MEGA SCART switchers...8+
SCART Atari Retro A/V
3 replies to this topic
#1 TheCoolDave OFFLINE
TheCoolDave
    Chopper Commander
  • 188 posts
Posted Sun Nov 25, 2018 12:35 PM
Hey all,
I have had a few threads here on my retro consoles that I am trying to setup. I was about to stick with US standard of S-video with everything possible but, as I am leaning towards a Framemeister for my setup, this opens the door to RGB and can upscale/line double up to 480p over HDMI, this is claimed to be one of the best pictures you can get from Retro consoles.
This thread is not for comparing the Framemeister vs. the OSSC. I still will have some consoles that have S-video and will leave them like that for reasons. The OSSC cant do S-video with out a converter of some type, that I don't want to deal with. So the Framemeister looks like my winner here.
This brings up another issue. SCART switching. It's been a long quest for a lot of people. For 8 or more, you only have a few options and the price seems to sky rocket from there.  If I am going this route, I need to go all in, as much as possible within affordable range (not going tp spend $400+ for switching).
My setup is going to contain 20 retro consoles from the Wii back. HDMI devices will be treated differently (and thinking about starting a YouTube channel on this subject).  This could have more than 8 RGB type consoles.  Also if S-video and Composite is treated natively with SCART (as I have read) with no conversion, running the switch into a SCART port on the switch could simplify things a little.
What I would like is Auto switching but, would love and PREFER a IR override with it.  IR gives me what I really want is to force control the change in a automated setup via remote.  Something I really want and pretty much need.
So looking for options... and see what others are using. This is the larger ones I have found...
gRetrostuf - gscartsw 8:2 about $220..
http://www.gretrostu...store/gscartsw/
Over all good quality from reviews. No IR control but, auto should do. Can be daisy chained but, to get 15, it's going to cost $440+ shipping.  Big cost.
Lotharek - Hydra series.
https://lotharek.pl/products.php?id=35
A selection of sizes... 8 to 16 (OMG !) switchers..  Kind of eyeing the W-Hydra 2.  It's 16:2  that does everything. INCLUDING IR control (something that seems hard to find). Price is not too crazy compared to other options 999.00 PLN or about $264.43 US. A little pricey but, for what it offers, I don't know of anything else that could fill the bill.
I don't know much about this W-Hydra 2, anyone use their series of switches ? Any good or bad on them ?
What are others using ? Anyone using MORE than 8 devices that can do SCART ?
This is the type of thing I am losing sleep over so I wanted to start a MODERN discussion on options or MODERN switchers..
#2 Newsdee OFFLINE
Newsdee
  • 1,297 posts
Posted Mon Dec 17, 2018 9:41 PM
Only six ports, but I have one of these:
https://otaku-games....th-housing.html
It saves some space because I can use it as a component switch as well.
My setup orbits around an XRGB-Mini which takes conposite, component, S-Video and RGB as inputs and upscales to HDMI. Each input goes to a switch for that type, so, for example, all my conposite consoles come from one box into the upscaler.
For HDMI I have two separate 5-port switches that go to different TV inputs. So I have room for 9 HDMI machines (excluding the upscaler), 5 composite/SVideo, 4 component (own switch), and 6 RGB/SCART.
I printed a "cheat sheet" to remind myself what combination of buttons to push and TV inputs to use for each machine. Note, I only use HDMI input on the TV as the analogue inputs scale badly. XRGB is much better even for composite video.
Edited by Newsdee, Mon Dec 17, 2018 9:49 PM.
#3 Zap! OFFLINE
Zap!
  • 1,757 posts
Posted Sun Dec 30, 2018 2:19 PM
I have the gscartsw v3.4. It has 8 input and two output ports, and one of those is VGA (still RGB). I like this option because the VGA part feeds into my Startech PEXHDCAP60 capture card without any additional adapters. I only wish that they made a 16 port version.
http://www.gretrostu.../gscartsw-v3-4/
#4 str0m OFFLINE
str0m
    Combat Commando
  • 8 posts
Posted Fri Jan 4, 2019 10:12 AM
I have two of the 5 port auto switch Bandridge boxes which then connect to a manual 3 way scart splitter then into my TV. This works quite well but obviously isn't what you want. Just replying to say that Hydra2 16 port looks good! I need more ports now so instead of spending another £30 on a Bandridge, I could get one of them and just ignore the extra £170 lol
Also tagged with one or more of these keywords: SCART, Atari, Retro, A/V
