+Gemintronic Posted December 20, 2018 Share Posted December 20, 2018 So, I'm trying to save variables yet again. I'm thinking that a status bar color will never change during the game and want to use a constant. How would I declare a constant in bB and have it referenced in the assembly code of a mini kernel? For instance, I changed the color of the status bar to yellow (#$2F) in 6lives_statusbar.asm ifconst statusbarcolor ; only write COLUPF if color variable exists, otherwise use existing PF color lda #$2E sta COLUPF endif How would I declare a constant in bB const _mystatusbarcolor = $2E and have that replace the lda #$2E in the code? 3 Quote Link to comment Share on other sites More sharing options...
RevEng Posted December 20, 2018 Share Posted December 20, 2018 The "#$2E" in the original ASM isn't a memory location, it's a literal constant value. So no memory would be saved by substituting your bB constant for the #$2E. If you want it just for convenience, then you can just put "lda #_mystatusbarcolor" in the asm code, instead of "lda #$2E". 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 20, 2018 Author Share Posted December 20, 2018 The "#$2E" in the original ASM isn't a memory location, it's a literal constant value. So no memory would be saved by substituting your bB constant for the #$2E. If you want it just for convenience, then you can just put "lda #_mystatusbarcolor" in the asm code, instead of "lda #$2E". Holy cow that's amazing!! Thank you for the tip!! ^_^ 1 Quote Link to comment Share on other sites More sharing options...
