Wally1 Posted November 14, 2018 Share Posted November 14, 2018 hey gang i would like to make 3.5 720k floppies of GODS (forgive the gentile spelling, my Jewish brethren) but G-DS comes in 800k sized files. what can I do? thinks WAlter Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted November 15, 2018 Share Posted November 15, 2018 An 800K disk is simply a soft-sectored DSDD. If you have software that can write the image back to floppy, you should be ok. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted November 15, 2018 Share Posted November 15, 2018 With PC, you can write 800 K format only with internal drive, not with USB attached one. SW for: http://atari.8bitchip.info/floimgd.php Quote Link to comment Share on other sites More sharing options...
Wally1 Posted November 15, 2018 Author Share Posted November 15, 2018 well they said it wasn't possible but all i needed was a little piece of tape to cover the hole across from the write protect notch to make a hi-density 1.44 MB disk behave like a 720 K disk. using external USB floppy. and, it worked. Now bunch of great games on mu UltraSaint. oh I used PC (DOS) command "format a: /T:80 /N:9" I will try software mentioned in Paranoid Little Mans link. Thank you both. Walter 1 Quote Link to comment Share on other sites More sharing options...
jefffulton Posted November 15, 2018 Share Posted November 15, 2018 I have yet to find a Gods disk that is under 890K. That odd format is much more difficult for a PC to produce than an 820k. There might be a cracked version that will work, but Disk 2 is always a problem with Gods. It is in an off compressed format already. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted November 15, 2018 Share Posted November 15, 2018 well they said it wasn't possible but all i needed was a little piece of tape to cover the hole across from the write protect notch to make a hi-density 1.44 MB disk behave like a 720 K disk. using external USB floppy. and, it worked. Now bunch of great games on mu UltraSaint. oh I used PC (DOS) command "format a: /T:80 /N:9" I will try software mentioned in Paranoid Little Mans link. Thank you both. Walter 720 KB is not good for many Atari SW, they use higher capacity (10 sectors/track instead 9), and that's simply not supported by firmware of USB floppy drives. Quote Link to comment Share on other sites More sharing options...
Wally1 Posted November 15, 2018 Author Share Posted November 15, 2018 well a happy little compromise is that I got a game called 'Onslaught' to work and it is pretty friggin great. 1 Quote Link to comment Share on other sites More sharing options...
jefffulton Posted November 20, 2018 Share Posted November 20, 2018 I have not been able to get "GODS" to write out to any floppy. It's actually two 890k floppies. Even with Black tape over the the left side hole on a 1.44k floppy I can't get Makedisk to create that format. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted November 20, 2018 Share Posted November 20, 2018 PC floppy controller can't create and write hyperformat - that's how 890 KB is called. You need Atari for that. Or try with other crack. Hell, I looked what format it is in original - and it is 2 x 800 K (with lot of empty space). You definitely need another crack. 1 Quote Link to comment Share on other sites More sharing options...
jefffulton Posted November 22, 2018 Share Posted November 22, 2018 PC floppy controller can't create and write hyperformat - that's how 890 KB is called. You need Atari for that. Or try with other crack. Hell, I looked what format it is in original - and it is 2 x 800 K (with lot of empty space). You definitely need another crack. I had the original disk 2 for Gods (I can't find disk one). When you run disk two, try's to run its own disk-expander. I have looked at all of the major cracks, and none will write on a PC. Had anyone created an image writer what will work on the ST? Quote Link to comment Share on other sites More sharing options...
