Moon Patrol - Arcade Sprite Hack (Call for Moon Buggy drivers!)
Atari 800 Atari XL Atari XE Moon Patrol Moon Patrol Arcade
127 replies to this topic
#26 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Fri Sep 28, 2018 10:21 AM
I found a .xex image which is patched:
#27 doctorclu OFFLINE
doctorclu
    ***Moon Patrol 5200*** *Moon Master2015* *Blue Max:Class 4*
  • 7,691 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Fri Sep 28, 2018 10:57 AM
Good... I'll add that in a directory in a MyDos 4.53 ATR... I get a error 146 when I try to load that.
"146 Function not provided by handler (OS ROMs) "
#28 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Fri Sep 28, 2018 11:50 AM
How about this? I found it here.
#29 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Fri Sep 28, 2018 11:52 AM
Pseudografx, Level42 just hit on something I was just starting to thinking about: The Mountains and cities.
I could try to find resources to draw out arcade screen shots of both, but it looks like you might already have a good handle on this.  Would you be up for helping us draw out the arcade backgrounds so we can modify the backdrop to look like that?
Won't be at the resolution you drafted, but it will really help this Arcade Moon Patrol really pop.  :D
I actually just used the graphics from the arcade version that is available here at AtariAge: http://atariage.com/...7800/?p=3424158
I could help with some graphics, but as for the bacgrounds, the resources are all in that picture :)
#30 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Fri Sep 28, 2018 12:08 PM
Oh... that is a great help!  :D
#31 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Fri Sep 28, 2018 12:20 PM
Here is the requested mockup for the city level.
As far as I know, all of this should be possible on a standard Atari, just not with the current binary, as I already noted.
#32 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,246 posts
Posted Fri Sep 28, 2018 12:21 PM
how about this one...
I trust in Drac030!
Attached File  moon-patrol-audiofix.arc   16.2KB   25 downloads
unarc and enjoy!
I have used this on all sorts of machines without issue.
Edited by _The Doctor__, Fri Sep 28, 2018 12:22 PM.
#33 pseudografx OFFLINE
pseudografx
    Dragonstomper
  • 758 posts
Posted Fri Sep 28, 2018 12:25 PM
I am also attaching a POKEY rendition of the ingame music. I used Miker's patched RMT for this so it won't play the same in the unpatched version.
Attached File  Moon_Patrol.xex   2.91KB   42 downloads
Attached File  Moon_Patrol-patch0a.zip   407bytes   26 downloads
#34 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Fri Sep 28, 2018 12:42 PM
Yeh, unarchived, but error 146 when I put it on a mydos image.   Could be the Atari800 image editor corrupting the executable.
#35 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Fri Sep 28, 2018 1:06 PM
Have you tried MAKEATR?
#36 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Fri Sep 28, 2018 2:27 PM
I'll give that a try.
#37 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Fri Sep 28, 2018 10:10 PM
So, does makeATR work?
#38 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Fri Sep 28, 2018 10:59 PM
Not much luck here and no much time for refining that.   If you can set up an ATR with the executables, preferably autoloading, that would be awesome.
#39 _The Doctor__ OFFLINE
_The Doctor__
  • 6,246 posts
Posted Fri Sep 28, 2018 11:50 PM
Maybe my copy corrupted, or it's been patched for 816 use... someone should just patch the one you already worked on. I will try to remembers it's only a couple bytes...
#40 _The Doctor__ OFFLINE
_The Doctor__
  • 6,246 posts
Posted Sat Sep 29, 2018 12:33 AM
or just get fixed sound and color from fandal site
Attached File  moon_patrol.zip   12.29KB   34 downloads
I know it had something to do with audio control and being moved from cartridge...
anyway this is fixed by fandal so maybe no problems with whatever your using?
#41 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Sat Sep 29, 2018 12:36 AM
Thank you.   As getting ahold of a working ATR seems to be a problem for me and everyone, a disk version of these hacks will apparently need to wait.   I'll dedicate my time towards making adjustments to the binary, maybe months down the road I'll drag my Atari 800 back out and build a decent ATR image to work with.
#42 _The Doctor__ OFFLINE
_The Doctor__
  • 6,246 posts
Posted Sat Sep 29, 2018 1:15 AM
what do you mean, disk version?
this is a 5200 conversion or cartridge conversion...
there might be disk in preservation as well..
what is it you are looking for?
I don't understand... you can copy the xex to a disk or ?
Do you need an ATR with this on it? made for your or Your hack on it. if this is the case... we can make an ATR without any issues and copy the xex to it.
I don't know what you need...
Let us know what emulator you are using and what you know works with it in terms of DOS or ATR, is your emu up to date? If the emu is flawed perhaps Altira is and option to use?
do you want a boot loader of some kind.
here is the cartridge
Attached File  Moon Patrol (1983)(Atari)(US).car.txt   16.02KB   19 downloads
just rename to moonpatrol.car
Edited by _The Doctor__, Sat Sep 29, 2018 2:14 AM.
#43 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sat Sep 29, 2018 1:46 AM
I’m sure there is a dump of the 800 cartridge somewhere. Just no time to search it.
#44 _The Doctor__ OFFLINE
_The Doctor__
  • 6,246 posts
Posted Sat Sep 29, 2018 2:19 AM
there is the cartridge image ready for you to hack up...
all the other .xex are spread through the thread, please pick all the ones you want and I will put them on and ATR or indicate what you want done. Most everyone can make atr's. If you are unable, once you proved the post and a little note. I'll do it.
#45 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Sat Sep 29, 2018 7:07 AM
I have a version of Moon Patrol I have played from disk since the 80's.   I'll get my Atari 800 out at some point and create a working ATR.  I've been working with emulators for a while and the 800 is kinda buried at the moment, so no worries, I'll have a disk version of this going with that or other versions you've submitted in a few months.
#46 _The Doctor__ OFFLINE
_The Doctor__
  • 6,246 posts
Posted Sat Sep 29, 2018 9:46 AM
wow I couldn't read that last post. It basically was to say once you provide the list or post of what you want, I am willing to make your atr's :)
apologies... for the mess,,, not only was I having difficulty, but part of my network was over the night as well.
New people in the neighborhood have their routers set on odd channels trouncing the spectrum and killing through put for the neighborhood. The also have the rts/cts guard functions turned off broadcasting at will all over the place, this is causing routers and wireless cards to get trounced and reset to the point of disconnection over retries... terrible...    I have upped power and chose the best channel I could to get away from them and made sure every device is tenacious and is using all guards and rts/cts... it's all good now. Their turn to have issues now. sigh.
Edited by _The Doctor__, Sat Sep 29, 2018 9:54 AM.
#47 doctorclu OFFLINE
doctorclu
  • 7,691 posts
Posted Sat Sep 29, 2018 10:09 AM
If you are able to create a ATR of one of the above mentioned sound patched versions, will be awesome!
#48 EnderDude OFFLINE
EnderDude
    Chopper Commander
  • 147 posts
Posted Sat Sep 29, 2018 5:42 PM
HOVERCRAFT FTW!!!!
#49 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,045 posts
Posted Sat Sep 29, 2018 6:48 PM
That sucks. I'm glad I live in the country where no one's wi-fi can even reach the next neighbor...
#50 Gunstar OFFLINE
Gunstar
    Gunstar
  • 10,045 posts
Posted Sat Sep 29, 2018 6:50 PM
HOVERCRAFT FTW!!!!
Could you change the wheel sprites to make them look like the black "hover bubble" that is usually under hovercraft? At least REAL hovercraft and not sci-fi hovercraft is like that...I just suggest it as it may look cooler.
Edited by Gunstar, Sat Sep 29, 2018 6:52 PM.
Also tagged with one or more of these keywords: Atari 800, Atari XL, Atari XE, Moon Patrol, Moon Patrol Arcade
