LordKraken Posted November 12, 2018 Share Posted November 12, 2018 (edited) Hello guys, I'm trying to play a sound directly in "lyxass-style" asm, without the use of any library. I looked at the code from pong1k from Sage, and actually managed to play a sound in my own program, but I basically just figured out what the sound code was and copy/pasted it . I'm trying to understand what the code is ACTUALLY doing now, so any help would be greatly appreciated (my guess is that we poke some value at special magic address...?) Note that it is just code snippet from different part of the code. ; Sound definition..? SetSound:: ; stereo sound lda #$42 ; Beep metal sound sta $fd50 lda #$3B sta $fd25 lda #$24 sta $fd21 ; Code to play the sound .playsound lda #80 sta $fd20 ; Volume jmp .main ; As the comment says... .loop lda $fd0a ; No clue what this is doing but it makes the sound better bne .loop ; apparently decrease the volume and eventually stop the sound lda $fd20 _IFNE dec $fd20 jmp .loop _ENDIF Edited November 12, 2018 by LordKraken Quote Link to comment Share on other sites More sharing options...
+karri Posted November 12, 2018 Share Posted November 12, 2018 There is 4 sets of registers for sound. #define STEREO_REG (*(char *)0xfd50) #define VOLUME_REG(chan) (*(char *)(0xfd20 + 0 + (chan & 3) * ) #define FEED_REG(chan) (*(char *)(0xfd20 + 1 + (chan & 3) * ) #define OUT_REG(chan) (*(char *)(0xfd20 + 2 + (chan & 3) * ) #define SHIFT_REG(chan) (*(char *)(0xfd20 + 3 + (chan & 3) * ) #define BKUP_REG(chan) (*(char *)(0xfd20 + 4 + (chan & 3) * ) #define CTLA_REG(chan) (*(char *)(0xfd20 + 5 + (chan & 3) * ) #define CNT_REG(chan) (*(char *)(0xfd20 + 6 + (chan & 3) * ) #define CTLB_REG(chan) (*(char *)(0xfd20 + 7 + (chan & 3) * ) The VOLUME is obvious. The BKUP is the pitch. The rest are related to waveform. The OUT reg is where you can bang PCM waveform to produce digitized sound. Quote Link to comment Share on other sites More sharing options...
enthusi Posted November 12, 2018 Share Posted November 12, 2018 Sorry, double post. Quote Link to comment Share on other sites More sharing options...
enthusi Posted November 12, 2018 Share Posted November 12, 2018 When I wrote the sound routines for Lacim's Legacy I quickly realized that the common docs arent toooo helpful there :-) Emulator sources helped me best so far. ; No clue what this is doing That made me cry a little, though :-) fd0a is the timer for rasterlines/vblank. Quote Link to comment Share on other sites More sharing options...
LordKraken Posted November 12, 2018 Author Share Posted November 12, 2018 (edited) Thanks Karri, I'll look at the code again with this piece of information (I think the smileys are hiding some relevant information...) @enthusi Well it might be obvious for you but without documentation I can just guess ^^ Plus I'm from this generation of programmers who still know what asm is and how it works but has never done anything more than practicing a bit at school (believe me, the "millenial" programmers are even worse they don't even know what ASM is ). Now does that snippet also mean that the sound is going to sound different every time, depending on how much time is left before a vblank? Also what is in $fcb0? thanks Also what is in $fcb0? Found the epyx document and apparently lda $fcb0 is used to check whether the josytick button is pressed... am I right? Edited November 12, 2018 by LordKraken Quote Link to comment Share on other sites More sharing options...
42bs Posted November 13, 2018 Share Posted November 13, 2018 Thanks Karri, I'll look at the code again with this piece of information (I think the smileys are hiding some relevant information...) @enthusi Well it might be obvious for you but without documentation I can just guess ^^ Plus I'm from this generation of programmers who still know what asm is and how it works but has never done anything more than practicing a bit at school (believe me, the "millenial" programmers are even worse they don't even know what ASM is ). Now does that snippet also mean that the sound is going to sound different every time, depending on how much time is left before a vblank? Also what is in $fcb0? thanks Found the epyx document and apparently lda $fcb0 is used to check whether the josytick button is pressed... am I right? What do you mean "without documentation". There are the original docs either as picture or html. So instead of "guessing" try "reading". Quote Link to comment Share on other sites More sharing options...
+karri Posted November 13, 2018 Share Posted November 13, 2018 The "smileys" was supposed to be character 8 followed by ) As 42bs said you get tons of information from the docs and also from the website that Alex is maintaining. It is pinned at the top of this forum. 1 Quote Link to comment Share on other sites More sharing options...
Turbo Laser Lynx Posted November 13, 2018 Share Posted November 13, 2018 (edited) I found it much easier to get started with assembler on the c64 (not that I've done much of it, it's so slow when you're a beginner at it), but at least it was faster understanding the general concepts, because the documentation and books are so much more beginner friendly on the c64. I found these two sites for lynx hardware addresses. 42bs site for more thorough documentation: http://www.monlynx.de/lynx/hardware.html and this one for a quick reference list: http://www.chibiakumas.com/6502/atarilynx.php Edited November 13, 2018 by Turbo Laser Lynx Quote Link to comment Share on other sites More sharing options...
enthusi Posted November 13, 2018 Share Posted November 13, 2018 Assembler is great fun. You will see! And in my opinion the only real Option for 8bit systems. You will often check the Hardware Register appendix. In the end it contains basically all you need. Lynx isnt that hard to access. No complex gfx modes, etc. Fd0a counts down to 0 each frame. The loop is a so-called busy loop that Waits until the timer reaches zero. So it ends once per frame. Debugging via screen colors is quite helpful on lynx. Try lda $fd0a then sta $fda0 in the loop. After that add a few LSR between lda and sta and try to understand what it does. Quote Link to comment Share on other sites More sharing options...
LordKraken Posted November 13, 2018 Author Share Posted November 13, 2018 (edited) What do you mean "without documentation". There are the original docs either as picture or html. So instead of "guessing" try "reading". This is an odd answer. I'm just asking for help, no need to patronize me;) First of all I didn't know about the doc, because I didn't even know what to look for. But more than that I also clearly stated I am not (definitely not!) an ASM programmer, so what is obvious for you guys might not be for me. Anyway, thanks Karri and Sampo for the information and the link, I learnt new stuff @enthusi thanks a lot! That sounds like a reasonable approach to understand all of that a bit better (last time I touched asm it was x86 in 1998... ) Edited November 13, 2018 by LordKraken Quote Link to comment Share on other sites More sharing options...
42bs Posted November 13, 2018 Share Posted November 13, 2018 This is an odd answer. I'm just asking for help, no need to patronize me;) First of all I didn't know about the doc, because I didn't even know what to look for. But more than that I also clearly stated I am not (definitely not!) an ASM programmer, so what is obvious for you guys might not be for me. "patronize", well, I was even polite not the say RTFM. I just expect that someone does a bit of search him/herself before asking questions. And "finding" the Lynx documentation shouldn't be a big deal (try Google: atari lynx documentation). And this is by no way related to assembly. It is basic programming. A lot of gus here (me included) are willing to answer questions, but I expect a sign that the questioner did try to solve the problem him/herself first. Quote Link to comment Share on other sites More sharing options...
+karri Posted November 13, 2018 Share Posted November 13, 2018 If you are not interested in libraries but you just want to make sound directly then I would suggest looking at the C-version of abcmusic. Everything is written in C with no hidden libraries. Here is a bit from "Shaken, not stirred" for digital saying of "Big.. Bada big boom". I did not use a timer but put in a dummy for loop doing nothing to get the right sound out of the beast. tgi_sprite(&Smushroom); tgi_setcolor(COLOR_YELLOW); tgi_outtextxy(70, 40, "Big..."); tgi_outtextxy(30, 50, "Bada Big Boom"); tgi_updatedisplay(); lynx_snd_pause(); lynx_load((int)&BIGBADABOOM_FILENR); musa = bigbadaboom; CTLB_REG(0) = 0x0; CTLA_REG(0) = 0x10; STEREO_REG = 0; VOLUME_REG(0) = (char) 255; for (i = 0; i < 21000; i++) { for (j = 0; j < 15; j++) { isfrog = 0; } OUT_REG(0) = (char)*musa; musa++; } VOLUME_REG(0) = (char) 255; The file BIGBADABOOM is just an 8kHz mono file with one byte per sample. .export _bigbadaboom .segment "BIGBADABOOM_RODATA" _bigbadaboom: .byte 253 .byte 250 .byte 251 .byte 251 .byte 251 .byte 251 .byte 250 .byte 248 .byte 249 .byte 251 .byte 253 .byte 253 .byte 0 .byte 2 .byte 1 .byte 254 .byte 252 .byte 251 .byte 248 .byte 248 ... Quote Link to comment Share on other sites More sharing options...
LordKraken Posted November 13, 2018 Author Share Posted November 13, 2018 Dude seriously, I spent an evening and a half reading the code of your pong1k example. For someone with no prior experience of ASM, especially not 6502, it was a difficult and exhausting experience (although very interesting). I'm not coming up with random question while taking my shower to just annoy people. I figured that those memory addresses were somehow specials and the only thing I was asking was indeed "What are they really, and where can I learn more". An answer with a link to the actual low-level documentation would have been good enough. Worst case scenario, just don$t answer. But NO NEED to be condescending. Really. Now I realize you've done a lot for the developer community, and I'm grateful for that, but again it does NOT grant you the right to be mean to people. Quote Link to comment Share on other sites More sharing options...
LordKraken Posted November 13, 2018 Author Share Posted November 13, 2018 @Karri Thanks for the suggestion, but I'm tweaking a "multicart" program for "newcc65" so I have to write it in ASM. I promised I will look at the new compiler once I'm done with my game Quote Link to comment Share on other sites More sharing options...
42bs Posted November 13, 2018 Share Posted November 13, 2018 Now I realize you've done a lot for the developer community, and I'm grateful for that, but again it does NOT grant you the right to be mean to people. Is it "mean" to ask for a little searching before asking? If so, I am mean. If you'd asked "Why is this code reading the VBL counter register until it is zero?" might have brought you the answer w/o even asking. Quote Link to comment Share on other sites More sharing options...
enthusi Posted November 13, 2018 Share Posted November 13, 2018 I guess we can not overestimate the efforts that went into all the documentation and libraries, tool-chains that are around and openly distributed. That was already like 25 years ago? BS93 iirc The Lynx homebrew community seems to be quite small and on top of that relying on high-level languages/interfaces for decades now. So there remain only very few people with in-depth knowledge. I myself try to avoid asking for 'solutions' but I also really much enjoy discovering things on my own and re-inventing the wheel. And I still ask alot If you are fully new to assembler I think the direct read/write of registers is maybe a bit new concept. To become familiar I mostly dont use labels for registers either but their hex-adresses directly instead. Helps you reading disassemblies alot! Just by playing with the palette colors in 'real time' will give you a good feeling of how things work. But be aware that the Lynx emulators only render on a line-by-line basis, whereas the real Lynx will start using the new color right when you change it. The above mentioned colorbars will look clean and stable when used in horizontal interrupt but not so much in a busy loop. You will see when you test on real hardware (old and new LCD alike). Assembler will allow for much more efficient code, including selfmodifying code which is a completely new concept for C-coders or people used to execute code from ROM only. (Some assembler programmers dont like it either, though Don't worry about being new to it. The good thing about old things: they dont really age. Never too late. 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted November 13, 2018 Share Posted November 13, 2018 There is also a newcc65 version of abcmusic in the same repo I mentioned earlier. If you look at the file abcmusic.m65 you have the driver for playing music on the newcc65 platform. There is also a newcc65 version that plays 4-voice kantele music called abcmini.c 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted November 13, 2018 Share Posted November 13, 2018 But NO NEED to be condescending. Really. I did not mean to be "condescending" (had to look up that word ) Quote Link to comment Share on other sites More sharing options...
LordKraken Posted November 13, 2018 Author Share Posted November 13, 2018 Well nice to hear that I understand your point, make no mistake, sometimes helping with real basic stuff can get annoying. When that happen, and you're not in a good day, just ignore the question, or put a link w/o comment, that's ok. No one can thank you enough, you, Karri and a few others, for giving us all these tools to create games on our favourite handheld! But with great power come great responsibilities, and empowering people is one of them imho (not bashing then though ^^). That said, ich hoffe das wir friede machen kann Have a nice day! 1 Quote Link to comment Share on other sites More sharing options...
