Question about sprites & pixel position
4 replies to this topic
#1 jeffry OFFLINE
jeffry
    Space Invader
  • 15 posts
Posted Thu May 17, 2018 4:46 AM
I am trying to code my own colision detection.
Everytime I think i have it ... I don't.
I am hoping someone get help me get back on track.
Suppose my player0 sprtie is a 8x8 square.
If I set player0x = 50 & player0y = 50  which pixel of my sprite will be at coordinates 50,50?
  123454678
a ########
b ########
c ########
d ########
e ########
f  ########
g ########
h ########
  Is  a1? h1? a8? h8?  Something else?
Also how does using the REFP0 affect this?
My code seems to me that everything looks correct yet it doesnt quite work. I believe if I can get a clear answer on which pixel is at the defined coordinate I can figure this out.
Thanks for any help to set me straight.
Edited by jeffry, Thu May 17, 2018 4:47 AM.
#2 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,964 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu May 17, 2018 5:28 AM
Have you played with any of the example programs below? You can move sprites around and see the coordinates in the score:
Find Border Coordinates
9 Objects with Coordinates
13 Objects With Coordinates and Collision (DPC+)
It can help you figure out exactly where things are.
#3 Karl G ONLINE
Karl G
    Dragonstomper
  • 793 posts
Posted Thu May 17, 2018 6:11 AM
H1. Reflecting the sprite won't affect the positioning of the sprite.
Edited by kdgarris, Thu May 17, 2018 6:15 AM.
#4 jeffry OFFLINE
jeffry
    Space Invader
  • 15 posts
Posted Thu May 17, 2018 12:06 PM
@Random Terrain
Thanks I had seen that program before in fact i modified it to measure and plot playfields.
I just never thought about utilizing it in this context .. brainfart I guess... Thanks!
P.S. I assume by your name you are the one with the similiarly named website.... SO THANK YOU again. you have given me unmeasurable guidence and help via that site.
@kdgarris... Thanks.. I was hopping that not accounting for the REF was part of my problem but alas I screwed up elsewhere
Thanks to Both of you!!!!
#5 RevEng OFFLINE
RevEng
    Bit Player
  • 5,176 posts
Posted Sat May 19, 2018 6:00 PM
The answer to your original question actually varies on the kernel used. The standard kernel uses your "h1" as the base. DPC+ uses your "a1". The multisprite kernel regular player uses "h1", and the virtual players are a bit offset from there.
The wrinkle to all of these is if you use NUSIZ#=5 or NUSIZ#=7 to modify the player size, it's pushed one pixel to the right.
I've put together a boxcollision routine for bB along with some samples, which you may be interested in.
