emarti Posted August 1, 2018 Share Posted August 1, 2018 Hi, I coded simple basic lines. I want to save it into ATR image via Sio2Arduino. I attached "EMPTY.ATR" for D1 drive. 10 REM **** SAMPLE **** 20 PRINT"ATARI" 30 END SAVE"D1:SAMPLE.BAS" Returns "ERROR 130". How to do? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted August 1, 2018 Share Posted August 1, 2018 Hi, I coded simple basic lines. I want to save it into ATR image via Sio2Arduino. I attached "EMPTY.ATR" for D1 drive. 10 REM **** SAMPLE **** 20 PRINT"ATARI" 30 END SAVE"D1:SAMPLE.BAS" Returns "ERROR 130". How to do? Error 130 means "device not present". You will need to load a DOS before being able to save to disk. 1 Quote Link to comment Share on other sites More sharing options...
emarti Posted August 1, 2018 Author Share Posted August 1, 2018 (edited) Ok. I loaded DOS2.5. How to return from DOS to BASIC without RESET? Edited August 1, 2018 by emarti Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 1, 2018 Share Posted August 1, 2018 (edited) If the image is empty you need to load DOS then write it to the empty disk, Init, then write DOS select the run cartridge option from the 2.5 menu that takes you to basic type DOS while in basic takes you back to DOS menu make sure mem.sav is active and if using 130XE or expanded memory computer you can use ramdisk to speed up the process Edited August 1, 2018 by _The Doctor__ 4 Quote Link to comment Share on other sites More sharing options...
emarti Posted August 1, 2018 Author Share Posted August 1, 2018 (edited) Ok I got it. I wrote dos files into ATR image with H. I can save it, now. Thank you Stephen Edited August 1, 2018 by emarti 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 1, 2018 Share Posted August 1, 2018 (edited) and that choice is usually B on most DOS menus if you are using XL XE do not press option during boot, if using and 800 or 400 make sure basic cart is plugged in... in this way BASIC is available to move freely to and from Edited August 1, 2018 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
emarti Posted August 1, 2018 Author Share Posted August 1, 2018 and that choice is usually B on most DOS menus Thank you _The Doctor__. 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted August 4, 2018 Share Posted August 4, 2018 Ok. I loaded DOS2.5. How to return from DOS to BASIC without RESET? Just type DOS (if you have it loaded). Quote Link to comment Share on other sites More sharing options...
