How hard would it be to port Outrun arcade version to the 32x?
Outrun Arcade 32x
13 replies to this topic
#1 travistouchdown OFFLINE
travistouchdown
  • 4,536 posts
  • Do the math!
Posted Wed Nov 28, 2018 9:33 AM
The original arcade version that is?  I just can't seem to get this thought out of my mind.   I mean Space Harrier, Afterburner, Virtua Racing, Virtua Fighter, Mortal Kombat II, and NBA Jam TE were all near direct arcade ports to the 32x.   I wonder if it would be relatively easy or if it would take a team hundreds of hours to make it happen.
Anyone with any technical knowledge or coding background have any insight on this?
Thanks, and going to keep dreaming in the meantime.
#2 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Wed Nov 28, 2018 10:17 AM
I'm sure it's doable but it would be starting from scratch, since nobody outside of Sega has the Outrun source code. It's probably all written in Motorola 68k assembly language anyway (the Genesis has a single 68k but the code isn't directly usable on the SuperH processors in the 32x). It would probably rely on the Genesis to draw the background and HUD and use the 32X just for the cars and other sprites. That's basically how Afterburner and Space Harrier work, and like you said, the mushroom does a great job.
The games you mention are all high-quality versions on the 32x, for sure, but none of them were just direct "make a few changes, compile, and run" kind of ports.
#3 travistouchdown OFFLINE
travistouchdown
  • 4,536 posts
  • Do the math!
Posted Wed Nov 28, 2018 11:10 AM
Interesting...so people were able to port the first level of Wolfenstein 3d because they had access to the source code?
Is it possible to strip the Outrun source code from an arcade cab board with a hex compiler or?   I'm surprised with how many platforms this game was on that it's not more readily available.
I guess I will just have to remain happy with the near arcade perfect version that's on Sega Ages for Saturn...  Still; bugs me to know Outrun would run flawlessly on 32x and yet it never happened.  I picture it with a RED cart for some reason :)
#4 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Wed Nov 28, 2018 11:42 AM
That makes it easier, and the dev himself said he was modifying the original engine
It may be possible to pull out some usable stuff from the compiled ROMs, but I don't have experience with that.
Edited by derFunkenstein, Wed Nov 28, 2018 11:42 AM.
#5 -^Cro§Bow^- OFFLINE
-^Cro§Bow^-
  • 6,995 posts
  • Collector of Fine Atari and Sega Antiquities!
Posted Wed Nov 28, 2018 2:46 PM
I'm confused, I was under the impression that the Saturn AGES releases were the most arcade accurate releases besides the recent releases on 3DS from M2? I only own Fantasy Zone for my Saturn from those AGES releases. It certainly looks, sounds, and plays just like the arcade does.
#6 Yakumo1975 OFFLINE
Yakumo1975
    Moonsweeper
  • 431 posts
Posted Wed Nov 28, 2018 7:18 PM
outun on the Saturn is even better than the Arcade because if features the option to play at 60fps or 30fps. The Arcade version was 30fps only.
#7 Austin OFFLINE
Austin
  • 12,976 posts
Posted Wed Nov 28, 2018 10:30 PM
Considering Space Harrier and After Burner II fared well on the 32X, I see no reason why OutRun couldn't have been done. I'm personally disappointed Sega didn't do it back in the day, as it's my favorite of the three.
#8 Jin OFFLINE
Jin
    Solar Striker
  • 3,112 posts
Posted Thu Nov 29, 2018 1:39 AM
The 32X had soooo much untapped potential, and OutRun could have totally been done on it with a solid team of programmers at the helm. I'm not a coding guy so I couldn't speculate as to how big the team would have had to be or how much it work it would have taked, but the hardware itself was definitely up to the task. Personally I'm still bummed out about all the 32X games that were in development but never got finished... a port of the Aliens vs Predator arcade game, the Alien Trilogy first-person shooter, Castlevania: The Bloodletting, Darkstalkers, Sonic 2: Special Edition and Sonic Mars, and Soulstar X to be specific. I can't think of a single system that had as many cancelled games that I would have loved to play as the 32X.
#9 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,615 posts
Posted Thu Nov 29, 2018 1:51 AM
I don't know about OutRun per se, but generally one can do a lot with disassembling the binary code, identifying and labeling jump points, memory usage etc. At least on other platforms there are tools that automatically do a lot of the ground work, for the developer to polish. If the source code is poorly documented and tightly tied to the arcade hardware anyway, a disassembly of the binary code might be just as much use as the origlnal source code would've been.
#10 Lost Dragon OFFLINE
Lost Dragon
  • 3,738 posts
Posted Thu Nov 29, 2018 2:37 AM
Regarding canned 32X titles.
Soulstar canned in favour of the Jaguar CD version.
Very doubtful AVP was ever even started.
Capcom USA ' s  Chris Kramer was asked about AVP and Dark Stalkers coming to the Sega 32X in 1994..His reply:
"There are going to be a couple Capcom games on the 32X.  I'm not
at liberty to discuss either titles or availability, but I can
tell you that we won't have any titles out until the middle of next year at the earliest.  Thanks for the interest."
Then after the 1995 E3 Press release by Capcom USA didn't feature the 32X, yet the aging Mega Drive
 was..he was asked just what Capcom had planned for the 32X and why it hadn't been included on the list of formats Capcom were supporting.
He replied that as of that point in time, Capcom had NO firm plans  for 32X they just remained a licensed developer.
As for Alien Trilogy, again very doubtful work got very far, it started at all.
GTW investigated it from it's original Mega CD annoucement onwards.
https://www.gamestha...r-the-sega-32x/
Sadly despite a lot of hours being put into clearing up press claims over now lost games, people are still using them as fact on likes of misc Wikipedia entries.
#11 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Thu Nov 29, 2018 7:52 AM
I thought the question was "is it feasible for the community to make it" and not "could the 32X handle it". The answer to the second question is an unequivocal "yes" because the Outrun hardware was nowhere near the 32X.
I think Capcom could have made some arcade-perfect ports for the 32X as well, but it was clear from the start that Japanese developers weren't really interested in the mushroom, since the Saturn would launch at the same time.
Edited by derFunkenstein, Thu Nov 29, 2018 7:53 AM.
#12 travistouchdown OFFLINE
travistouchdown
  • 4,536 posts
  • Do the math!
Posted Thu Nov 29, 2018 12:54 PM
Correct.  Was wondering if possible at this juncture to get it done...looks like a long shot.
#13 Austin OFFLINE
Austin
  • 12,976 posts
Posted Sun Dec 2, 2018 7:36 PM
Yes, and if we talked about that the thread would be pretty short. ;)
Short answer: Of course it's possible. The reality is, it's not going to happen.
#14 derFunkenstein OFFLINE
derFunkenstein
  • 1,342 posts
Posted Sun Dec 2, 2018 10:24 PM
The best part about this forum is that were all united by a love of vintage video games and so theres bound to be conversation. :)
Also tagged with one or more of these keywords: Outrun, Arcade, 32x
