+OLD CS1 Posted June 21, 2018 Share Posted June 21, 2018 I need to mass convert a bunch of PC files to DF/128. TI99Dir only does one file at a time and I tried using DM2K in Classic99 with appropriate DSK devices settings but I get a error reading the source. I am sure someone has a quick and easy way to do this. Right? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 21, 2018 Share Posted June 21, 2018 I need to mass convert a bunch of PC files to DF/128. TI99Dir only does one file at a time and I tried using DM2K in Classic99 with appropriate DSK devices settings but I get a error reading the source. I am sure someone has a quick and easy way to do this. Right? tipi works great for this Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 21, 2018 Share Posted June 21, 2018 I had to fix the import in TIImageTool for binary DF128 import, but it works now. However, you have to do two clicks with your mouse per file. tiimagetool.zip Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 21, 2018 Author Share Posted June 21, 2018 I had to fix the import in TIImageTool for binary DF128 import, but it works now. However, you have to do two clicks with your mouse per file. It works, thank you. It sucks for 257 files, but it works. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 21, 2018 Share Posted June 21, 2018 Please verify with some of the imported files that everything has been imported correctly. If it is good for two or three files from your set, the rest should be OK as well. It sucks for 257 files, but it works. You know the typical support forum comments on this? SRLY? 257 files? Really mad. You should definitely not import so many files. How should anyone know there is someone with so many files? This software is not intended to work with imported files. You know that every import will make it worse. Importing is a dead end. It will bite you sooner or later, and you will remember my words. If you want to do so, stay with Windows. Glad to hear it works. 4 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 21, 2018 Author Share Posted June 21, 2018 Please verify with some of the imported files that everything has been imported correctly. If it is good for two or three files from your set, the rest should be OK as well. I will be able to test here shortly and will report. You know the typical support forum comments on this? SRLY? 257 files? Really mad. You should definitely not import so many files. How should anyone know there is someone with so many files? This software is not intended to work with imported files. You know that every import will make it worse. Importing is a dead end. It will bite you sooner or later, and you will remember my words. If you want to do so, stay with Windows. Glad to hear it works. Seriously underrated post. Quote Link to comment Share on other sites More sharing options...
Tursi Posted June 21, 2018 Share Posted June 21, 2018 PC files already are DF128 - by default that's the format they'll be stored as if received via XMODEM without any header. Sounds like you've already solved your problem, but as always, if Classic99 is throwing a disk error you don't understand, the log should provide some input as to why. Reading PC files directly under Classic99 is supported but can be tricky since it will try to do text files differently by default. Quote Link to comment Share on other sites More sharing options...
