tripletopper Posted December 19, 2018 Share Posted December 19, 2018 I uae a right handed Beshu Ultimate Superstick, and for most games, probably the default index-to-index mapping for the right hand side is best. I played with the Sega Master System Joystick with the main fire button on the middle finger, and it is tiring. However I know of 3 games, 1 I know by experience and one I’m guessing on the TG 16, and one I know of on the Colecovision, ad predict there should be one gmae in the NES llibrary, tat need a button swap on the left hand side. The 3 games are Side Arms (I own) Pac-Land (i predict based on the arcade) and Tutankham The first and last have a Left fire and right fire, and Pac Land has left run and right run. Those buttons are swapped when right handed and using the usually-good index-to-index mapping, when left-to-left mapping is better for those 3 games Is flipping the buttons on an Ultimate Superstick as easy as making a pin-swap adapter, or does it require a code chip attached? I don’t want it a permanent swap, most games are good as-is. Quote Link to comment Share on other sites More sharing options...
