ST/Amiga Mouse adapter for Jaguar Gridrunner & Defender of the Crown
74 replies to this topic
#26 Lynxpro OFFLINE
Lynxpro
  • 3,741 posts
Posted Mon Oct 29, 2018 4:17 PM
Now if someone could do an adapter to use the Atari 5200 CX53 Trak-Ball in the place of the ST Mouse, I'd buy that in a heart beat...  Imagine Crack'ed being ported and getting to play that sucker with a Trak-Ball instead of a mouse. Or even ST Missile Command...  :)
Awesome work nonetheless.
#27 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Fri Nov 2, 2018 9:54 AM
Aha! But they might not always in the future!
ST wiring will likely be the safest choice.
It does sound like the most sensible choice but do you know for sure?
I now have the adapter and no mouse yet. There's no original ST mice on the bay at the moment but there are Amiga mice. I may have to go for the Amiga unless anyone knows of an ST one that's available?
#28 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Fri Nov 2, 2018 1:58 PM
I was just talking shit, man :)
I'm sure you'll be fine with an Amiga mouse.
#29 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Fri Nov 2, 2018 3:36 PM
Cool bananas. I've just gone for a refurbished Amiga mouse. Since I have a CD32, I'm hoping to make use of it that way too. First stop though is Impulse X.
Edited by Guitari, Fri Nov 2, 2018 3:37 PM.
#30 kurtori OFFLINE
kurtori
    Chopper Commander
  • 118 posts
  • Gamer By Trade
Posted Mon Nov 5, 2018 10:40 AM
I received my adapter over the weekend and confirmed it works great with Elansar (cartridge version) and Griddunner! Looking forward to trying it with Defender of the Crown!
I have the ST Star Wars on a homemade cart, and thoigh the mouse was recognized, I couldnt get it to calibrate; the movement of the reticule were erratic and appeared to almost be in multiple places at once. Not sure if there is a way to change that.
Edited by kurtori, Mon Nov 5, 2018 10:41 AM.
#31 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Mon Nov 5, 2018 11:31 AM
Were you using an ST or Amiga mouse?
#32 kurtori OFFLINE
kurtori
    Chopper Commander
  • 118 posts
  • Gamer By Trade
Posted Mon Nov 5, 2018 1:20 PM
Im using an ST mouse.
#33 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Mon Nov 5, 2018 6:48 PM
Hmmm. Sounds like a question for CJ then.
#34 CyranoJ OFFLINE
CyranoJ
    RAPTOR Wrangler
  • 5,870 posts
  • reBOOTed
Posted Tue Nov 6, 2018 1:53 AM
Should work fine, I've played that for hours 😀
#35 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Fri Nov 9, 2018 7:03 AM
No luck with this. I ordered a refurbished Amiga tank mouse and it fits fine. The problem is with the connection to the Jaguar, it's quite loose so the mouse buttons only work if I am constantly fiddling with the adapter.
The direction control of the mouse ball won't work at all. Same story with Impulse X CD and Gridrunner. Same story on two Jaguars also.
So I tried without the plastic half-housing, same story.
#36 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Fri Nov 9, 2018 8:14 AM
Sounds like the holes in your controller ports have been stretched.
Some controllers have thicker pins than others, I'd imagine this can make the controller ports loose over time.
#37 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Fri Nov 9, 2018 4:41 PM
Thank you but doubt that. Port 2 has barely been used. I have a third jaguar which has a brand new motherboard, I'll try that one too. The supplier of the mouse is certain it works correctly. I have no amiga to try it with.
#38 Zerosquare OFFLINE
Zerosquare
  • 2,791 posts
Posted Fri Nov 9, 2018 7:16 PM
It won't help with the buttons, but cleaning the rollers (remove the trap that holds the mouse ball) may help with the cursor movements.
Edited by Zerosquare, Fri Nov 9, 2018 7:16 PM.
#39 MacRorie OFFLINE
MacRorie
  • 1,046 posts
  • No matter where you go, there you are.
Posted Sat Nov 10, 2018 1:08 AM
Hmm, I test them out with my collection of mice/trackballs here, before they go out, so not sure what the problem could be.  Could have a cold solder, but there is not much to them. two connectors and a board. I have not had any problems with connection, I push it in, put the mouse/trackball on it and fire away.  No one has reported any problems, so this is a first.  I can send you another, if you are still having problems.
#40 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Sat Nov 10, 2018 2:17 AM
Thanks MacRorie / Zerosquare
I do have an Amiga! I have a CD32. I'm not too familiar with it so I need to explore the collection to see what I can use that uses mouse. Anyone know if it's port 1 or 2 on a CD32 for mouse?
The mouse was cleaned and tested on the inside before it was sent to me, although I'm having trouble accessing the ball, the cover is really tight.
The adapter did come apart when I removed it from the housing but I pushed the connectors back onto the board, still no luck. I'll give the CD32 a try and if the mouse is good then could I have a replacement adapter but soldered this time?
Edited by Guitari, Sat Nov 10, 2018 2:22 AM.
#41 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Sat Nov 10, 2018 5:34 AM
Update - I tried the mouse on my Amiga CD32 and it works fine! So the adapter must be faulty! Sorry!
#42 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Sat Nov 10, 2018 9:04 AM
The connectors weren't soldered to the board?
That sounds like a whoopsie!
If you can't solder them yourself, you could send it to me and I'll solder them in and send it back out to you. It's a 5 minute job and I'm in the UK so would likely be faster than sending a new one.
Wouldn't cost you anything other than postage to me.
#43 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Sat Nov 10, 2018 10:55 AM
Oh wow sounds great! Thank you, could you pm me your postal add?
#44 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Sat Nov 10, 2018 11:02 AM
No problem at all :)
PM sent.
#45 MacRorie OFFLINE
MacRorie
  • 1,046 posts
Posted Sat Nov 10, 2018 12:25 PM
Okay, THAT's not supposed to happen!  Sorry about that.  Not sure how that happened at all.  My most sincerest and humble apologies.  I will gladly send you a new one, just let me know if you want to do that or just solder it in. Again, deepest apologies, I must have grabbed one from the wrong pile when putting it in the envelope. I have a pretty strictly procedure I follow for orders, but obviously this one got through. SO sorry!
#46 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Sat Nov 10, 2018 1:12 PM
No worries. Let's see if Gummy can fix it and if not I'll let you know.
#47 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Wed Nov 14, 2018 4:40 AM
Soldered and on its way back.
#48 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Wed Nov 14, 2018 6:03 AM
Excellent, thank you, looking forward to it!
#49 Guitari OFFLINE
Guitari
  • 1,731 posts
Posted Thu Nov 15, 2018 9:01 AM
Got it back Gummy - thanks so much! However still no joy  :(  I get a shakey movement on the mouse config screen of Impulse X whereas before it was dead. But not moving now as it should. This is selecting both Amiga and ST mice.
I'll try on the other jaguars later but I can't see that'll help  :(
#50 Gummy Bear OFFLINE
Gummy Bear
    Dragonstomper
  • 883 posts
Posted Thu Nov 15, 2018 10:39 AM
It worked perfectly with Impulse X and Grid Runner with my ST mouse.
Hmm... I wonder what could be wrong.
I can tell you what's NOT wrong: the adapter.
