HRD (Horizon Ramdisk) 2018
134 replies to this topic
#51 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 6:32 AM
Super! I can't wait to check it all out!! I can't thank you enough Barry ! I'll keep you posted.
#52 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Tue Oct 30, 2018 6:44 AM
I'm, um, not Barry. Just a guy who spent way too much time troubleshooting broken HRD+ units.
Sent from my Pixel 2 XL using Tapatalk
#53 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 6:59 AM
ooops....I really was expecting Barry to respond with that same info as he had posted earlier..BUT Im super excited for the response Mr Wiley! well see if the RAMDRIVE will live again!
#54 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 7:07 AM
Oh, I have this and was told that it's not for this drive, that this drive is actually a 1000.
#55 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Tue Oct 30, 2018 7:31 AM
It is the right schematic. The HRD+ is a HRD with a lot of Frankensteining. You'd be better off following this document and correcting the wiring to match it. It's a pain in the arse but there's a reason that the HRD+ was built using the PCB.
#56 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 7:59 AM
Yes I did this previously, and found, as in my previous comments, the three stacked 138s do not work as this schematic describes. BUT they work as wired in the photo, unlike this schematic. This is the reason for the post, and in previous comments explained not to use this schematic, and Someone named Barry had replied that the card was an early board 1000 and is different from the 2000 and 3000 layouts as this schematic was. But yeah I started off using this months ago and got nowhere. Now I'm able to turn the card on/off as I rewired it back the way received it originally. The reason for changing it was that the card was intermittent and I was told by Gary Opa that the problem AT that time was related to the 3 stack so I rewired it as these instructions. But it was worse, the card never responded. Thanks
#57 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Tue Oct 30, 2018 9:14 AM
There's a lot more that needs to be rewired (thinking specifically of the 259 stack, but the 138s and the 254s are going to be wrong too), and there's probably a cut trace that needs to be restored between the fingers and the rest of the card.
Seriously, please take it from one who fixed a HRD that matched no known wiring diagram into a stable HRD+ testbed that I used for prototyping OSHPark boards to eliminate stacking and bring it up to a minimum of 2 meg. Make it look like the instructions; there's a reason they switched from HRD wiring to HRD+. Treat it like a fresh build with all the parts present and you're just touching up bad solder joints and flywires icon_smile.gif
#58 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 9:42 AM
Hmm. I understand. But I did my best to follow these. I replaced the 3 stack and I replaced the 259 two stack with new parts, I wired as schematic and I never got a data light after loading cru >1000. So I reverted. Now I can turn the card on/off. I just now don't know why the ram won't allow writes. This is where I'm stuck.
#59 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Tue Oct 30, 2018 9:53 AM
Look very, very carefully at the underside of the board near the card interface for cut traces. Use a multimeter if you want to be certain.
#60 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 10:09 AM
Not seeing any
#61 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 10:12 AM
Not seeing any- i also ohm'd them out JUST to make sure! Do you want a photo  of the 138 stack and the 259 stack?
Edited by GDMike, Tue Oct 30, 2018 10:20 AM.
#62 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 10:31 AM
No cut traces
#63 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 10:40 AM
I've attached some pictures
#64 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Tue Oct 30, 2018 9:52 PM
Hmmm. Offhand I'd start with some desoldering wick and refresh every single solder joint on the card. After 40 years you're going to have at least five bad ones. Those flying wires look pretty marginal too. Might as well treat this as a restoration project rather than a break/fix.
#65 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Tue Oct 30, 2018 9:56 PM
Yep...I think I have no choice now. There are bad spots on all junction ports too.
#66 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Wed Oct 31, 2018 3:47 PM
I've laid out what I have...
Edited by GDMike, Wed Oct 31, 2018 3:48 PM.
#67 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Thu Nov 1, 2018 3:14 AM
Yep, that's the board that's covered by the HRD+ doc I put up. If you've got a TL866, you can pull each chip except for the soldered stacks and do a logic test for everything except the '245s I think.
What I ended up doing was desoldering everything except the RAM, replacing all the DIP sockets with machined sockets, and swapping the dead '154 with a small circuit board that incorporated a SMD CMOS '154 (the DIP is only NOS AFAIK).
That was the first iteration. When I return from this deployment, I'll visit the ex, grab the board, and send photos. All of my stack replacements and RAM plugin are available on OSHPark.
#68 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Thu Nov 1, 2018 4:33 AM
No, unfortunately I can't test those. But I will swap out all that I can, caps, resistors v regulator, diodes etc..
#69 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Thu Nov 1, 2018 6:02 AM
I like your layout pics.
#70 Ksarul OFFLINE
Ksarul
  • 5,021 posts
Posted Thu Nov 1, 2018 6:19 AM
I have plenty of new-manufactured 154s. Rochester Electronics still produces them on demand, and I bought about 1,500 of them (the minimum order) a couple of years ago. Mine are the .300 width chips, not the wider, .600 style.
#71 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Thu Nov 1, 2018 6:42 AM
Thanks and good to know.
#72 wileyc OFFLINE
wileyc
    Chopper Commander
  • 119 posts
Posted Thu Nov 1, 2018 8:51 AM
There's a really neat way to take the 154s out of the equation entirely. Basically what you do is get a couple of the right size SRAMs, wire the 154 chip select from the 259 stack into the CE of each SRAM, and run the synthesized address lines in. I'll post schematics when I return from this deployment.
#73 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Thu Nov 1, 2018 1:46 PM
With everything out, what are the chances of making a larger drive? Could I use this board in achieving that?
#74 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Thu Nov 1, 2018 1:48 PM
#75 GDMike OFFLINE
GDMike
    Star Raider
  • 86 posts
Posted Thu Nov 1, 2018 5:26 PM
Power section cleaned
