TI99 with WIN95
emulator
4 replies to this topic
#1 fabrizio OFFLINE
fabrizio
    Space Invader
  • 25 posts
Posted Tue Feb 5, 2019 4:15 AM
CIAO, i have win 95 installed on an old portable TI, which emulator do you recommend?
#2 blackbox OFFLINE
blackbox
    Chopper Commander
  • 188 posts
Posted Tue Feb 5, 2019 4:49 AM
Hi there.
We are running on W98 and find that the DOS PC99 runs very well. (But the PC99 debugger crashes in W98).
The DOS PC99 is supplied with the latest PC99w.
The modern MAME/MESS will not work due to relying on specific modern direct X but an older MESS may work well- but you will need an older TI set of files for it, as MAME has been redesigned several times and appears to have little backward compatability.
If you can find a dos version of Mess Vn 0.97 that seems to work but requires the TI files, I can supply these.
regards s
Edited by blackbox, Tue Feb 5, 2019 5:05 AM.
#3 HOME AUTOMATION OFFLINE
HOME AUTOMATION
    Moonsweeper
  • 314 posts
Posted Tue Feb 5, 2019 5:14 AM
V9T9 Has Parallel Port Support!
Runs well.
          H.A.
#4 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Tue Feb 5, 2019 5:52 AM
Concerning MAME, I'd say a minimum requirement is a Core generation CPU (Core2 and Core i), i.e. a post-2006 PC/laptop.
#5 blackbox OFFLINE
blackbox
    Chopper Commander
  • 188 posts
Posted Tue Feb 5, 2019 5:55 AM
-that is, the current Mame. No problem with the older versions.
Also tagged with one or more of these keywords: emulator
