CTRL Key in XB after autoload doesn't work
XB Call Key
26 replies to this topic
#1 wolhess OFFLINE
wolhess
    Star Raider
  • 72 posts
Posted Tue Nov 13, 2018 6:05 AM
Hi,
I tried to make my own startmenue in XB. To change DSK1-3, I will use [ctrl]+1 for DSK1., [xtrl]+2 for DSK2 and [ctrl3]+3 for DSK3.
If I start the small programm below with >OLD DSK1.PROG and >RUN, it works as expected.
100 CALL CLEAR
110 PRINT "KEY CHECK"
120 CALL KEY(0,K,S)
130 IF K>=177 AND K<=179 THEN 140 ELSE 160
140 PRINT "CTRL 1-3 OK!"
150 GOTO 120
160 PRINT "KEY";K;"STATUS";S
170 GOTO 120
If I autoload the programm (programm-name = load) in XB the programm doesn't accept [ctrl]+1-3!
Normal key's and [FCTN]+key are working.
What do I wrong in this case? Is anybody there who make it possible to use [CTRL]+1 after autoload?
I tried this in RXB, XB2.5, XB2.7, stock TI and classic99, all the same problem.
Thanks for any help, even if that does not work in XB.
#2 mizapf OFFLINE
mizapf
  • 3,610 posts
Posted Tue Nov 13, 2018 8:20 AM
Try keyboard mode 5. Just a quick guess.
#3 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 429 posts
Posted Tue Nov 13, 2018 9:59 AM
Ahoy there... wolhess,
I was not able to recreate your results using XB VER.110 on classic99 or real iron w/TIPI... "CTRL 1-3 OK!".
Using RXB 2012 from classic99, I did realize the issue... if I BREAK with FCTN 4 then CONTINUE... CTRL keys work... "CTRL 1-3 OK!"(dark blue screen)hmm...
   processing...
tried mizapf's idea... it worked
did this next... new line 105... problem fixed... if not solved... waste of MEM+TIME!
100 CALL CLEAR
105 CALL KEY(5,K,S)
120 CALL KEY(0,K,S)
150 GOTO 120
170 GOTO 120
  • RXB likes this
#4 senior_falcon OFFLINE
senior_falcon
  • 1,489 posts
Posted Tue Nov 13, 2018 12:31 PM
Here's an idea that might work. I don't know for sure because I am at work and cannot test it out until tonight.
Save this one line program as LOAD
10 RUN "DSK1.MENU"
And of course you need to save the menu program as MENU
By avoiding autoload when loading MENU it may make the program respond as expected.
Autoload can do funny things. I remember Bruce Harrison having problems with random numbers when autoloading a program.
#5 mizapf OFFLINE
mizapf
  • 3,610 posts
Posted Tue Nov 13, 2018 2:43 PM
The point is that keyboard mode 0 means: same mode as last time. Keyboard mode 5 is the BASIC mode. If I remember correctly, keyboard mode 3 is a TI-99/4-compatible mode without CTRL key. It seems as if the autoload feature of Extended Basic does not set the mode and keeps the mode from the master title screen.
Surprisingly, I cannot reproduce the problem with MAME. The original program senses the CTRL key, unless I explicitly use mode 3. I wonder whether the difference is caused by a particular peripheral setup, or whether there is another version of the Extended Basic module.
#6 RXB OFFLINE
RXB
  • 3,583 posts
Posted Tue Nov 13, 2018 5:30 PM
You know what you may be Right about that?
RXB 2000 on all have Quit Key TURNED OFF on RXB start up:
[3508]               ***********************************************************
[3509] 7A38 B6,80,C2 RXBRUN OR   >10,@>83C2        QUIT KEY OFF
       7A3B 10
[3510] 7A3C B2,45,F7        AND  >F7,@FLAG         Set flag
[3511] 7A3F BD,04,7E        DST  @YPT,@VARY        Save Row/Col values
[3512] 7A42 04,01           BACK >01
[3513] 7A44 07,80           ALL  >80
I wonder if turning off the Quit Key is also creating this problem?
Edited by RXB, Tue Nov 13, 2018 5:31 PM.
#7 Casey OFFLINE
Casey
    Moonsweeper
  • 340 posts
Posted Tue Nov 13, 2018 9:04 PM
I took some time tonight to experiment with this on my real iron 99/4A.
I have a beige console with 1981 software, and first, I plugged in a beige V110 Extended BASIC cartridge, and then saved the program as DSK1.LOAD.
The program ran as expected - CTRL1-3 were detected just fine when autoloaded.
I then put in my FinalGROM99 and ran the V110 Extended BASIC from there.  It also behaved the expected way.
Next, I tried V100 Extended BASIC - it never detected CTRL 1-3, even if I changed the CALL KEY to key unit 5.
Next, Extended BASIC V2.6 - it did not work when autoloaded, but breaking the program and then running the program produced the expected results.
Next, RXB 2015 - same behavior.  It did not work when autoloaded, but breaking the program and then running it produced the expected results.
Next, Mechatronic Extended BASIC - it behaved correctly.
Just some data points - not sure what exactly it means.  I do know that in the past I've had differences in how things worked between different V110 Extended BASIC cartridges, so it could be something that was fixed later.  I'd be curious how a black Extended BASIC cartridge behaves on real iron with this program.
#8 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 429 posts
Posted Tue Nov 13, 2018 10:36 PM
The cartridge reports version 110, is black... and was a gift with a hand written masking tape label.
#9 wolhess OFFLINE
wolhess
    Star Raider
  • 72 posts
Posted Wed Nov 14, 2018 4:23 AM
Thank You mizapf. This was the trick!
#10 wolhess OFFLINE
wolhess
    Star Raider
  • 72 posts
Posted Wed Nov 14, 2018 5:02 AM
Thank you all for your fast responses!
The hint from Michael using CALL KEY(5,K,S) is working fine.
I also tested the way to start the keycheck program from LOAD with RUN "DSK1.KEYCHECK".
The result was the same as starting the program as autoload.
I think the RUN statement and autoload uses the same way without CTRL-Key accepted.
What I learned  is we have in XB not only the key unit codes 0,1,2 as described on page 109 of the book "TI Extended Basic - For the TI-99/4 Home Computer"
The numbers 3,4 and 5 are also accepted in CALL KEY.
The CTRL-Keys are supported in key unit code 1 (with diffrent return codes), 4 and 5 with the correct return codes.
It is amazing, every time I ask something in this forum I get the right answers in very fast time.
Thank you again to all!
#11 mizapf OFFLINE
mizapf
  • 3,610 posts
Posted Wed Nov 14, 2018 8:20 AM
The reason why nearly all BASIC programs use keyboard mode 0 is, in my view, because we learned it this way from the TI manuals. TI used this mode maybe for the sake of compatibility with 99/4 consoles. When you write programs with mode 0, they should run on all consoles; but on the 99/4A it means you keep the previous keyboard mode. If you use mode 5, they will not run on a 99/4 (just tried in MAME, only modes 0,1,2 are available). It would make more sense to use the explicit mode 5 setting at all times (or 1 or 2 for split keyboard).
#12 Lee Stewart OFFLINE
Lee Stewart
  • 3,967 posts
Posted Wed Nov 14, 2018 10:29 AM
The keyboard modes are discussed in detail in §2.6.10 “KEY subprogram” and §3.3 “Keyboard mapping” in the TI-99/4A User’s Reference Guide.  As has been pointed out by mizapf, mode 0 specifies the last-used of modes 3, 4 and 5.  The keyboard modes are described as follows:
Mode Description
 0   Previously specified mode (3, 4 or 5)
 1   Left side of keyboard or joystick 1
        –character codes: 0 – 19
 2   Right side of keyboard or joystick 2
 3   Standard TI-99/4 mode
        –character codes: 0 – 127, but returned as all caps
        –FCTN codes: 1 – 15
        –CTRL codes: none
 4   Pascal mode
        –character codes: 0 – 127, upper and lower case
        –FCTN codes: 129 – 143
        –CTRL codes: 1 – 31
 5   Basic mode
        –FCTN codes: 1 – 15
        –CTRL codes: 128 – 159, 187
What the above-referenced sections do not tell you is how the 4A keeps track of the previous (whole or unsplit) keyboard mode.  The keyboard mode is specified to the keyboard scanning routine (KSCAN) by storing its value (0 – 5) at >8374.  This is what “CALL KEY(mode,key,status)” does and you can do it explicitly, as you would need to do in Assembler.  KSCAN decodes the byte at >8374 by testing first for mode 0.  Failing that, KSCAN tests for modes 1 and 2, decrementing it and testing for 0 each time.  If it is neither mode 1 nor 2, the final decrement yields 0, 1, 2 or a nonsense number.  If the former, the reduced value is stored in >83C6 (MSB of console ISR workspace R3).  It is >83C6 that tells the 4A which of modes 3, 4 and 5 was last specified for the keyboard.  Whatever the value, KSCAN clears (sets to 0) >8374, so you can never discover the last keyboard mode by checking >8374.  You can get this information the same way the console does by checking the byte at >83C6.  By the way, for TI Basic and Extended Basic, the decimal addresses for >8374 and >83C6 are -31884 and -31802, respectively.
...lee
#13 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,428 posts
Posted Wed Nov 14, 2018 11:22 AM
I never really understood what advantage there was to using mode 0 given the potential pitfalls. It doesn't seem to have a speed advantage. Is there a tie-in with JOYST or some other routine(s)?
#14 Opry99er OFFLINE
Opry99er
  • 10,734 posts
Posted Wed Nov 14, 2018 11:27 AM
I've always used "0" for every routine I've ever written. I don't know why, I just always have.
  • RXB likes this
#15 Casey OFFLINE
Casey
    Moonsweeper
  • 340 posts
Posted Wed Nov 14, 2018 11:32 AM
Same with me. I’ve always used mode 0 because everything else I saw always did. I don’t recall ever seeing a program in a magazine listing use anything other than 0, 1, or 2. Maybe on an occasion I’ve seen 3 used, but certainly never 4 or 5....
  • RXB likes this
#16 Lee Stewart OFFLINE
Lee Stewart
  • 3,967 posts
Posted Wed Nov 14, 2018 12:03 PM
Well, the Extended Basic (XB) manual was written for the TI-99/4, which did not use anything but 0, 1 or 2 for keyboard mode.  Under the description for “CALL KEY()”, modes 3, 4 and 5 are listed as “for future expansion”.  So, for the TI-99/4, you could only use ‘0’ for full keyboard.  The addendum to the XB manual does discuss use of modes 3, 4 and 5 for the TI-99/4A, which handles them as I indicated in my last post.
Using mode 0 is usually to be preferred for default conditions because the system presumably gets set up for the proper whole keyboard mode.  For the TI-99/4, it really is mode 0 and only mode 0 for the full keyboard.   But, for the TI-99/4A, once you get into TI Basic or XB, it should be set up for mode 5, which you can show by checking the byte at >83C6 and adding 3 to it, i.e., >83C6 should have a value of 2.  Barring a user change, the fact that there was anything other than ‘2’ at >83C6 after XB autoloaded “DSK1.LOAD” is a bug in XB, as far as I am concerned.
...lee
#17 Lee Stewart OFFLINE
Lee Stewart
  • 3,967 posts
Posted Wed Nov 14, 2018 12:08 PM
No.  When key-unit is 1 or 2 (left or right keyboard/joystick), the default, full keyboard mode indicated at >83C6 is not checked or changed.  Only specifying a key-unit of 3, 4 or 5 will update >83C6 for the next invocation of key-unit 0.  And, only on the TI-99/4A, of course.
...lee
  • RXB likes this
#18 RXB OFFLINE
RXB
  • 3,583 posts
Posted Wed Nov 14, 2018 4:56 PM
...lee
The QUIT KEY disabled is why RXB gets this effect, but then it was a oddball way of finding it.
No one likes accidently hitting QUIT KEY when using the TI99/4A and losing everything they were working on.
This was a majority request for me from users. (First demoed on Miller Graphics GKXB)
Edited by RXB, Wed Nov 14, 2018 4:57 PM.
#19 Opry99er OFFLINE
Opry99er
  • 10,734 posts
Posted Wed Nov 14, 2018 5:39 PM
I've always been curious about GKXB. I never had a copy, but is it essentially a predecessor to RXB? It required the GK to run it because we didn't have GROM emulation available in cartridge form?
#20 arcadeshopper OFFLINE
arcadeshopper
  • 4,336 posts
Posted Wed Nov 14, 2018 5:53 PM
Yes. I used it a lot, the addons are great, and fixing the quit key + there's some line editor changes too..very nice
#21 RXB OFFLINE
RXB
  • 3,583 posts
Posted Thu Nov 15, 2018 3:28 PM
Well this is the reason RXB used Keyboard mode 0 and even XB sets Keyboard 5 then clears Keyboard mode to zero:
*            START OF BASIC INTERPETER
* GROM Address >6372 TOPLEV
       AORG >0372
TOPLEV CLR  V@LODFLG           Initialize temp area
* RXB PATCH CODE USER ***********************************
*        MOVE 77,V@LODFLG,V@LODFLG+1
*        ST   5,@KEYBD          Select full keyboard
*        SCAN
*        CZ   @KEYBD
*        BR   G6388             99/4A Console?
*       ST   >01,V@CONFLG      Select 99/4A console
       ST   V@CONFLG,@FAC       Save CONFLG
       ST   @FAC,V@CONFLG       Restore CONFLG
       BR   G6388
       BR   G6388
G6388  CLR  @KEYBD
So need to fix this so it does the same as normal XB.
#22 RXB OFFLINE
RXB
  • 3,583 posts
Posted Thu Nov 15, 2018 4:25 PM
Ok FIXED RXB
[0656]               ***********************************************************
[0657]               *            START OF BASIC INTERPETER
[0658]               ***********************************************************
[0659]               * GROM Address >6372 TOPLEV
[0660]                      AORG >0372
[0661] 6372 86,A3,71 TOPLEV CLR  V@LODFLG           Initialize temp area
[0662]               * RXB PATCH CODE USER ***********************************
[0663]               *        MOVE 77,V@LODFLG,V@LODFLG+1
[0664]               *        ST   5,@KEYBD          Select full keyboard
[0665]               *        SCAN
[0666]               *        CZ   @KEYBD
[0667]               *        BR   G6388             99/4A Console?
[0668]               *       ST   >01,V@CONFLG      Select 99/4A console
[0669] 6375 BC,4A,A3        ST   V@CONFLG,@FAC       Save CONFLG
       6378 BB
[0670] 6379 35,00,4D        MOVE 77,V@LODFLG,V@LODFLG+1
       637C A3,72,A3
       637F 71
[0671] 6380 BC,A3,BB        ST   @FAC,V@CONFLG       Restore CONFLG
       6383 4A
[0672] 6384 BE,74,05        ST   5,@KEYBD          Select full keyboard scan
[0673] 6387 03              SCAN
[0674]               *
[0675] 6388 86,74    G6388  CLR  @KEYBD
Now it does exactly what XB 110 does.
#23 Lee Stewart OFFLINE
Lee Stewart
  • 3,967 posts
Posted Thu Nov 15, 2018 5:35 PM
Ok FIXED RXB
[0660]                      AORG >0372
[0665]               *        SCAN
[0666]               *        CZ   @KEYBD
       6378 BB
       637C A3,72,A3
       637F 71
       6383 4A
[0673] 6387 03              SCAN
[0674]               *
You do not need
G6388  CLR  @KEYBD
to zero @KEYBD.  SCAN does that for you for free when @KEYBD contains 3, 4 or 5.  Of course, because it is labeled, perhaps you need it for something else, like allowing use by a TI-99/4, which does not allow any mode greater than 2 and must use mode 0 for the full keyboard.   I have not seen KSCAN from a TI-99/4 console ROM, but I would guess it zeros @KEYBD, just like the TI-99/4A, when it finds an illegal mode.
...lee
#24 RXB OFFLINE
RXB
  • 3,583 posts
Posted Fri Nov 16, 2018 11:28 AM
You do not need
G6388  CLR  @KEYBD
...lee
I agree but was in original XB code not what I put in....so yea I can remove it but just left it for 2 extra bytes.
Problem I have with code is so many address have to remain the same for XB ROMs and people writing routines that continue to work.
#25 Lee Stewart OFFLINE
Lee Stewart
  • 3,967 posts
Posted Fri Nov 16, 2018 12:13 PM
Yeah—I keep running into code with double meanings in the console ROM.  Witness these five gems marked by the original TI programmers as “nasty”:
C025   EQU  $+1           NASTY                      [$ is >0024, so ref. is >0025]
C030   LI   R0,>0020      C030 REFD (0200) NASTY     [>0200 is the value of the instruction word]
HX20   EQU  $+1           =>20 (NASTY)               [>20 is the value of the second byte of the following “MOVB” inst.]
* = BR TABLE
BRESET MOVB @STATUS,R4    IS CONDITION SET?
HX06   DEC  R5        MORE TO LOOK AT? REF IS NASTY  [>06 is value of first byte of “DEC R5”]
HX0300 LIMI 1             LABEL IS NASTY!            [>0300 is value of “LIMI” instruction]
...lee
  • RXB likes this
Also tagged with one or more of these keywords: XB, Call Key
