Trouble with images divisible by 16
17 replies to this topic
#1 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Wed Feb 28, 2018 6:36 PM
Both the height and the width of the picture I want to show is divisible by 16. So what am I doing wrong here? Why won't it show anything but green? It's supposed to be an orange.
#2 ggn OFFLINE
ggn
  • 1,453 posts
Posted Thu Mar 1, 2018 2:29 AM
Next time please include more information of what you're trying to do - it'll save some time for everyone!
Your image is 8 bitplanes in depth and the object is set up to handle that. No probs there. The problem is that 8 bpp images are in fact paletted, so you need to tell assets.txt to dump a palette. And then you need to tell rb+ to load the palette at startup using loadclut.
I'll omit the fix as an excersise to the user :)
#3 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Thu Mar 1, 2018 10:12 AM
I'm trying to make the orange show up on the screen. But it won't. All the documents say that 8 bpp graphics don't have a CLUT.
#4 ggn OFFLINE
ggn
  • 1,453 posts
Posted Thu Mar 1, 2018 12:23 PM
Citation needed.
Edited by ggn, Thu Mar 1, 2018 12:25 PM.
#5 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Thu Mar 1, 2018 3:39 PM
From the rapinit.s file:
    dc.l    no_CLUT                ; no_CLUT                            ; Define sprite colours.                                            ;   R_sprite_CLUT
        ; no_CLUT for 8, 16 and 24bit
        ; CLUT number 0 to 15 for 1, 2 and 4bit
#6 CyranoJ OFFLINE
CyranoJ
    RAPTOR Wrangler
  • 5,702 posts
  • reBOOTed
Posted Thu Mar 1, 2018 3:53 PM
That does not mean it does not have a CLUT.
#7 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Sat Mar 3, 2018 11:54 PM
I gave it a CLUT of 1 and it displays a black orange instead of an orange one.
#8 ggn OFFLINE
ggn
  • 1,453 posts
Posted Sat Mar 3, 2018 11:58 PM
Try 0.
#9 WAVE 1 GAMES OFFLINE
WAVE 1 GAMES
  • 1,096 posts
Posted Sun Mar 4, 2018 12:05 AM
Try deleteing the orange CLUT and gfx data files from the build folder. Then build it again and see how it looks. Basically just re-wright the clut file
#10 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Sun Mar 4, 2018 12:25 AM
Neither suggestion worked. Why won't this stupid picture go in?
#11 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Sun Mar 4, 2018 12:34 AM
And this is the result when I try to put it in:
Attached File  resultwhichisstupidandwrong.png   8.23KB   1 downloads
#12 sh3-rg OFFLINE
sh3-rg
  • 3,397 posts
  • doge + tie = dothemath
Posted Sun Mar 4, 2018 3:24 AM
8-bit images, 256 colours, use all 256 colour registers - the whole CLUT. It's not like 16-bit where it's Red-Blue-Green values described per pixel, it's like 1-, 2- and 4-bit images that have an array of colours indexed by these bits.
You need to set your object to CLUT 0 or no_CLUT (IIRC, both will work), and have assets.txt create a CLUT file and fire that data at the CLUT.
If that doesn't work, maybe your image tool is shipping broken files, or maybe you're overwriting sections of the CLUT with other palette data for other objects.
Simple solution if you do not require palette adjusting for the object is make it 16-bit. If that doesn't suit your needs, you're going to have to make your orange graphic's 256 colour palette suitable for both it and any other sub-16-bit objects you want to use and carefully manage your CLUT.
#13 Welshworrier OFFLINE
Welshworrier
    Moonsweeper
  • 250 posts
Posted Sun Mar 4, 2018 4:31 AM
Out of interest is this for a different game to the one you are working on with Jeffrey Bonez?
#14 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Sun Mar 4, 2018 7:08 AM
Yes, this is a different game.
#15 ggn OFFLINE
ggn
  • 1,453 posts
Posted Fri Mar 9, 2018 3:42 AM
So it's been a week without this getting solved, so it's hand holding time yet again!
  • Download and extract zip
  • In assets.txt Change gfx_noclut to gfx_clut
  • In oranges.bas add loadclut(strptr(ORANGEFRUIT_clut),0,256) before the DO statement
  • Build and run
Because you didn't read my first reply?
Edited by ggn, Fri Mar 9, 2018 3:42 AM.
#16 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Fri Mar 9, 2018 6:04 AM
Sorry to be such a pain. I didn't realize the number after the CLUT was the number of colors.
#17 ggn OFFLINE
ggn
  • 1,453 posts
Posted Fri Mar 9, 2018 7:16 AM
Well, it's ok. If my explanations aren't making sense to you don't hesitate to ask for clarifications.
#18 atari2600land ONLINE
atari2600land
    Channel F Viewer
  • 11,625 posts
Posted Fri Mar 9, 2018 8:06 AM
Kind of a bland factory, but oh well...
Attached File  orangesjaguarpic2.png   10.45KB   1 downloads
Reply to this topic
