+Gemintronic Posted December 11, 2018 Share Posted December 11, 2018 I'm trying to determine the most susceptible display device to the screen roll that comes with going over-cycle. I figured the most touchy one is the one I'd use for hardware testing. So far I've got: A modern TV with RF tuner. A VCR attached to a Commodore 1702 I need to get a plain, old CRT TV. In any case, are my first two options good enough? Is a stand alone CRT TV with RF the best option? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 11, 2018 Share Posted December 11, 2018 With my Commodore 1084S I can tell if the program generates +/-1 scanline vs the prior frames. You can easily test your displays using Jitter (scroll down to How to Test to find it). Use joystick to set the # to 129, then tap the fire button to simulate an over-cycle event. On my 1084S the top of the image (the transition from black to white) will visibly move whenever fire is tapped. 1 Quote Link to comment Share on other sites More sharing options...
