bfollowell Posted November 7, 2018 Share Posted November 7, 2018 I took my keyboard apart for some major cleaning and to replace the contact pads with the Best "TT" Touch Upgrade pads. As usual with keyboards, some of the longer/larger keys had little spring rods under them. However, several didn't. I'm hoping someone on here may have a had their keyboard apart recently for some cleaning and may be able to answer my questions. The 0 and the Enter key from the number keypad seem to have grooves in the plastic base for them, but there were no springs under the keys when I removed them and there are not any plastic clips under the keys for them, though there do appear to be slots for them. Are mine just missing, maybe lost by a previous owner, or are they typically not there? Also, the space bar has a larger spring rod, but the key itself doesn't have the little clips that the rods usually sit in. There does appear to be a portion of one remaining on the right side of the key (left underneath in the picture). Should it have the two clips for the spring rod? I've attached a few photos so you can see what I'm rambling on about. I'm just trying to figure out if I need to order some replacement keys so I can get this baby back as close to original as I can. Thanks guys! Quote Link to comment Share on other sites More sharing options...
tjlazer Posted November 11, 2018 Share Posted November 11, 2018 I checked one of my 520ST's and the Enter and 0 do not have the metal bars. The Space bar does have the plastic clips on both sides. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted November 11, 2018 Author Share Posted November 11, 2018 I checked one of my 520ST's and the Enter and 0 do not have the metal bars. The Space bar does have the plastic clips on both sides. Thanks for confirming. I'll probably look into ordering a replacement space bar eventually. Quote Link to comment Share on other sites More sharing options...
