atariry Posted October 7, 2018 Share Posted October 7, 2018 While working on my Atari on a breadboard project, I nearly blew up the GTIA chip. I had wired up power, clocks and controls, but not address or data, of Sally (6502), ANTIC and GTIA. When I powered up, I was having problems programming the FPGA board, and I saw that the 5V power rail was low. I then saw that the power supply was limiting the current, and stupidly I raised the limit from 500mA to 1A. I then smelt something burning, so quickly turned off the power supply. Touching the chips, the GTIA chip was too hot to hold my finger on. Damn!!! I opened the Atari official 400/800 field service manual and to my horror saw that I had the +5V and GND connections reversed. I had googled for pinouts and had used the rather nice pictures from user.xmission.com. On this site the picture of GTIA has VCC (i.e. +5V on pin 3), as opposed to other sources which show pin 3 as ground. I will attempt to contact the webmaster to ask if the pictures can be corrected. Just my luck to use these and not double check with other sources. Lesson learned! I reversed the power connections to the GTIA and powered up. All was well and current draw was no more than 300mA. Nevertheless all pins of GTIA looked dead on a scope. I re-connected the 3.57MHz source to FOSC, and finally saw a waveform on the CSYNC pin, which was horizontal sync pulses, but without and vertical sync (which I suspect/hope comes from the ANTIC chip which is not yet programmed). --Atariry Quote Link to comment Share on other sites More sharing options...
foft Posted October 8, 2018 Share Posted October 8, 2018 (edited) Thank you, I think you just saved me blowing up another one. Id copied the pin out from there too... Your project looks great! Yeah I think with no antic there is no vsync. Edited October 8, 2018 by foft Quote Link to comment Share on other sites More sharing options...
1050 Posted October 8, 2018 Share Posted October 8, 2018 Problem may stem from the Atari 800XL FSM schematic which has pin 3 with a label of VCC but is properly diagramed as connected to ground. Pin 27 suffers the same fate as incorrectly labeled as VSS but is properly connected to +5 by diagram. If someone went by just this official diagram that has the mixed up labels on it things could go bad in a hurry. And a lot of people do just that without checking too. Atari made a mistake here and everybody else just follows suite without confirming that the labels are wrong polarity for those functions. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 8, 2018 Share Posted October 8, 2018 I am of the opinion all such FSM should be corrected and replaced..... this is not a case of keeping paper as it was but preserving the machines themselves! 2 Quote Link to comment Share on other sites More sharing options...
