Oh god this lynx.
Billythegrape
Got a nice lynx 1 with 10 games and a sewage brown official carrying case for xmas. Worked pretty well except for the left side of the screen had a crapload of white pixels.
Decided to recap it as I had done to my game gear quite successfully. It went well, but i noticed someone had done it once before, so no change in anything except piece of mind.
Got a new job and as a random gift my pops sent me a mcwill mod. I went through the mod, removing the necessary components, then got to the testing 5v part. Meter between vcc and ground gave me 4.45v, which was well below the 5.45v cutoff listed by mcwill so I continued the mod.
When I turned it on, I got a white screen with no sound. Ok, no problem, I saw on here that if I connected just the vcc and ground to the screen I should see static. I did this, just got a white screen.
Contacted mcwill, he told me to remove the screen and try it on 5v power source. I don't have one. I removed it and bought the voltage regulator tune up kit or whatever from console5. Installed that, the screen won't turn on at all.
So i disconnected the screen and started checking voltages. 2.38v vcc to ground and the mosfet is hot as hell. I have replaced the 2 transistors, the mosfet, the power jack, and zener diode with this kit. What. The. Fuck. Did. I. Do. Wrong.
Not sure about that. I've never looked into the Lynx 1 and I had been told that the McWill mod was more difficult on the lynx 1. I can see why as the pin pitch to attach to on the LCD lines is much much smaller. More like working on the GG it would seem.
Soldered the new voltage regulator onto the mcwill. Nothing. In fact, the lynx won't function with the screen connected. Took vcc off mcwill, chips challenge music blasts out of the speaker. Touch the vcc lead to the mcwill, the music gets quiet, then goes drrrrrrrr like a cd skipping. Disconnect, turn lynx on, music is back
Sounds like perhaps a fault now on the McWill PCB - if the regulator had died on it, that's not a good sign. I would ask McWill if you can send the mod back for him to check out - but you may have to pay for the repair if it needs a new chip. There's also a chance you have a wire connected incorrectly somewhere perhaps? Double check your wiring before sending the screen back to McWill I think.
As GadgetUK said double check your connections.
I cannot recall if the mod works with both the Lynx 1 and 2, if it does then you should have instructions for both, make sure you are following the correct instruction for your Lynx as some of the component references are different, i.e. C10 on a Lynx 1 is not necessarily in the same circuit and doing the same thing as C10 in a Lynx 2.
