HDTV1080P Posted August 1, 2018 Share Posted August 1, 2018 (edited) Internally modifying ones TI-99/4 and TI-99/4a computer so that it offers native HDMI, VGA, RGB, component video, or S-Video, is better than using composite video, or RF channel 3 and 4. However for various reasons one might want to use the legacy composite video output that does offer a better picture and sound quality when compared to RF channel 3 and 4. Cables Online has released a couple of high-end composite video/audio cables for the Texas Instruments computers These high-end Cables Online cables are 100% compatible with the TI-99/4 and TI-99/4a computers. This is a high-end cable with shielded wires, one end of the cable uses a metal neutrik connector with all 5 pins on the DIN connector being gold plated, the second end of the cable uses two metal RCA connectors with yellow for video and white for audio (RCA connectors are gold plated). When the white RCA connector is connected to the left audio input jack on a stereo TV/monitor, 99% of stereo TV/Monitor’s will internally split the mono audio signal to both speakers. On the rare 1% of stereo TV/Monitors from the 20th Century that do not internally split the mono audio to both speakers when a cable is plugged into the left audio input, this 53 cent gold plated RCA plug splitter can be plugged into the back of ones stereo TV/monitor to hear mono audio out of both speakers. (1 ) The high-end 6 feet Cables Online ADX-506 composite video cable with audio for the TI-99/4 and TI-99/4a computer is now $24.95 plus free shipping. (2) The high-end 6 inch Cables Online ADX-300 Audio/Video adapter cable for the TI-99/4 and TI-99/4a is now $20.95 plus free shipping. This ADX-300 cable ended up being the best quality composite video option when used with two high-end RG-6 double shielded cables (one RCA cable for video and one RCA cable for audio). High quality RG-6 cable with two RCA connectors on each end can be purchased directly from Monoprice in lengths between 3 feet and 100 feet (Monoprice offers a lifetime warranty on this quality cable). I tested this ADX-300 cable over a 100 feet connection using RG-6 cables and the picture and sound quality at 100 feet was excellent (3 feet slightly better picture then 100 feet). The purpose of the ADX-300 cable is that it allows consumers to have their Texas Instruments home computer connected to any length of RG-6 cable between 3 feet and 100 feet in length. Edited August 1, 2018 by HDTV1080P 1 Link to comment Share on other sites More sharing options...
HDTV1080P Posted August 13, 2018 Author Share Posted August 13, 2018 (edited) One day all classic 70’s and 80’s videogame and computer systems well need a native HDMI output When computer monitors and TV’s break most consumers end up purchasing a new model if the display is 10+ years old instead of getting the display repaired. And sometimes even if one wants to get the display repaired it is not possible to get the display repaired because the parts needed to repair the circuit board went out of production and can no longer be found in stock from parts supplies . Therefore, the reality is consumers always end up with new models of electronics for various reasons. Around 3+ years ago, I mentioned that all desktop computer monitors in production have only a digital HDMI input and sometimes also digital Displayport input (but no analog video inputs at all on desktop computer monitors). The work around to the issue was consumers instead were purchasing flat panel TV’s and projectors that offered both HDMI and analog video inputs. Around the year 2010 the S-Video jack was removed from all new displays and A/V receivers. Therefore, consumers have gone through 8 years of TV models that no longer offer 480i S-Video jacks. But in general back in 2015 (much less true in 2018), flat panel HDTV’s especially the higher-end models came with at least one component video input good for 480i, 480p, 720p, 1080i, and sometimes 1080p resolution, at least one 480i composite video input, and a RF input that worked with NTSC/ATSC/QAM signals (basically everything except the S-Video input). However, in the year 2018 new models of displays are changing rapidly. Normally the high-end top of the line models of HDTV’s well have more input jacks when compared to lower end and lower priced flat panels. Displays can be made cheaper if they have no analog inputs or less analog input jacks on them. On some of the high-end top of the line 2018 LG OLED Ultra HDTV’s and some other HDTV’s on the market from various companies there is no longer any component video input jacks at all. What happen to S-Video back around 2010 is now happening to many 2018 Ultra HDTV’s when it comes to no longer offering analog component video inputs. Some of the 2017 or 2018 TV models that do still offer component video input require a special 3.5mm to RCA adapter plug to be used to feed component video into the display. Now the latest 2018 LG Ultra HDTV’s still have the legacy 480i composite video feature but to use that feature a special 3.5mm to RCA composite video adapter needs to be used. So at least on the 2018 models from LG and some others, composite video input is possible with the correct adapter connected. Also LG still makes RF tuners that handle a channel 2, 3, and 4 NTSC modulated video and audio signal from a classic 70’s and 80’s videogame and computer system (but that well not be the case in the future). Looking at the specs for this year’s 2018 high-end Samsung Ultra HDTV that cost around $2,800, there is no analog video inputs at all, not even the legacy 480i composite video inputs. To make matters worse Samsung has dropped the NTSC feature from their built in tuners according to the spec sheets I was looking at. In reality for over a decade all full power TV stations in the United States have been broadcasting in digital ATSC. In addition, all or most all Cable TV companies are now 100% QAM with no more NTSC channels. So it’s very logical to not offer analog NTSC tuners in all new TV’s and instead only offer 100% ATSC/QAM tuners. However, there are some consumers that have videogame systems, computer systems, and VCR’s from the 20th Century that need a RF input with a NTSC tuner built in. Yes, one can purchase a digital ATSC RF modulator with both a HDMI input and a composite video input but the problem is those ATSC RF modulators cost around $895 (ATSC RF modulators one day in 5-10+ years might cost under $100 when all future TV tuners in 2020+ only offer ATSC/QAM and drop the NTSC feature). NTSC RF modulators that sale for around $20 or $30+ well become useless non-compatible item when connected to a new flat panel TV that only offers ATSC/QAM tuners. One needs to really hunt to find a 2018 TV that has all three of the following features on a flat panel: component video, composite video, and analog NTSC. What all or most 2020+ flat panels TV’s well have in regards to input jacks (say goodbye to NTSC RF that ColecoVision, ATARI, and other people have used over the decades) Because of inflation and because manufactories are looking to produce flat panels and projectors at cheaper prices. Most likely somewhere around 2020+ all or most flat panels including the top of the line Ultra HDTV models well no longer offer any component video inputs, no longer offer composite video inputs, and no longer offer NTSC RF tuners (And this is starting to happen on the latest top of the line models in 2018). Also in the future with the new ATSC 3.0 standard we are looking at all new built in TV tuners to be exclusive ATSC/ATSC 3.0/QAM models with no NTSC feature offered (again NTSC not needed since all or most cable TV companies have converted to QAM) and full power broadcast TV stations have been 100% ATSC for over 10 years. What this means is on all or most 2020+ flat panel TV’s and projectors, the only way one is going to be able to connect their classic 70’s and 80’s videogame and computer system is if they externally or internally modify it to have a HDMI output (some systems have expansion module interfaces that would allow a hardware developer to make a native external HDMI graphics card for their favorite videogame and computer system). Now there is 480i composite video to HDMI converter boxes on the market for around $14.99 but that is not as good as solution as having a native HDMI output. There is also the issue of classic 1982 ColecoVisions, and 70’s videogame systems from ATARI and others that only have a RF output. If one is going to have to modify their classic videogame system for composite video so that they can use an external composite video to HDMI adapter, it is much more logical to just go in and remove the RF NTSC modulator and install a HDMI output on all the classic 70’s and 80’s videogame and computer systems that cannot have native HDMI output from its expansion interface (some videogame systems like the ATARI 2600, 5200, and many others do not have an expansion module interface). Edited August 13, 2018 by HDTV1080P 1 Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 13, 2018 Share Posted August 13, 2018 Stop cross-posting. There is a parent forum here where you can post this, or even in the market place since you are obviously hawking products in your multi-forum cross-posts. You are getting a dangerously close to a mass report and this is your only warning. If you want to participate with our community, fine, but this kind of activity is not wanted and a violation of AtariAge policy. 10 Link to comment Share on other sites More sharing options...
