2 button joystick ?
145 replies to this topic
#126 Mathy OFFLINE
Mathy
  • 2,967 posts
Posted Fri Mar 22, 2019 6:51 PM
Hello Steve
Some voice from the back of my mind whispers that there are two types of potmeters: linear and logarithmic.  Maybe you've got the logarithmic type?
Sincerely
Mathy
#127 Stephen OFFLINE
Stephen
  • 7,651 posts
  • A8 Gear Head
Posted Fri Mar 22, 2019 9:08 PM
I'm thinking the pots should also be 500k and not 1M, but it's been over a decade since I had one apart.
#128 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
  • Lost in the Robot Factory
Posted Sat Mar 23, 2019 9:43 AM
It's 470K for a C64, 1M for an Atari 2600/8Bit.
Either Mathy is right and I flubbed my pot purchasing (wow I haven't said "pot purchasing" for a loooong time!) or I've screwed the wiring somehow.
#129 Zonie OFFLINE
Zonie
  • 2,165 posts
Posted Sat Mar 23, 2019 10:13 AM
Linear Taper and Audio Taper. Probably the latter...
#130 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 208 posts
Posted Sat Mar 23, 2019 3:45 PM
Hi All,
add 3 more games : :-D
  • Dropzone
  • Star Raiders II
  • Lode Runner
this was a contribution from a friend who supports the project.
https://github.com/a...ee/master/games
regards
Edited by ascrnet, Sat Mar 23, 2019 3:46 PM.
#131 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
Posted Sat Mar 23, 2019 4:07 PM
You're the hero we need :D
#132 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 208 posts
Posted Mon Mar 25, 2019 7:39 PM
thanks, but I'm not the only one in this project.
regards
#133 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
Posted Tue Mar 26, 2019 7:11 PM
Well it turns out I screwed up the schematic. There is a problem with the switching between paddle and buttons. Need to rework it.
EDIT: V3 boards ordered from OSHPark. :/
Edited by Mr Robot, Tue Mar 26, 2019 7:37 PM.
#134 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 208 posts
Posted Wed Mar 27, 2019 7:17 PM
no problem, I want to see that pcb working to make another joystick 2.0 :grin:
News: soon in Altirra 3.20 will have support for 3 buttons using my scheme ;-)
regards
#135 R0ger OFFLINE
R0ger
    Moonsweeper
  • 429 posts
Posted Thu Mar 28, 2019 11:44 AM
That's great news !
#136 tane OFFLINE
tane
    Chopper Commander
  • 118 posts
Posted Sun Mar 31, 2019 7:44 PM
Bored enough to hack your Joystick Tester:    Attached File  Joystick Tester.xex   761bytes   30 downloads
#137 tane OFFLINE
tane
    Chopper Commander
  • 118 posts
Posted Mon Apr 1, 2019 8:35 AM
Rounded corners:  Attached File  Joystick Tester.xex   761bytes   47 downloads
#138 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 208 posts
Posted Fri Apr 5, 2019 7:48 PM
Rounded corners
congratulations for the modification tane, I liked the idea of the buttons. copying !!!!! :-D
regards
#139 krupkaj OFFLINE
krupkaj
  • 1,227 posts
  • from 8 to 64 and beyond
Posted Sun Apr 7, 2019 3:11 AM
This all is really nice, thanks for all pathes.
BTW I remember there was version of Missile Command with 3 turrets. But ihey were operated from keyboard. It would be great to have version with joystick buttons, or maybe we can hack also the trackball :)
#140 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
Posted Tue Apr 16, 2019 3:54 PM
Just a quick update. V3 worked fine, I've used the schematic to make two different versions of the board, one with everything, one with just the extra buttons (and Fire3/Up switch) which is small enough to be only $6 for three from oshpark. Waiting for the purple pcb's to arrive again.
#141 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
Posted Mon Apr 29, 2019 3:42 PM
OK the boards are in and work great, here they are fully populated (you probably won't need to do that)
I'm just writing some documentation and I'll be sharing, hopefully tomorrow. The Large board is $12.30 for 3 and the small board (the one most people will probably want) is $6.95 for 3. The docs will be on my website and the gerbers will be on OSHPark.
#142 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 208 posts
Posted Mon Apr 29, 2019 8:12 PM
congratulations for the design of the plates, they were very good. :D
regards
#143 Zonie OFFLINE
Zonie
  • 2,165 posts
Posted Mon Apr 29, 2019 9:37 PM
Nice
#144 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
Posted Tue Apr 30, 2019 2:17 PM
https://atari8bit.ne...ler-interfaces/
#145 Lynxpro OFFLINE
Lynxpro
  • 3,741 posts
Posted Thu May 2, 2019 5:40 PM
What an interesting thread to stumble upon...
Just to give you guys some inspiration, back-in-the-day in Atari Inc's Consumer Engineering Division, Dan Kramer and others built custom Trak-Balls with 3 Fire Buttons so they could accurately play Missile Command on their A8s. The custom in-house version is referred to as 3-Base Missile Command. Here's a pic of Dan's custom 3-button Trak-Ball Controller for use with it:
Dan Kramer 3 Fire Button Custom Trak Ball Controller
Rob Zdybel suggested using the Paddle Lines for the 2 extra Fire Buttons.
Mr. Robot's pic of the various Atari arcade controllers reminded me that had Warner not forced Atari Inc to cancel the 5200, Dan Kramer would've finished up a Driving Controller [based upon Atari's Pole Position Steering Wheel and Shifter] and a Yoke Controller [based upon Atari's Star Wars Yoke] for that doomed console.
#146 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 768 posts
Posted Fri May 3, 2019 4:05 PM
I got a gift from the Kevin Savetz and Nir Dary today at VCF East!
Here is David's Midnight Magic with the flipper buttons swapped around to match Pinball Construction Set so it will work correctly with the flipper buttons on my joystick boards.
Attached File  midnight-joystickFix.xex   45.9KB   8 downloads
That just leaves Advanced Pinball Simulator, I think that one will be harder to do, it uses the keyboard buttons 'Z' and '/'
