Experimenting with Adam data drive sensor
1 reply to this topic
#1 Ingramokhll OFFLINE
Ingramokhll
    Combat Commando
  • 2 posts
Posted Sat Dec 29, 2018 12:43 AM
I recently bought an Adam expansion module, and of course the data drive wasn't working. I took it apart for repair and found that the sensor was torn to shreds.
I haven't seen any for sale, so I thought I'd try my hand at making one. In my first attempt I made a round disc from thin plastic, used a razor to scratch the surface in a pattern similar to the original and glued it to the aluminum shaft. This was a total failure.
In attempt 2 I made another disc, but used a sharpie to draw thin lines like the original sensor had. This one didn't function properly, BUT when I manually spun the sensor it did cause the drive to respond. It made the drive motors spin in opposite directions though, effectively locking up the drive.
I'm thinking of attempting a 3rd sensor using tiny pieces of wire glued to the disc in case the sensor uses induction rather than optics, or maybe both....but the moral of the story is that I believe its possible to create new sensors for all those dead data drives setting around!!!
#2 LoTonah OFFLINE
LoTonah
    Dragonstomper
  • 541 posts
Posted Sun Dec 30, 2018 3:53 AM
Welcome to the group!  I'm too tired to comment on the rest, its 2am and I was literally just about to go to bed.  But I also noticed that no one greeted you, so there ya go!
