curtludwig Posted September 18, 2018 Share Posted September 18, 2018 Hello all, I've had my TI for about 35 years now, its part of the reason I learned to read, and type for that matter. Sometime in the late '90s I bought a literal pickup truck load of TI stuff... Anyway recently I got bit by that old bug and picked up a TIPI, RPI and 32k RAM expander and I've been bashing my head against the wall for almost a week now. To be honest there is exactly 1 thing I want to do, play Tunnels of Doom without waiting 200 seconds for the cassette to load or dragging out the PEB. So far I'm having no luck. I've gotten a couple of basic programs I downloaded to work (Hero and of course RPS) but none of the editor/assembler things. Finally I tried writing some basic programs and saving that to the TIPI, I figured if I could get that to work I could load TOD from tape one more time and save to TIPI but alas no luck. Looking around the stuff I see assumes you already know something. I need TIPI for the complete idiot... Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 18, 2018 Share Posted September 18, 2018 Ok I assume you can load and save to TIPI.XXX from basic no? Take this dsk image and copy it to your tipi via the web interface or file share.. web interface is HTTP://TIPI:9900 on any PC on the lan that your TIPI is connected too. This should automatically create a directory called TOD under tipi..so that would be TIPI.TOD.XXXX for the files on the disk.. on the disk you will find these tunnells of doom games ASSAULT DOCTOR K-MART ORBS PENNIES QMMD QUEST SPACE/M STREK TOMB the stock ones are PENNIES and QUEST stick the TOD cart in your TI.. select 3 and type TIPI.TOD.PENNIES That should get be going.. follow this pattern for the other games.. enjoy ALSO: this disk contains the module and a xb loader so you could map DSK1. on TIPI to TOD and just load from extended basic.. Greg Tod.dsk Quote Link to comment Share on other sites More sharing options...
curtludwig Posted September 21, 2018 Author Share Posted September 21, 2018 Hi Greg, thanks for the reply. I've been able to put some basic and xbasic programs on the TIPI and load them but never anything that used Editor/Assembler and I've never been able to save from the TI to the TIPI. I was with you right up until "This should automatically create a directory called TOD under tipi" which it doesn't instead I see: I was under the impression TIPI wouldn't work with DSK files, certainly I've never gotten it to do anything with one. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 21, 2018 Share Posted September 21, 2018 Hi Greg, thanks for the reply. I've been able to put some basic and xbasic programs on the TIPI and load them but never anything that used Editor/Assembler and I've never been able to save from the TI to the TIPI. I was with you right up until "This should automatically create a directory called TOD under tipi" which it doesn't instead I see: I was under the impression TIPI wouldn't work with DSK files, certainly I've never gotten it to do anything with one. have you updated the software on your TIPI? CALL TIPI and if it says press U to upgrade at the top.. do that if you are already on version 1.0betav027 then let me know.. dsk auto-unpack to a folder was added around version 025 or so Greg 2 Quote Link to comment Share on other sites More sharing options...
curtludwig Posted September 21, 2018 Author Share Posted September 21, 2018 That got it, thanks Greg! 2 Quote Link to comment Share on other sites More sharing options...
jonecool Posted October 3, 2018 Share Posted October 3, 2018 Sorry a little late seeing this post. Not sure if you've already figured all this out or not, but perhaps this video I made a few months back may be helpful to you. 1 Quote Link to comment Share on other sites More sharing options...
