088XEL, or a generalized approach for all Atari hardware?
Thanks for your help!!
Greg
#53 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,937 posts
Posted Sun Jul 15, 2018 7:20 PM
Greg it is a generalized solution and solves the issue for the whole line both real and clone...
#54 AtariGeezer ONLINE
AtariGeezer
  • 2,903 posts
Posted Sun Jul 15, 2018 7:34 PM
I have 1 working now with my Incognito 800 :)  Will have to check it out on my XEL too...
#55 DrVenkman OFFLINE
DrVenkman
  • 4,081 posts
Posted Sun Jul 15, 2018 7:38 PM
Greg
It’s been 3 decades since my two semesters of “Electrical Engineering for non-EE Majors” classes, what we called “Sparks and Magic 101” :P So my theoretical knowledge is both old and mostly forgotten.
However, having said that, others have built these with 1N4148 diodes without any problems. With that type diode mine worked with my 1200XL but didn’t work with my 1088XEL. However, another user said it worked with his. Each of the XEL’s is hand-built, usually by its owner, so the build quality is a variable too. So who knows if mine is just a little off-spec in the serial I/O chain?
But once I put in the 1N5819 Schottky diode instead, it booted right up. I haven’t yet tried it with my 1200XL or the 800 I have out and handy. I’ll do that at some point. After struggling with this nagging issue all weekend on and off, I was happy to declare victory and retire from the field! :)
#56 GrandviewCoin OFFLINE
GrandviewCoin
    Moonsweeper
  • 399 posts
Posted Sun Jul 15, 2018 7:41 PM
Just for the sake of having both options I just ordered some 1N5819's. For the price might as well.
#57 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Sun Jul 15, 2018 8:02 PM
Excellent, glad to hear you got it working.  Still interesting to know if it's a just enough out of spec edge case considering it works on machines other than the XEL.
I'm gearing up to make some SDrive-MAXs for friends.  Experimenting with some print settings and some filament that is annoying me for some reason, will probably make the 'somewhat less than perfect' cases available for free to fellow AAers when I'm done :)
#58 AtariGeezer ONLINE
AtariGeezer
  • 2,903 posts
Posted Sun Jul 15, 2018 9:57 PM
Just tested on my XEL and it's working with it too...
#59 NuClear235 OFFLINE
NuClear235
    Space Invader
  • 14 posts
Posted Mon Jul 16, 2018 2:48 AM
How do You print it ? Normal or uipside down. I am printing it that face lays on bed. Result is not perfecto on grid holes...
#60 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 390 posts
  • Mr Ziggy loves to extend the 1050 heatsink!
Posted Mon Jul 16, 2018 4:11 AM
im printing mine face down as i type - when i tried it the right way up, it left lots of debris where the screen butts up.
#61 Level42 OFFLINE
Level42
  • 2,602 posts
I'm not so picky about the case so would gladly pay for material costs and shipping of one of the "less perfect" ones :D
Edited by Level42, Mon Jul 16, 2018 4:22 AM.
#62 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Jul 16, 2018 4:16 AM
Did you ever test the 1N5819 with a DVM ? sounds it was open (blocking two ways).
In theory a shottky diode should be better because it only drops 0,3V or so compared to the generic 1N4818...
[EDIT] checked the datasheets. The 1N4818 can also "only" deliver 300mA where the 1N5819 can handle 1000mA... I guess the Uno plus display won't consume more than 300mA but even so...in theory the 1N5819 seems like a better choice....
O well I guess whatever works is best, LOL
Edited by Level42, Mon Jul 16, 2018 4:21 AM.
#63 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Jul 16, 2018 4:28 AM
Wait a minute, just read the 1088XEL thread......I think you exchanged the type numbers of the diodes in your post here :D
So DO use a 1N5819 (or similar schottky diode) and NOT a generic one with a higher voltage drop (like the 1N4818).
#64 DrVenkman OFFLINE
DrVenkman
  • 4,081 posts
Posted Mon Jul 16, 2018 5:41 AM
Yeah I made a typo. I let my AA subscription lapse and can’t edit the post, lol. Anyway, the 1N5819 is working with the XEL and the 1N4148 wasn’t. So once I do some compatibility tests with an 800 and a 1200XL, I’m going to build another one for a friend.
#65 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Jul 16, 2018 5:46 AM
LOL, I'm glad when theory matches "real world" ;)
#66 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 390 posts
Posted Mon Jul 16, 2018 6:31 AM
mine turned out reasonably well - printed face down.
just have some post processing to do and it will look decent!
#67 _The Doctor__ OFFLINE
_The Doctor__
  • 6,937 posts
Posted Mon Jul 16, 2018 10:31 AM
If the initial print layer diagonals fell from left to right it would sort of  match XE's better as well
Edited by _The Doctor__, Mon Jul 16, 2018 10:32 AM.
#68 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Jul 16, 2018 3:38 PM
I was just looking at my recently acquired 1025 and remembering all these neat XL style boxes I thought: wouldn't it be cool to replace the top plastic part of the 1025 with a completely redesigned one that is REALLY in XL style..... LOL.....
Oops, no intention to side-track this thread :D
#69 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Mon Jul 16, 2018 4:06 PM
The case top is something you really need to print face down for FDM printing, otherwise you'll cause a massive amount of support structure material printing and/or make an ugly top surface over supports.
#70 rdea6 OFFLINE
rdea6
  • 2,836 posts
Posted Mon Jul 16, 2018 4:16 PM
I wonder if I could get MacRorie to start building these things also.. OR Dropcheck...
#71 DrVenkman OFFLINE
DrVenkman
  • 4,081 posts
Posted Mon Jul 16, 2018 6:45 PM
I am currently working on a compatibility list for the latest beta version (0.8b) which I manually build from Github. As for 0.7, a few that are known to work (although there are many others) are:
Agent USA
Bandits
Bruce Lee
Canyon Climber
Goonies (used to test weak bits)
Nibbler
I just decided to try this and what do you know? It worked! I booted up the ATX from the A8 Software Preservation Project torrent and it worked like a charm, thanks! So great to be able to boot some titles like this in un-cracked/un-hacked versions. :)
#72 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Mon Jul 16, 2018 7:11 PM
It's just a beautiful thing isn't it?  The SDrive-MAX is amazing in its own regard, but even the partial support of .atx is a fantastic cherry on top.  And that's on top of an SDrive that can actually support 4 drives and change images on the fly.  Hello Alternate Reality the Dungeon!
Yet I can't help getting the feeling that many of our A8 compatriots still don't know about the SDrive-MAX or how incredible it is.
How do we change that?  We need to change that...
#73 Kyle22 OFFLINE
Kyle22
  • 4,097 posts
  • broadway1.lorexddns.net 10001
Posted Mon Jul 16, 2018 7:16 PM
Will this work: https://www.ebay.com..._from=R40&rt=nc
#74 a8isa1 OFFLINE
a8isa1
  • 1,564 posts
Posted Mon Jul 16, 2018 7:21 PM
Would this board and this screen work for an SDrive-MAX build?
I like the board because the headers aren't installed yet and there is a USB Micro B connector instead of USB B.
On the downside a cable isn't included.
-SteveS
[EDIT]
Oops.  I was a bit slow.  Pretty much the same materials that Kyle22 asked about.
Edited by a8isa1, Mon Jul 16, 2018 8:00 PM.
#75 DrVenkman OFFLINE
DrVenkman
  • 4,081 posts
Posted Mon Jul 16, 2018 7:28 PM
I know, right?!?! I admit that I paid this far too little attention myself until recently. When Farb first mentioned it in the Atari 8-bit Software Preservation Project thread, I admit I confused it with the confusingly-similar named SDrive dongle SD card/SIO plug dongle device. I was totally unaware of this actual project until the link to the project was later posted. To quote my paraphrase my forum-handle inspiration, this gadget SHOULD be bigger an the microchip. But no ones heard of it.
Since then Ive done what I can. I built one last week and posted about on the Facebook Atari 8-bit Computers page where it got quite a bit of attention. Ive shared it in my own small circle of retrocomputing friends, at least two of whom want to build them now themselves. I plan to build two more in the coming weeks (one as a spare and one for a friend). Its fantastic. AND it handles .XEX and .CAS files all in one device that anyone can build themselves if they have a cable. Amazing.
Kyle, I know the Arduino will work. Ive got two of them and they work great for this project. I dont know about the screen, It looks very similar to the specific recommended Elegoo unit so its *probably* identical just without the name. If it does all work, thats a great price - about what I paid for the Elegoo screen alone on Amazon about a week ago.
Edited by DrVenkman, Mon Jul 16, 2018 7:37 PM.
