Posted Mon Oct 29, 2018 7:27 PM
Posted Mon Oct 29, 2018 7:30 PM
PAL and NTSC both are the same in terms of the size PCB slot to my knowledge.
The problem you are looking at is a cheaply made non-uniform cart shell.
I have a number of Taiwan Cooper games that are NTSC but they wont fit properly in my 2600 or 7800 because of the cheap shells that are so poorly made.
I dont know if any solution.
Sometimes people will use something like a Videogame Brain as a pass thru device for cartshells that dont fit properly in their console. Its a Fairly common problem with Imagic, Activision and M-Network shells in the 7800.
Sent from my iPhone using Tapatalk
Posted Mon Oct 29, 2018 7:35 PM
Thanks, I'll try to open it up to insert the pcb by itself to see if it works.
Posted Mon Oct 29, 2018 7:54 PM
Posted Mon Oct 29, 2018 7:59 PM
Hard to tell on the pic, but looks like your 2 cart slot dust protector tabs have been broken off. They push into the 2600 tab slots, opening up the systems little dust protector flap. Try turning your 2600 upside down and then carefully wiggle the cart in. Over the years, the little mechanism that opens the dust cover becomes weak and can be opened by turning the system upside down, as aforementioned.
Posted Mon Oct 29, 2018 8:07 PM
What is your solution for the video out on NTSC TVs?
Posted Mon Oct 29, 2018 8:13 PM
http://atariage.com/...this-might-help
Posted Tue Oct 30, 2018 2:16 AM
A PAL to NTSC AV adapter
Your ntsc console outputs a ntsc signal so I'm afraid it won't help. The only difference with a pal cart is that the game will output 50fps instead of 60, and colors will look wrong.
Edited by Cambouis de l'Atari, Tue Oct 30, 2018 2:21 AM.
programming
Atari Systems →
Atari 2600 →
Atari 2600 Programming →
2600 Programming For Newbies →
Just started with assembly programming, Playfield generation difficultiesStarted by George Washingtoad, 11 Feb 2019 ![]() |
Atari Systems →
Atari 7800 →
New PC controller compatibility for your 7800Started by ave1, 30 Jan 2019 ![]() |
Marketplace →
Buy, Sell, and Trade →
FS: CIB Atari 2600, Sunnyvale 4-switchStarted by berserkerNES, 28 Jan 2019 ![]() |
Marketplace →
![]() [SOLD] Qbert Jump Atari 2600 carts, Free Play Florida 2018 limited EdStarted by Maverick, 25 Jan 2019 ![]() |
Atari Systems →
Atari 2600 →
Howard Scott Warshaw InterviewStarted by lushgirl_80, 22 Jan 2019 ![]() |
