bchamb88 Posted October 3, 2018 Share Posted October 3, 2018 I've got 3 of the original style units and all three suffer from varying degrees of key bounce. My unit that has the F18a installed actually has it the worst. The 100% easy fix is as follows. And pardon me if this has been posted at some point in the past. I took one of my wife's emery boards and cut it lengthwise. This made the width about right to fit between the 2 sets of metal fingers underneath the key. More importantly, the thickness was perfect between the fingers. My main unit probably had 15 or so bad keys. I would insert the emery board ahd move it up and down maybe 10 times. It fully fixed every bouncing key. I went ahead and did this procedure to all the keys as preventative maintenance. Just file (no pun intended) this away and try it next time you have bouncy key problems. 4 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted October 3, 2018 Share Posted October 3, 2018 And pardon me if this has been posted at some point in the past. No problem! Sometimes there are different variants, other times we get entirely new approaches to things. But in reality, IT'S ALWAYS NEW TO SOMEONE! Quote Link to comment Share on other sites More sharing options...
