p1FqO3 Posted September 4, 2018 Share Posted September 4, 2018 I know Sega Genesis controllers can be used with a 2600. But, could the Atari Paddle and/or Driving controllers be safely connected to a Genesis? Could a game be programmed to utilize them? Has it been done? I love spinner controlled games, but there's only so much that could be done on a 2600, I wonder what could be done with next gen hardware. Quote Link to comment Share on other sites More sharing options...
Video Posted September 5, 2018 Share Posted September 5, 2018 Well the driving controller is just a variant of joystick, turning the wheel just plays a pattern of two joystick directions, so no reason a game couldn't be programmed to read it. Paddles on the other hand basically have a volume. One direction is louder, the other is softer. If the genesis can read analog, there's no reason a game couldn't read it, but I don't know if the genesis reads analog. 1 Quote Link to comment Share on other sites More sharing options...
Supergun Posted September 5, 2018 Share Posted September 5, 2018 Yes, the Sega Genesis / Mega Drive can read analog controls. One example is the famous XE-1AP analog controller by Dempa for use with & compatible with After Burner, Galaxy Force, and a few other games. 1 Quote Link to comment Share on other sites More sharing options...
Swami Posted September 5, 2018 Share Posted September 5, 2018 The driving controller puts out binary quadrature, so it would have to be able to read that on pins 1 and 2, unless you re-wired them to other pins - with the same story. I'm not really sure what the B and W stand for in this schematic: http://www.atariage.com/2600/archives/schematics/Schematic_2600_Accessories_Low.html The paddles are on pins 5 and 9, but 5 is the +5V VCC on a Genesis, so you would need to rewire the paddle ouput to another genesis pin, and 9 is a Fire button, so same thing. Although, you could program any fire button or joystick direction to do anything in a new game. I'm not sure if you would have to switch the paddle contacts around, like you do for the 2600, or not. 1 Quote Link to comment Share on other sites More sharing options...
TheHoboInYourRoom Posted September 5, 2018 Share Posted September 5, 2018 I'm not really sure what the B and W stand for in this schematic: http://www.atariage.com/2600/archives/schematics/Schematic_2600_Accessories_Low.html Blue and White, referring to wire colors. Pins 1 and 2 on the driving controller correspond to up and down on both the Atari joystick and the Sega d-pad, so there's absolutely no reason the Genesis couldn't read the Gray code. Since the two consoles have the power supply on different pins, though, it would be safest to have a little plug adapter that swaps pins 7 and 9 plugged into the console, with the foreign controller plugged into the adapter. 1 Quote Link to comment Share on other sites More sharing options...
zylon Posted September 9, 2018 Share Posted September 9, 2018 The SMS or MKIII had a paddle control. http://www.smspower.org/Development/Paddle Quote Link to comment Share on other sites More sharing options...
Torr Posted September 18, 2018 Share Posted September 18, 2018 The SMS or MKIII had a paddle control. http://www.smspower.org/Development/Paddle Now the question is: Can an Atari Paddle Controller be used in place of the SMS/Mark III Paddle Controller? Probably not easily I'm guessing. Quote Link to comment Share on other sites More sharing options...
TheHoboInYourRoom Posted September 18, 2018 Share Posted September 18, 2018 Blue and White, referring to wire colors. Pins 1 and 2 on the driving controller correspond to up and down on both the Atari joystick and the Sega d-pad, so there's absolutely no reason the Genesis couldn't read the Gray code. Since the two consoles have the power supply on different pins, though, it would be safest to have a little plug adapter that swaps pins 7 and 9 plugged into the console, with the foreign controller plugged into the adapter. "...plug adapter that swaps pins 7 and 5..." What was I thinking, the post I quoted even said the Genesis uses pin 5 for power. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted September 18, 2018 Share Posted September 18, 2018 The Genesis has a "mega mouse" too, but I'm not sure how it works. It probably isn't anything terribly complicated, though. It seems reasonable to assume that a driving controller could be used in place of one axis on the mouse. Quote Link to comment Share on other sites More sharing options...
