Really Dumb Programming Question
11 replies to this topic
#1 koolmoecraig OFFLINE
koolmoecraig
    Star Raider
  • 86 posts
Posted Wed Jun 13, 2018 3:30 PM
Don't laugh.
So just getting back into my old disks from back in the day.  I don't really have memories of how some stuff worked...
I boot a Basic program from disk - some old game I typed in from Antic or whatever back then.
I load it.
I "List" it. All the code comes up and scrolls.
How do I scroll up to look at and modify the code?  When I use "CONTROL" and the "UP" arrow, i can only get the cursor to the top of the code that is showing on the screen - it will not scroll?
What simple thing am I not doing?
I appreciate the help. Thank you!
#2 KLund1 OFFLINE
KLund1
    Dragonstomper
  • 633 posts
Posted Wed Jun 13, 2018 3:44 PM
No, once it is off the top it is gone.
You need to list a range, or hit break during a full list.
#3 vitoco OFFLINE
vitoco
    Moonsweeper
  • 312 posts
Posted Wed Jun 13, 2018 3:46 PM
Type:
LIST 50
LIST 100,200
where the numbers are a line or a range of lines of the BASIC listing.
You can use CTRL+1 to pause/resume the listing to find the needed one. You can press break to interrupt the listing and get the READY prompt. Once in screen, you can edit it. Be careful if the line is longer than 3 physical lines of the screen.
"LIST" can be abbreviated as "L."
Edited by vitoco, Wed Jun 13, 2018 3:47 PM.
#4 koolmoecraig OFFLINE
koolmoecraig
    Star Raider
  • 86 posts
Posted Wed Jun 13, 2018 4:01 PM
Appreciate it! Thanks again
#5 koolmoecraig OFFLINE
koolmoecraig
    Star Raider
  • 86 posts
Posted Wed Jun 13, 2018 4:56 PM
Back again :)
OK, so I go back to the specific line of code...
List 1
Bring up the line I want to change - In this case it's my name(Because I misspelled it back in the day :)
I change the line.
Go back to the READY prompt and type: SAVE "D1:filename.bas
I get ERROR-    144
What simple thing am I messing up here?
#6 A8Watcher_808 ONLINE
A8Watcher_808
    Space Invader
  • 15 posts
Posted Wed Jun 13, 2018 5:40 PM
Error 144 means that it is having problems writing/reading from disk. The disk could be write protected (disk notch is covered) or the disk could be bad.
#7 russg OFFLINE
russg
  • 1,646 posts
Posted Thu Jun 14, 2018 2:37 PM
144 also is the error you get when densities are different from what is expected.  You have to get a disk directory or something
to set the density of the target drive.
I don't know if you can read from one density and write to a different drive in a different density.
I guess you can. DOS has to know the density it is working in.
DOS may be able to keep densities of source and destination, I don't know.
I'm still thinking.  DOS has to know how to deal with files of different DOSes.
I'm sure you can read and write from/to two different DOSes.
Edited by russg, Thu Jun 14, 2018 3:10 PM.
#8 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,946 posts
Posted Thu Jun 14, 2018 7:20 PM
If you're using the Altirra emulator, the default is for disks to be mounted as Read-only.  So, Error 144 will be the result of attempted writes to a disk image.
Use the Disk dialog to mount then change the mode to R/W.
#9 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,114 posts
Posted Thu Jun 14, 2018 10:03 PM
Brings me to a question... was there a homecomputer
Basic which has the ability be used like a text editor? Means scroll up/down?
Some assemblers had that feature.
I am not aware of any? Maybe Sinclair or amstrad machines?
#10 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,946 posts
Posted Fri Jun 15, 2018 3:26 AM
For Atari I don't think any language cart before Action! had a proper editor.
I can't think of any 8-bit computer that had a built in Basic with proper editing.  Also, proper editing usually goes in hand with no line numbers which I don't think any stock 8-bit Basic did.
Also consider, Atari was the pinnacle of stock editing capability with C= machines a distant second.  Most others at best only had a partial fullscreen editor.
Amstrad like BBC has a pretty decent Basic built in but again the editing is the crippled variety.
In the 16-bit era, I think practically everything for ST and Amiga was by proper editor.  Though the DBasic language for ST uses a legacy style text screen + line #s.  I'm not sure it's in use much in the modern day, it uses a 1K sector format which emulation doesn't seem to support.
Probably the main reason for lack of proper editors for 8-bitters - they don't lend so well to compact, tokenized programs.  On the 16-bit machines with 1/2 a Meg or more Ram it was much less of a problem to have big slabs of raw text in memory.
Edited by Rybags, Fri Jun 15, 2018 3:28 AM.
  • slx likes this
#11 slx OFFLINE
slx
  • 1,625 posts
Posted Mon Jun 18, 2018 2:40 PM
Even a couple years later PC-DOS came with edlin which was strictly line oriented and a total step backwards compared to the Atari.
Now, a parsing full-screen editor would be a worthy project...
#12 pirx OFFLINE
pirx
    Moonsweeper
  • 447 posts
Posted Mon Jun 18, 2018 3:52 PM
fast basic by our great contributor dmsc: https://github.com/dmsc/fastbasic
