zilog_z80a Posted March 9, 2018 Author Share Posted March 9, 2018 i`m at home now, it does not work. is distorted this is strage... i did WSYNC OUT OF THE LOOP AND NOW WORKS FINE. ? i will kill my self... brb.... lol but dunno when used the other playfield some lines where altered, must wait to arrive at home to try. sta WSYNC kernel_loop ldX PLAYF0,y ;+4 4 ----AND START TO COUNT HERE. stX PF0 ;+3 7 -- WE WRITE PF0 BEFORE TIA CYCLE 68 - PF0 lda (player0),y ;+5 12 and (mask0),y ;+5 17 sta GRP0 ;+3 20 ldx PLAYF1,y ;+4 24 stx PF1 ;+3 27 -- WE WRITE PF1 BEFORE TIA CYCLE 84 - PF1 ldx PLAYF2,y ;+4 31 stx PF2 ;+3 34 -- WE WRITE PF2 BEFORE TIA CYCLE 116 - PF2 lda (player0),Y ;+5 39 ldx PLAYF3,y ;+4 43 stx PF0 ;+3 46 -- WE WRITE "RIGHT PF0" BEFORE TIA CYCLE 148 - PF0 ldx PLAYF4,y ;+4 50 stx PF1 ;+3 53 -- WE WRITE "RIGHT PF1" BEFORE TIA CYCLE 164 - PF1 ldx PLAYF5,y ;+4 57 stx PF2 ;+3 60 -- WE WRITE "RIGHT PF2" BEFORE TIA CYCLE 196 - PF2 and (mask0),y ;+5 65 sta GRP1 ;+3 68 dey ;+2 70 bne kernel_loop ;+2 72 ---OR 73 IF BRANCH WAS TAKEN. Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted March 9, 2018 Author Share Posted March 9, 2018 (edited) i`m at home now, it does not work. is distorted I KNOW WHAT TO DO!! WILL COMMENT A MASK. I JUST NEED TWO MOBILE OBJECT. THE OTHER TWO WILL BE A MEAL AND ANOTHER OBJECT!! (WITH MISSILES...) I THINK THAT CAN WORK ENEMY --- GRP0 STATIC MEAL --- MISSILE0 PLAYER--- GRP1 STATIC OBJECT ---MISSILE1 Edited March 9, 2018 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 9, 2018 Share Posted March 9, 2018 Lots of problems, you're going to need to rethink your project. Your image is 37 scanlines. To have the blank space above/below the image you need enough to cover the image's range. Your 1LK covers 192 scanlines so if your image is all the way at the top you need 155 zeros below it for the masking to work. Likewise, if your image is all the way to the bottom you need 155 zeros above it. 155 + 37 + 155 = 347. A single page of ROM is 256 bytes. Because the data you need to cover both extremes exceeds that, you'll eventually cross a page. For Stay Frosty 1 I used a 1LK, but it didn't span the entire screen. The screen was broken up into zones, and each zone had their own pointers so significantly fewer zeros were needed above/below the image: And even with that, I couldn't update everything. I ended up dropping PF0 and only using PF1 and PF2 to draw a mirrored playfield. If you do this that frees up 10 cycles per scanline, which gives you extra cycles so you don't have to worry about crossing a page. Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted March 10, 2018 Author Share Posted March 10, 2018 (edited) Lots of problems, you're going to need to rethink your project. Your image is 37 scanlines. To have the blank space above/below the image you need enough to cover the image's range. Your 1LK covers 192 scanlines so if your image is all the way at the top you need 155 zeros below it for the masking to work. Likewise, if your image is all the way to the bottom you need 155 zeros above it. 155 + 37 + 155 = 347. A single page of ROM is 256 bytes. Because the data you need to cover both extremes exceeds that, you'll eventually cross a page. For Stay Frosty 1 I used a 1LK, but it didn't span the entire screen. The screen was broken up into zones, and each zone had their own pointers so significantly fewer zeros were needed above/below the image: blogentry-3056-0-11662100-1467471571.png And even with that, I couldn't update everything. I ended up dropping PF0 and only using PF1 and PF2 to draw a mirrored playfield. If you do this that frees up 10 cycles per scanline, which gives you extra cycles so you don't have to worry about crossing a page. blogentry-3056-0-01040700-1467567026_thumb.png how did you all transparent? i don't remember if CTRLPF has this property? Edited March 11, 2018 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 10, 2018 Share Posted March 10, 2018 how did you all transparent? i don't remember if ctrlf has this property? 30 Hz flicker - Stay Frosty, Part 2 1 Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted March 10, 2018 Author Share Posted March 10, 2018 (edited) 30 Hz flicker - Stay Frosty, Part 2 i'm thinking about using sectors Darrell, first now i must implement your 2LK with Masked graphics, the kernel i have planned is 127 lines, up before this kernel in the black part will put other kernel with lifes,objects and energy, a lot of work too. but you are right, must use sectors.i will take this with calm. and re understand all. ty Darrel and thanks to all of you AtariAge. Edited March 13, 2018 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted March 18, 2018 Author Share Posted March 18, 2018 (edited) Lots of problems, you're going to need to rethink your project. Your image is 37 scanlines. To have the blank space above/below the image you need enough to cover the image's range. Your 1LK covers 192 scanlines so if your image is all the way at the top you need 155 zeros below it for the masking to work. Likewise, if your image is all the way to the bottom you need 155 zeros above it. 155 + 37 + 155 = 347. A single page of ROM is 256 bytes. Because the data you need to cover both extremes exceeds that, you'll eventually cross a page. For Stay Frosty 1 I used a 1LK, but it didn't span the entire screen. The screen was broken up into zones, and each zone had their own pointers so significantly fewer zeros were needed above/below the image: blogentry-3056-0-11662100-1467471571.png And even with that, I couldn't update everything. I ended up dropping PF0 and only using PF1 and PF2 to draw a mirrored playfield. If you do this that frees up 10 cycles per scanline, which gives you extra cycles so you don't have to worry about crossing a page. blogentry-3056-0-01040700-1467567026_thumb.png Hi Darrell, i was trying to use a 2lk kernel for my port of the game, but the sprites become larger... too much for my taste. i though that i could combine 2lk with SECTIONS so now... i'm reading about your Stay Frosty and once i have understood all... will proceed to try again a (1LK+SECTIONS) for my purposes. cheers. Edited March 18, 2018 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
vidak Posted March 29, 2018 Share Posted March 29, 2018 I think you need to slow down, zilog! A good strategy to learning something new is to learn things in steps! I'd say master drawing a single character using DoDraw first, then draw a 2LK using DoDraw, then master drawing a symmetrical playfield using a 2LK, then perhaps draw an asymmetrical playfield by itself, and then see how much other stuff you can fit in with timing constraints.I have found that an asymmetrical playfield uses up a LOT of cycles. It is probably the most difficult thing to fit into a kernel. Small steps! I started building my game step by step - I had no ability to draw even a /single/ multi-coloured sprite when I first set out. Even multi-coloured sprites take up a lot of time. You have 76 cycles per scan line, that really is not a lot!! Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted March 29, 2018 Author Share Posted March 29, 2018 (edited) I think you need to slow down, zilog! A good strategy to learning something new is to learn things in steps! I'd say master drawing a single character using DoDraw first, then draw a 2LK using DoDraw, then master drawing a symmetrical playfield using a 2LK, then perhaps draw an asymmetrical playfield by itself, and then see how much other stuff you can fit in with timing constraints. I have found that an asymmetrical playfield uses up a LOT of cycles. It is probably the most difficult thing to fit into a kernel. Small steps! I started building my game step by step - I had no ability to draw even a /single/ multi-coloured sprite when I first set out. Even multi-coloured sprites take up a lot of time. You have 76 cycles per scan line, that really is not a lot!! Hi Vidak!! i will use sectors with an asymetrical playfield 1LK (2LK ENLARGES MY SPRITES A LOT), two sprites (one masked). if i try to use two masked nothing fits.... or if i retire STA WSYNC in kernel loop my asymetrical playfield gets all lines in a no sense offset. i was thinking yesterday about Frosty and Sierra Maestra, if sectors works for me, great, if not i will need to use c programming dpc+arm. ty Vidak. ps (my playfield is 127 lines) will do several sectors of this i think.... characters animation is already done but i don't use it in tests. Edited March 29, 2018 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted March 30, 2018 Share Posted March 30, 2018 You could always use 3E with enough RAM to buffer the entire screen as code and do lda #, sta zp for everything. After accounting for loop and bank switch overhead you'd probably have enough time for 10-12 TIA writes. That's enough for an assymetric PF and colored sprites. Of course writing a new PF to the buffer would need to span a few frames. 1 Quote Link to comment Share on other sites More sharing options...
zilog_z80a Posted March 30, 2018 Author Share Posted March 30, 2018 (edited) You could always use 3E with enough RAM to buffer the entire screen as code and do lda #, sta zp for everything. After accounting for loop and bank switch overhead you'd probably have enough time for 10-12 TIA writes. That's enough for an assymetric PF and colored sprites. Of course writing a new PF to the buffer would need to span a few frames. Hi ZackAttack, i will maintain all monochrome. will be a version near to zx spectrum in that aspect, in that manner i can do more logical at extended ram and less graphics repeated info. TY FOR YOUR INFO. cheers!! Edited March 31, 2018 by zilog_z80a Quote Link to comment Share on other sites More sharing options...
