Atari 2600 50Hz PAL: 242 or 228 picture lines?
PAL Atari 2600
4 replies to this topic
#1 Dionoid OFFLINE
Dionoid
    Chopper Commander
  • 111 posts
Posted Thu Jul 5, 2018 5:53 AM
In Session 7 of "Atari 2600 Programing for Newbies" I learned that 50Hz PAL has up to 242 lines of actual picture.
However, the Stella Programmer's Guide says to use 228 picture lines when doing a conversion from NTSC to PAL (see screenshot below).
Which one would make most sense to use? I guess when converting an NTSC game to PAL50, it would be even easier to use 192 visible scanlines (just like NTSC) and increase the number of lines in VBLANK and OVERSCAN accordingly. Or would that cause issues? (other than not using the full screen estate).
Are there any best practices to follow when creating a game that should run on NTSC, PAL60 and PAL50?
#2 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,499 posts
  • Medieval Mayhem
Posted Thu Jul 5, 2018 12:35 PM
In the world of CRT based televisions you need to be concerned with things like Safe Area.  Older TVs, like in the 70s when these guidelines for the Atari were established, had a lot of variation so the safe area was smaller.  Newer CRTs are much better, so you can safely increase the size of the safe area.  I recall a utility was written to test how many scanlines people could see, but my search has fallen short - somebody else might recall more about that.
For NTSC 192 was recommended back then.  My games vary from 182 to 202 based on the needs of my game (Draconian needed more time for game processing so only used 182 for the game screen).
#3 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 409 posts
  • Whackadoo thingamajig
Posted Thu Jul 5, 2018 4:46 PM
This is probably it.
#4 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,499 posts
  • Medieval Mayhem
Posted Thu Jul 5, 2018 6:54 PM
Yep!
#5 Dionoid OFFLINE
Dionoid
    Chopper Commander
  • 111 posts
Posted Tue Jul 10, 2018 3:55 PM
Exactly the information I was looking for. Thanks @SpiceWare and @TheHoboInYourRoom !
Also tagged with one or more of these keywords: PAL, Atari 2600
