Swami Posted July 9, 2018 Share Posted July 9, 2018 I've read a couple places that when using the diagnostic cart for controller testing, that you can use a Masterplay interface in place of the loop-back board. The loop-back board plugs into all four (or two) ports. Do you just plug the Masterplay interface into port 1 and start the tests, or is there variation from the Field Service Manual flow chart. Does the Masterplay only test one port at a time? Otherwise, can you just plug in the controller in question into port 1 and adjust the pokey/controller using the manual selection of pokey adjust from the diagnostic cart menu? Edit: I figured this out through trial and error. You can just plug in the Masterplay/controller and test it, although game results after making controller/pokey adjustments with the cart are not that great, at least for the more finicky games, although it is probably helpful if calibration is way off. Quote Link to comment Share on other sites More sharing options...
