dpisacane Posted February 1, 2019 Share Posted February 1, 2019 Not terrific, but it's a score, I guess. [emoji39] 25,000 Sent from my Pixel 2 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted February 1, 2019 Share Posted February 1, 2019 (edited) You guys are hitting some crazy scores. I should probably read the manual to see how scoring works My first attempt was 8000. Edited February 1, 2019 by JasonlikesINTV 1 Quote Link to comment Share on other sites More sharing options...
scalpel Posted February 1, 2019 Author Share Posted February 1, 2019 Tron Deadly Discs - 200 joe's tron - 200.png Never played this before...not sure of the controls in emulation. 200 ? I think it's better to use the Intellivision system Quote Link to comment Share on other sites More sharing options...
m-crew Posted February 1, 2019 Share Posted February 1, 2019 1,030,500 2 Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 1, 2019 Share Posted February 1, 2019 Always better to use the Intellivision Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 1, 2019 Share Posted February 1, 2019 (edited) My buttons are not working for me with Tron Deadly Discs. Using Nostalgia. Buttons work fine with other games like Centipede, but not Tron. Might have to play later on the Intellivision...The intellivision controller has 15 buttons. Deadly Discs uses nine of them. You guys are hitting some crazy scores. I should probably read the manual to see how scoring works My first attempt was 8000.For high scores, learn how to take out the recognisers. Edited February 1, 2019 by mr_me Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 1, 2019 Share Posted February 1, 2019 For high scores, learn how to take out the recognisers. And you get more time to take out the recogniser if you have more doors jammed open before he enters play. 2 Quote Link to comment Share on other sites More sharing options...
dpisacane Posted February 1, 2019 Share Posted February 1, 2019 The intellivision controller has 15 buttons. Deadly Discs uses nine of them. For high scores, learn how to take out the recognisers. Easier said than done. I've read the manual and understand that I have to attack its eye when it turns white. The trouble is, I have never once actually been able to beat a recognizer. [emoji3525] Sent from my Pixel 2 using Tapatalk Quote Link to comment Share on other sites More sharing options...
m-crew Posted February 1, 2019 Share Posted February 1, 2019 Easier said than done. I've read the manual and understand that I have to attack its eye when it turns white. The trouble is, I have never once actually been able to beat a recognizer. [emoji3525] Sent from my Pixel 2 using Tapatalk Its all about lining up to the right spot as its coming out. It always stops at the same spot. So mark a spot in the grid and use that to line up. Depends on which side it comes out. Youll be on the left or right. Quote Link to comment Share on other sites More sharing options...
wolfy62 Posted February 1, 2019 Share Posted February 1, 2019 Easier said than done. I've read the manual and understand that I have to attack its eye when it turns white. The trouble is, I have never once actually been able to beat a recognizer. [emoji3525] Sent from my Pixel 2 using Tapatalk The best way to hit a recognizer is from a diagonal angle. You can hit it from straight above it,but that is harder and you have less time to run away if you miss. Also,as Bamse said the more doors you have open the more shots you get as the Recognizer closes them 1 at a time. Have fun! Quote Link to comment Share on other sites More sharing options...
dpisacane Posted February 1, 2019 Share Posted February 1, 2019 The best way to hit a recognizer is from a diagonal angle. You can hit it from straight above it,but that is harder and you have less time to run away if you miss. Also,as Bamse said the more doors you have open the more shots you get as the Recognizer closes them 1 at a time. Have fun! Okay, but I do have one additional question. Can I hit any part of that bulge on the top of the recognizer, or do I have to actually hit the white eye itself? Sent from my Pixel 2 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 1, 2019 Share Posted February 1, 2019 Okay, but I do have one additional question. Can I hit any part of that bulge on the top of the recognizer, or do I have to actually hit the white eye itself? Sent from my Pixel 2 using Tapatalk I thought you had to hit the eye directly when it's white. That's what I've been doing anyway. 2 Quote Link to comment Share on other sites More sharing options...
m-crew Posted February 1, 2019 Share Posted February 1, 2019 I thought you had to hit the eye directly when it's white. That's what I've been doing anyway.Yup when its white. Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 1, 2019 Share Posted February 1, 2019 (edited) "The ONLY way to knock out the Recognizer and win the bonus, is to score a direct hit on his eye with the disc of TRON. THE EYE IS WHITE. You must hit straight on, from the top or from the side. No other hit will work." You'd think you have to go through the small gaps on the side but a hit on top of the bulge when the eye is white works. Edited February 1, 2019 by mr_me 1 Quote Link to comment Share on other sites More sharing options...
S.BAZ Posted February 1, 2019 Share Posted February 1, 2019 4,550 This game is a pain in the arse with a keyboard. Still working on getting my controller to work like Robotron. 1 Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 1, 2019 Share Posted February 1, 2019 If you're using nostalgia, you can use something like www.joytokey.net to workaround nostalgia's controller mapping limitations. Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 2, 2019 Share Posted February 2, 2019 (edited) 1,030,500I was happy with my new score until I saw yours Wow, what a great score. Mine pales into insignificance next to it. Nicely done sir 655450 Edited February 2, 2019 by Bamse 2 Quote Link to comment Share on other sites More sharing options...
m-crew Posted February 2, 2019 Share Posted February 2, 2019 I was happy with my new score until I saw yours Wow, what a great score. Mine pales into insignificance next to it. Nicely done sir What a great improvement!!! Thank You !!! But the way you are improving no score is safe. I was just shy of my high score. Gets really tough with those orange zapper dudes. I have yet to kill one ever. ? 1 Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 2, 2019 Share Posted February 2, 2019 What a great improvement!!! Thank You !!! But the way you are improving no score is safe. I was just shy of my high score. Gets really tough with those orange zapper dudes. I have yet to kill one ever. My dad used to get to the Orange soldiers when I was a kid. I've never even gotten to that point much less killed one 1 Quote Link to comment Share on other sites More sharing options...
m-crew Posted February 2, 2019 Share Posted February 2, 2019 My dad used to get to the Orange soldiers when I was a kid. I've never even gotten to that point much less killed one Ive shot them at least 3 times and no death. Not sure how many times you need to hit them to kill. I have a feeling you will meet the orange zapper soldiers soon. ?? 1 Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 2, 2019 Share Posted February 2, 2019 I'll see if I get the time for another go Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted February 4, 2019 Share Posted February 4, 2019 Man this game is hard, but reading the manual is helping. I didn't know you could block...or recall a thrown disc early...or walk through doors...or that what the Recognizer was doing was repairing doors Anyway, slight improvement as I learn how to play. Still haven't killed a Recognizer yet: 2 Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 4, 2019 Share Posted February 4, 2019 I don't think I've ever blocked a disc in a game. Does anyone else do that? Quote Link to comment Share on other sites More sharing options...
m-crew Posted February 4, 2019 Share Posted February 4, 2019 I don't think I've ever blocked a disc in a game. Does anyone else do that? I do when the white disc come out.. Tip-when you break those the solder who had it gets a regular disc back... 2 Quote Link to comment Share on other sites More sharing options...
Bamse Posted February 4, 2019 Share Posted February 4, 2019 I do when the white disc come out.. Tip-when you break those the solder who had it gets a regular disc back... Nice. I'll give it a try 1 Quote Link to comment Share on other sites More sharing options...
