Boolean operator syntax error
9 replies to this topic
#1 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Mon May 28, 2018 11:08 AM
Hello Guys,
I have been using the following without issue:-
if x= 49 || x=57 then a=26
But if I use the following, I get a Syntax error:-
if x= c-2 || x=c+2 then a=26
I guessing I'm missing something really obvious here, but what have I done wrong. I have checked out http://www.randomter...ds.html#boolean, and from what I can see, what I'm doing is good. For what I'm trying to do, it is important that the x value is compared against the result of the c value.
The weird thing is that the following compiles without issue:-
if x=c+1 then a=14
Is the problem that I'm doing x=c-2 followed by the boolean or?
#2 Osgeld ONLINE
Osgeld
  • 5,847 posts
Posted Mon May 28, 2018 11:25 AM
try
if x= (c-2) || x=(c+2) then a=26
Edit you need a space tween - and 2
Edited by Osgeld, Mon May 28, 2018 11:29 AM.
#3 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Tue May 29, 2018 11:53 AM
Thanks for the response Osgeld. Spaces is not the issue:-
if x = c - 5 || x = c + 5 then a=28
The above still fails to compile. I also tried:-
if x = (c - 5) || x = (c + 5) then a = 28
But still no cigar. Any further ideas?
#4 Lewis2907 OFFLINE
Lewis2907
    Moonsweeper
  • 303 posts
Posted Tue May 29, 2018 12:21 PM
tdp,
I got this to compile:
if x= c-2 then a=26 else if x=c+2 then a=26
I'm not sure if this is what you are looking for, thanks.
#5 bogax OFFLINE
bogax
    Dragonstomper
  • 787 posts
Posted Tue May 29, 2018 5:50 PM
This Works
  if x <> c - 2 && x <> c + 2 then skip
  a = 26
skip
This Works better
  if c - 2 <> x && c + 2 <> x then skip
  a = 26
skip
Edited by bogax, Tue May 29, 2018 6:01 PM.
#6 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Wed May 30, 2018 9:32 AM
Thanks guys. Digging into the RT bBatari docs some more, I can see that OR (||) has more restrictions on it that AND (&&). Case in point:-
if player0x = c + 5 && player0y = d + 5 then a=30
The above compiles fine. Now, just swap the operator from AND to OR:-
if player0x = c + 5 || player0y = d + 5 then a=30
The above does not compile. Looks like there are stricter restrictions on OR, compared to AND. Still trying stuff.
Edited by tdp, Wed May 30, 2018 9:32 AM.
#7 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,811 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Wed May 30, 2018 12:35 PM
Earlier versions of bB couldn't use math in if-thens, so we did the math in temporary variables and used those in the if-thens. I still do that to avoid any problems.
#8 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Wed May 30, 2018 2:05 PM
Hello Random - what do you mean by temporary variables? Will need to hit the docs again to learn more.
Edited by tdp, Wed May 30, 2018 2:22 PM.
#9 Random Terrain OFFLINE
Random Terrain
  • 28,811 posts
    Replay Value
    Nonlinear
Posted Wed May 30, 2018 2:22 PM
randomterrain.com/atari-2600-memories-batari-basic-commands.html#temp_variables
Example:
   temp6 = c + 5 : temp5 = d + 5
   if player0x = temp6 || player0y = temp5 then a = 30
#10 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Wed May 30, 2018 2:39 PM
@RT - Awesome stuff. I will try this later.
Thank you so much!!
