Karris template with own game -- setcollisiondetection(1) freeze
5 replies to this topic
#1 Bochum_Boy OFFLINE
Bochum_Boy
    Star Raider
  • 50 posts
Posted Fri Jan 11, 2019 2:40 AM
Dear all,
for my Bentley Bear project I switched to karris card template. But whenever I use tgi_setcollisiondetection(1) in the resident.c or game.c my Lynx freezes without loading the main game. Setting tgi_setcollisiondetection(0) makes the game run again, but I need the collision detection. Any ideas?
Here is main main(void) from resident.c:
int main(void)
    tgi_install(&tgi_static_stddrv);
    tgi_install(&lynx_160_102_16);
    tgi_setcollisiondetection(0);
    tgi_init();
    joy_install(&joy_static_stddrv);
    lynx_snd_init();
    CLI();
    lynx_load((int)&TUNE0_FILENR);
#if 0
    lynx_snd_pause();
    lynx_snd_play(0, musicptr.music0);
    lynx_snd_play(1, musicptr.music1);
    lynx_snd_play(2, musicptr.music2);
    lynx_snd_play(3, musicptr.music3);
    lynx_snd_continue();
#endif
    while (1) {
        lynx_load((int)&INTRO_FILENR);
        intro();
        lynx_load((int)&GAME_FILENR);
        tgi_setcollisiondetection(1);
        game();
    return 0;
#2 karri OFFLINE
karri
  • 2,502 posts
Posted Fri Jan 11, 2019 2:57 AM
Dear all,
int main(void)
    tgi_init();
    lynx_snd_init();
    CLI();
#if 0
    lynx_snd_pause();
#endif
    while (1) {
        intro();
        game();
    return 0;
The first problem is that you initialize the screen through two drivers. Please remove the line tgi_install(&lynx_160_102_16);
Have you told the linker that you need space for the collision buffer?
RAM:    file = %O, define = yes, start = $0200, size = $9E58 - __STACKSIZE__;
#3 Turbo Laser Lynx OFFLINE
Turbo Laser Lynx
    Moonsweeper
  • 485 posts
Posted Fri Jan 11, 2019 3:01 AM
The collission detection takes 8k of space which seems like a lot:
https://atarilynxdev...y-and-segments/
so my guess is that you can probably save a lot of space by programming a simple collission detection of your own.
#4 Bochum_Boy OFFLINE
Bochum_Boy
    Star Raider
  • 50 posts
Posted Fri Jan 11, 2019 4:06 AM
Thanks Karri, I removed the second driver. I tried to add the RAM line to lynx.cfg but it threw me an error with illegal code. I attached my current lynx.cfg:
SYMBOLS {
    __BLOCKSIZE__: value = 1024, type = export; # 1024 bytes / block
    __BOOTLDR__: type = import;
    __HEADERSIZE__: value = 64, type = export;
    __STARTOFDIRECTORY__: value = $CB, type = export;
    __DIRECTORYSIZE__: value = 5*8, type = export;
    __MEMORY_TOP__: value = $fff8, type = export;
    # Screen is just below the top vectors
    __SCREEN_SIZE__: value = 8160, type = export;
    __MEMORY_SCREEN1__: value = __MEMORY_TOP__ - __SCREEN_SIZE__, type = export;
    __MEMORY_SCREEN0__: value = __MEMORY_SCREEN1__ - __SCREEN_SIZE__, type = export;
    # Under the screen we put the C-stack
    __STACKSIZE__: value = $800, type = export; # 2K stack
    __MEMORY_STACK__: value = __MEMORY_SCREEN0__ - __STACKSIZE__, type = export;
    # Under the stack we must put the resident RAM segment
    __RAM_RESIDENT_SIZE__: value = $3000, type = export;
    __MEMORY_RAM__: value = __MEMORY_STACK__ - __RAM_RESIDENT_SIZE__, type = export;
    # Under the resident code we place the tunes
    __TUNES_SIZE__: value = $11dc, type = export;
    __MEMORY_TUNES__: value = __MEMORY_RAM__ - __TUNES_SIZE__, type = export;
    # Modules start adress
    __MEMORY_MODULES__: value = $0200, type = export;
    __MODULES_SIZE__: value = __MEMORY_TUNES__ - __MEMORY_MODULES__, type = export;
MEMORY {
    ZP: start = 0, size = $0100, type = rw, define = yes;
    HEADER: start = $0, size = __HEADERSIZE__, file = %O;
    BOOT: start = $0, size = __STARTOFDIRECTORY__, file = %O;
    DIR: start = $0, size = __DIRECTORYSIZE__, file = %O;
    RAM: start = __MEMORY_RAM__, size = __RAM_RESIDENT_SIZE__, define = yes, file = %O;
    INTRO: start = __MEMORY_MODULES__, size = __MODULES_SIZE__, define = yes, file = %O;
    GAME: start = __MEMORY_MODULES__, size = __MODULES_SIZE__, define = yes, file = %O;
    TUNE: start = __MEMORY_TUNES__, size = __TUNES_SIZE__, define = yes, file = %O;
SEGMENTS {
    # The cart.lnx _must_ be built in the order set here!!!
    # lnx header
    EXEHDR: load = HEADER, type = rw, define = yes;
    # encrypted  + secondary bootloader
    BOOTLDR: load = BOOT, type = rw, define = yes;
    # cart directory
    DIRECTORY: load = DIR, type = rw, define = yes;
    # resident code that stays in memory always
    STARTUP: load = RAM, type = ro, define = yes;
    LOWCODE: load = RAM, type = ro, define = yes, optional = yes;
    INIT: load = RAM, type = ro, define = yes, optional = yes;
    CODE: load = RAM, type = ro, define = yes;
    RODATA: load = RAM, type = ro, define = yes;
    DATA: load = RAM, type = rw, define = yes;
    BSS: load = RAM, type = bss, define = yes;
    ZEROPAGE: load = ZP, type = zp;
    EXTZP: load = ZP, type = zp;
    APPZP: load = ZP, type = zp;
    # Intro module
    INTRO_CODE: load = INTRO, type = ro, define = yes;
    INTRO_RODATA: load = INTRO, type = ro, define = yes;
    INTRO_DATA: load = INTRO, type = rw, define = yes;
    INTRO_BSS: load = INTRO, type = bss, optional = yes;
    # The game
    GAME_CODE: load = GAME, type = ro, define = yes;
    GAME_RODATA: load = GAME, type = ro, define = yes;
    GAME_DATA: load = GAME, type = rw, define = yes;
    GAME_BSS: load = GAME, type = bss, optional = yes;
     # Tunes
    TUNE0_RODATA: load = TUNE, type = rw, define = yes;
FEATURES {
    CONDES: segment = RODATA,
	    type = constructor,
	    label = __CONSTRUCTOR_TABLE__,
	    count = __CONSTRUCTOR_COUNT__;
	    type = destructor,
	    label = __DESTRUCTOR_TABLE__,
	    count = __DESTRUCTOR_COUNT__;
    CONDES: segment = DATA,
	    type = interruptor,
	    label = __INTERRUPTOR_TABLE__,
	    count = __INTERRUPTOR_COUNT__;
Edited by Bochum_Boy, Fri Jan 11, 2019 4:07 AM.
#5 karri OFFLINE
karri
  • 2,502 posts
Posted Fri Jan 11, 2019 5:05 AM
Yep. That is the problem.
You have one screen buffer for display.
One screen buffer for drawing.
You lack one screen buffer for collisions.
Add:
__MEMORY_SCREENCOLLISION__: value = __MEMORY_SCREEN0__ - __SCREEN_SIZE__, type = export;
Then change:
__MEMORY_STACK__: value = __MEMORY_SCREENCOLLISION__ - __STACKSIZE__, type = export;
#6 Bochum_Boy OFFLINE
Bochum_Boy
    Star Raider
  • 50 posts
Posted Fri Jan 11, 2019 5:38 AM
That was it! Great! Thanks a lot!
