+karri Posted April 10, 2018 Share Posted April 10, 2018 Hi, I have a few Lynx I units where the voltage refuses to rise above 4.2V. Obviously some chip is eating up the power. So far the metal casing hides Mikey, Suzy and RAM. I did already replace the caps, MOSFET and zener. Most likely I could just try to push enough power in to see from where the magic smoke escapes. But I wonder if someone has good experience of what chip is the most likely corpse. 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 10, 2018 Author Share Posted April 10, 2018 I opened up the metal cover and there is one chip getting REALLY hot. U3 the RAM chip. 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 13, 2018 Author Share Posted April 13, 2018 By removing the bad chip the voltages got back to normal. I found the same chip on ebay for €5 for 10 chips. 4 Quote Link to comment Share on other sites More sharing options...
Level42 Posted April 16, 2018 Share Posted April 16, 2018 (edited) I like monologues, especially when you come up with the solution Seriously, great info ! I bet Utsource might have even been cheaper.....but also slower....What type of RAMs are they ? (sorry too lazy to check schematics.....LOL) I have a feeling RAMs may die first on over-voltage situations....or maybe in general.... see how mT RAMs die on A8's.... Edited April 16, 2018 by Level42 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 19, 2018 Author Share Posted April 19, 2018 The RAM is of the type D41464C. Easy to find on ebay. I also had another Lynx I that was on all the time. The broken chip was U6 a hex inverter. After I replaced it from another broken Lynx the on/off buttons started to work. Perhaps documenting broken parts could help me next time I have to fix some Lynxes. 2 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 19, 2018 Author Share Posted April 19, 2018 Continuing on my monologue... I also have a Lynx that says "INSERT GAME". As the text turns up I assume that Mikey works. RAM works. Suzy works at least partly. The cart port could have a cold joint (it did not). The voltage is at 4.85V. So it appears to be ok. Perhaps re-capping could be done first. These are the logical parts that turn bad at old age. 2 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 19, 2018 Author Share Posted April 19, 2018 This is so weird. The problem was in the wear of the cart connector itself. Some carts like Slime World refused to start so I got the diagnose wrong. The cart connector just needs a little work-over with some dentist tools. And re-capping I assume. 2 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 20, 2018 Author Share Posted April 20, 2018 The next broken Lynx started nicely when given 5V to the poles of capacitor C39. But the normal start/stop and power adaptor was broken. The first thing was to get a barrel socket from another broken Lynx. The transistor Q13 was burned. Transferred a good one from another broken Lynx. So now I have still one more "good" Lynx. (The whole idea with this exercise was to find a few broken Lynxes so I could get the cart connectors for my programmer. I bought a bunch of broken Lynxes and 4 seems to be badly broken. For the resurrected Lynxes I do some re-capping and let them back in the wild.) 1 Quote Link to comment Share on other sites More sharing options...
