Sio2SD, Help desperately needed.
5 replies to this topic
#1 TonVH OFFLINE
TonVH
    Star Raider
  • 51 posts
Posted Tue Mar 6, 2018 11:58 AM
Received the Sio2SD + SD-card. Plugged it into the Sioport, turn on 800XL (tried with and without Option). After a short time I get a screen with "AHT", "Alley Cat".
But how do I get the File selector??????
I've checked instructions on Lothareks site (about K1, ....) but either do not understand them correctly or whatever. Looked at Youtube movies they all show file selector.
Please a step by step "How To".
#2 Almerian OFFLINE
Almerian
    Space Invader
  • 48 posts
Posted Tue Mar 6, 2018 12:12 PM
Look here for instructions:
https://retrogamesul...6/atari-sio2sd/
#3 TonVH OFFLINE
TonVH
    Star Raider
  • 51 posts
Posted Tue Mar 6, 2018 12:20 PM
Tried that myriad times.  After a short while I see "cfg tool mode" in display but when I then press K2 I never get to see the text "every startup". Pressing K2 who's a text like "127840.80 ($00)". Then after I am lost.
(for the time being all I want is to select thru file selector and nothing further).
The SD-card contains the files sio2sd.cfg, sio2sd.xex and folder Atari.
Edited by TonVH, Tue Mar 6, 2018 12:23 PM.
#4 Almerian OFFLINE
Almerian
    Space Invader
  • 48 posts
Posted Tue Mar 6, 2018 12:34 PM
Try this, you can see which buttons are pressed:
https://youtu.be/iQT_Qjl3OQ8?t=3m30s
#5 TonVH OFFLINE
TonVH
    Star Raider
  • 51 posts
Posted Tue Mar 6, 2018 1:04 PM
The trick clearly is to press "Shift" on the Sio2SD at start. So solved that. Thanks.
The "High speed Sio support" is installed. How can I ee whether this is active because I have the feeling loading is very slow.
#6 Philsan OFFLINE
Philsan
  • 3,672 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Tue Mar 6, 2018 1:17 PM
Those 2017 instructions seem based on my guide online for years: http://www.santelloc...2sd.htm#english
For example
ON-SCREEN LOADER INSTRUCTIONS (v3.5)
ARROWS/JOYSTICK select file .xex or disk image .atr
KEYS 1-8 mount selected file/image into drives 1-8
CTRL+T lets you toggle between real drives / virtual drives
ESC climb directory tree
X (long press) restart computer with selected images
RETURN/FIRE enter directory/load file/disk image
Loader Instructions (v3.5):
ARROWS/JOYSTICK: select directory/file (.xex) or disk image (.atr)
RETURN/FIRE: enter directory/load file/disk image
KEYS 1-8: mount selected file/image into drives 1-8
ESC: go back through the directory tree.
X: (long press) restart computer with selected image(s).
CTRL+T: lets you toggle between real drives / virtual drives
Anyway, the important thing is that they can help people use SIO2SD.
