AT/XT USB Keys v1.0 working
5 replies to this topic
#1 Shift838 OFFLINE
Shift838
  • 2,585 posts
  • SHIFT838
Posted Fri Jul 27, 2018 1:48 PM
I have finished the first build to of the AT/XT USB Keys PCB and it works great on my Geneve (with the XT code).
The PCB is only loaded with code for XT keyboards and uses the same exact code JediMatt42 compiled for his USB Keyboard for the Geneve 9640.  Eventually this unit will be allow to select between XT or AT Keyscan codes, but it's not there just yet hopefully soon.
It was designed from JediMatt's original design for his TI-99 USB Keys HERE and  followed by his USB Keyboard for the Geneve 9640 HERE which uses the same board but different code.
The modifications that I made was:
  • Added a jumper to select between AT and XT keyboards for future version of the code (suggested by JediMatt42)
  • Used a 5 pin MIDI connector to connect the keyboard to the Geneve 9640 or SNUG system (SNUG uses AT Keyscan codes) instead of header pins
  • Removed other header pins that are not used on Geneve or AT systems to help reduce the size of the board.
The unit has been designed to fit into the standard Hammond 1591XXL.  So only some cutout holes would need to be made, but it mounts directly to the enclosure.
The pictures show mine on header sockets.  I did that just in case I needed to pull something off to perform troubleshooting.
Since it uses a Teensy Microcontroller and USB Host controller the cost of the product to be built and tested is going to be more than the SCART-Genies.
The upside is as new code is released it is easily re-programmable in just a few seconds and of course the ability to use USB keyboards.
I have not decided on the price.  But the Parts and PCB alone cost $50. (enclosure will not be included).
I could even sell them as a kit minus the enclosure, Teensy and USBHost to reduce the cost and the buyer could source the remainder parts.
Feel free to chime in.
Edited by Shift838, Fri Jul 27, 2018 2:02 PM.
#2 Schmitzi OFFLINE
Schmitzi
  • 4,536 posts
  • ToXiC
Posted Sat Jul 28, 2018 12:36 AM
Great stuff ! Should I say or do you know that I am in ? ;)
And, I really like the implemented AtariAge-logo here:
Attached File  AA-USB-Logo.JPG   74.07KB   3 downloads
#3 Nick99 OFFLINE
Nick99
    Star Raider
  • 97 posts
Posted Sat Jul 28, 2018 4:15 AM
I'm I right thinking this will let me connect an USB keyboard to the Geneve without anything else but a midi cable and this USB device?
If so I´m in for a complete device..
#4 jedimatt42 OFFLINE
jedimatt42
  • 2,022 posts
Posted Sat Jul 28, 2018 8:40 AM
I've been slowly working on the firmware to support PS2/AT keyboard mode as well.. The XT code is very stable, I've been using it for a long time now.
This PCBoard design is a nice improvement over my previous board. Shift838 put forethought into the size and shape.
Great job! Love it!
-M@
#5 Shift838 OFFLINE
Shift838
  • 2,585 posts
  • SHIFT838
Posted Sat Jul 28, 2018 9:05 AM
Yes, a USB keyboard will work on a Geneve.
#6 Shift838 OFFLINE
Shift838
  • 2,585 posts
  • SHIFT838
Posted Sun Jul 29, 2018 12:58 PM
if anyone want's a pre-order kit (I need to order usbhost and teensy units). PM me and we can work out the details.
