Install USB Drivers for Harmony Cartridge
harmony drivers Harmoiny Cart not found
2 replies to this topic
#1 mceiras OFFLINE
mceiras
    Combat Commando
  • 2 posts
Posted Tue Aug 14, 2018 11:01 PM
Hi! I´m using Windows 10 Pro 64 bits version.
My Harmony Program Tool can´t found the Harmony Cartridge :(
I install the drivers and apparently everything worked perfectly.
The virtual com port have the following setup:
But the harmony Programming Tool continued not finding the harmony cartridge  :thumbsdown:
The only problem in Device Manager is the following:
When I insert the USB cable into the Harmony cartridge I hear the Windows characteristic sound that something has been inserted into a USB port.
What can I do ?  :?
best regards and thanks in advanced,
Marcelo
What can I do ?
Edited by mceiras, Tue Aug 14, 2018 11:13 PM.
#2 OldSchoolRetroGamer OFFLINE
OldSchoolRetroGamer
  • 5,569 posts
  • aka MaximumRD !
Posted Tue Aug 14, 2018 11:21 PM
If i am understanding correctly THESE are the drivers required for Windows 64 bit http://www.ftdichip....L Certified.zip
As linked to / mentioned in this thread : http://atariage.com/...e/#entry1920256
You certainly lose nothing in attempting to install them. Otherwise I can only suggest you try a different USB cable or port on your PC.
#3 MMarcoux66 OFFLINE
MMarcoux66
    Star Raider
  • 85 posts
Posted Wed Aug 22, 2018 3:31 PM
Having the exact same issue. Machine sees the card but the software does not. Hope someone can figure this out. Even FT Prog sees it.... Windows 10 x64 and tried a Windows 7 x86.
Also tagged with one or more of these keywords: harmony, drivers, Harmoiny Cart not found
