Jason_Atari Posted June 15, 2018 Share Posted June 15, 2018 Iv'e got a NES that has a weird issue, i've google searched and i can't find any fix specifically to this problem. Initially i had the white screen of death, i changed the cart connector (with a 100% known good one) and disabled the lock out chip. This seemed to fix it (so i thought) The problem is now it works intermittently. If i put a cart in and turn it on it works, turn it off (not touch anything) turn it back on and it's white screen again. It seems to boot up randomly even if the cart is connecting good in the connector. Any advise would be appreciated Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted June 15, 2018 Share Posted June 15, 2018 If you disabled the lockout chip by clipping the pin, I believe I read that method will usually work, but not always and you may need to tie the clipped lead to either +5 or ground (not sure which). In that case, your symptom might be explained by that signal "floating" and acting as either +5 or gnd just depending on random noise at the time of reset. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted June 15, 2018 Share Posted June 15, 2018 It's a cart connector problem. Cutting the lockout chip isn't a solution. Unless you are trying to play an unlicensed game all that cutting the lockout chip does is mask the real problem. The issue is simply poor contact between the cart and console. Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted June 15, 2018 Share Posted June 15, 2018 When you changed the pin connector I will assume it was a used one and original at that. You are not going to get the results you want. Anyhow when you changed it did you clean the board pins extremely well? In my opinion cleaning the actual board pins the connector slides onto is just as important as changing the connector itself. I use to use brasso on them and then coat w/deoxit gold as that was the only way to get a connection that yielded excellent results. I have since just went back to rubbing alcohol and new pin connectors as they kind of dig into the pins better, but it still doesn't yield better results than brasso and deoxit gold.. Fact is the cleaner you get the board pins the better results you will get. I always juts pop the lock-out out of the chip myself, that is not your problem here though. Quote Link to comment Share on other sites More sharing options...
Gamemoose Posted June 15, 2018 Share Posted June 15, 2018 How squeaky clean are your carts? It probably doesn't need saying but scrub. Those. Carts! I try to take the carts apart and rub with a clean eraser and then some iso alocohol or a shot of electrical contact cleaner to take off any rubber residue. That reminds me...I haven't done that to MY carts in a while.... Quote Link to comment Share on other sites More sharing options...
Tanooki Posted June 15, 2018 Share Posted June 15, 2018 I think most of us havent cleaned games in awhile. Theres just so many. Im about keeping the original connector and rehabbing it to like new and off works. Book the funk off wash rinse repeat. Any wonky compressed pins safety pin them up before hand. It doesnt fail with a reasonably clean game or better Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted June 15, 2018 Share Posted June 15, 2018 For my NES with a new connector, I don't have to push the cart down for it to play games. I've had it for a while and since I don't use it much, the connector still isn't broke in. Quote Link to comment Share on other sites More sharing options...
Jason_Atari Posted June 16, 2018 Author Share Posted June 16, 2018 (edited) Carts are clean, board connector is clean, same games and connector is 100% working on another NES. Edited June 16, 2018 by Jason_Atari Quote Link to comment Share on other sites More sharing options...
0078265317 Posted June 16, 2018 Share Posted June 16, 2018 A game genie works for me every time. Makes the contact better. Only way to connect sometimes. Quote Link to comment Share on other sites More sharing options...
mobiusstriptech Posted June 17, 2018 Share Posted June 17, 2018 Have you checked the capacitors on the board and in the power/RF box? They are well known for leaking at this point. Quote Link to comment Share on other sites More sharing options...
DJ Clae Posted June 21, 2018 Share Posted June 21, 2018 Sounds pretty typical. Maybe replace the connector with Blinking Light Win. Quote Link to comment Share on other sites More sharing options...
