Can I learn to hack 5200 pole position controller code?
7 replies to this topic
#1 Swami ONLINE
Swami
  • 2,481 posts
Posted Wed May 16, 2018 1:00 PM
If I wanted to learn to hack the 5200 pole position rom controller code for a PC racing wheel with a homemade 5200 to 15pin PC adapter, is this a reasonable short term goal for learning to program for the 5200? I know pretty much nothing, like should I learn to do such a thing in BASIC or assembly? Where can I learn step by step to get to this point?
The end goal of this project would be to move the acceleration and braking from fire 1 and 2 to up and down, to have analog gas and brake that work on old PC wheels, to move the shifter to fire1 and fire2, since the PC wheel shifters are digital, and, finally, be able to fine tune trigger values for these four functions to work with variations in wheel voltage outputs.
Thanks!
#2 baktra ONLINE
baktra
    Dragonstomper
  • 575 posts
Posted Thu May 17, 2018 1:40 AM
It is most certainly an ambitious goal.
You would need to do it in assembly language. that is for sure.
As your project involves also hardware, let us test feasibility.
Each 5200 controller has two analog inputs (two joystick axes, in modern terminology), that should be sufficient. One axis for steering, other axis for braking/acceleration.
In terms of the software, you would have to hack P.P's controller reading code (reading axes instead of buttons), and update also the game physics (so it not only recognizes "braking on/off", but "how much of braking".
#3 Xuel OFFLINE
Xuel
    Dragonstomper
  • 733 posts
Posted Thu May 17, 2018 12:32 PM
One way to handle braking without modifying the game physics too much would be to convert the analog braking value into pulse-width-modulated braking on/off. Varying the number of frames of braking "on" per, say, 20 frames would give you 20 levels of braking. So, for example, a very light braking could convert to braking "on" for 1 out of every 20 frames and full braking could convert to braking "on" 20 out of every 20 frames.
But maybe it's just as easy to modify the physics engine to handle variable amount of braking.
Thanks!
You're going to need to disassemble the original game code into assembly so 1) you can understand how it works and 2) you know where to modify it.
Here's a quick disassembly the 8-bit computer version of Pole Position to give you an idea:
Attached File  pp.zip   301.34KB   26 downloads
I included my disassembler "dis" and xasm. I didn't label anything other than the standard OS and hardware memory locations. Disassembly is an art. You have to figure out what various parts of code do but the main thing is figuring out how the data and variables are laid out. Once you know which memory locations correspond to various aspects of the game it becomes much easier to understand what's going on throughout the code. For example, one byte may be used by the code to store the velocity of your car. Figuring out which one will help you unravel other bits of code since you'll see all the places that refer to that byte and then understand they must have something to do with either setting or reacting to the velocity of the car. It's a multidimensional puzzle.
#4 Swami ONLINE
Swami
  • 2,481 posts
Posted Thu May 17, 2018 12:47 PM
attachicon.gifpp.zip
Thank you. That is helpful. Would you or anyone else know of a book or internet based tutorial that would be an introduction to 8 bit/5200 programming that would include 5200 controller (analog/digital/trackball) programming? Or two sequential sources that would get me to the same point more or less?
#5 Xuel OFFLINE
Xuel
    Dragonstomper
  • 733 posts
Posted Thu May 17, 2018 1:45 PM
The Altirra Hardware Reference Manual is a comprehensive Atari 8-bit computer and 5200 reference. The only other thing you need is a 6502 CPU fundamentals guide. Maybe this one is good? I haven't gone through it but superficially it looks OK.
#6 Swami ONLINE
Swami
  • 2,481 posts
Posted Thu May 17, 2018 2:29 PM
Okay, I'm making pixels in a 6502 assembly environment in a Java 6502 emulator, I think...
Thanks for getting me started.
#7 baktra ONLINE
baktra
    Dragonstomper
  • 575 posts
Posted Fri May 18, 2018 10:04 AM
And let's not forget http://atariage.com/...ms-to-the-5200/
#8 pirx OFFLINE
pirx
    Moonsweeper
  • 447 posts
Posted Sun May 20, 2018 6:24 AM
what about doing this in e.g. arduino? this way not much of a 6052 learning would be involved (sadly), but other games could benefit. and finding old PC analog joysticks would be possibly easier than 5200 controllers, so it'd be a winwinwin situation.
