Sophia DVI compatible monitors
sophia dvi monitor compatible
58 replies to this topic
#51 Ute OFFLINE
Ute
    Space Invader
  • 30 posts
Posted Wed Feb 13, 2019 4:26 PM
2ms is nothing. You wouldn't even notice 20ms lag, unless you are 15 years old ;)
Read this:
http://atariage.com/...-5#entry4052904
Sophia Rev.C itself does not introduce any extra processing delay.
When you use it with a PC Monitor, you will have very little lag (for example 5ms with Acer S200HLBbd, which is neglectable).
The most of TVs have a lag in a range of 100ms - 200ms in a normal mode, so you really have to remember to switch a TV to the game mode (to disable DSP processing) and you will end up with ~20ms lag.
Here is an overview showing example TVs lags:
https://translate.go...t-lag-fernseher
Anyway, your ATARI with SOPHIA Rev.C can still be connected to a CRT (over Composite Video), so you don't miss anything.
In my opinion Sophia is the most efficient way to enjoy your Atari in a living room ;-)
I agree that the Sophia is a nice option to have moving forward as CRT's are becoming harder to find and more expensive.
And I also agree 2ms is not a huge lag time.  I was sort of mixing two thoughts together above and I mistakenly said refresh rate when I meant response time(the rate at which a pixel can change color).
A 2ms response time however is very slow. The response time of a CRT's pixels is over 1000 times faster than an LCD. The only thing that comes close to a CRT's response time is an OLED/QLED at 10us, and right now those are quite expensive and that's still over ten times slower. And funnily enough they get screen burn in just like a CRT.
But anyways, I'm just saying when combing lag time with response response time, I get why people like to hold on to CRT's. ;)
#52 mytek ONLINE
mytek
  • 3,217 posts
Posted Wed Feb 13, 2019 5:51 PM
Yes CRTs can be extremely fast, with minimal lag time, but 2 ms is 100 times faster than the average younger person's reaction time. And if you are over 24 years old it only gets worse.  So I would conclude that a 2 ms lag would not be noticeable, and certainly not affect your game play. Not unless you are an AI on a super computer  :) .
#53 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,246 posts
Posted Wed Feb 13, 2019 8:23 PM
lag is additive and as you get older, and 200ms plus how slow you are as you age = failed mission on many games. I know for a fact I can play tempest 2k on the Jaguar like a mad man on CRT, my family tried watching and could keep up with me with all the melto vision explosions and ridiculous numbers of bad guys I creamed level after level after level... I would play all night... When we got the Visio and Samsung flat panels, I was the one getting creamed no matter what mode I set them in (and they were not cheap... I then tried and older Olevia set with almost the same result... I used and LG with all the bells and whistles turned off for raw power and lowest lag, it didn't look great but I fared better. I thought I couldn't play at those levels and my abilities had failed me... Grabbed an old sc1224 hooked it up and wouldn't you know played half the night! woot
#54 mytek ONLINE
mytek
  • 3,217 posts
Posted Wed Feb 13, 2019 9:10 PM
I agree that if the LCD lag was 200 ms that would be noticeable since adding in your own 200+ ms of delayed reaction time would make it pretty close to 1/2 a second. But if the LCD is only experiencing a 2 ms delay, that would be invisible to even a 15 year old gamer.
For myself, I would say my personal lag time is probably already close to a 1/2 second without any help from a slow LCD  :grin: .
#55 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 661 posts
Posted Thu Feb 14, 2019 2:30 AM
Now I see the point.
The electronics for analog video processing (if supported at all) is definitely not in focus of modern TVs manufacturers. The picture quality and lags are usually so bad that even the game mode won't help much.
I agree that connecting the ATARI via composite video to a modern TV makes little sense.
However things really change if your computer is equipped with SOPHIA and provides a digital video signal :)
  • Ute likes this
#56 Sleepy OFFLINE
Sleepy
    Moonsweeper
  • 308 posts
Posted Thu Feb 14, 2019 2:48 AM
List updated.
Working:
Model / Resolution / NTSC/PAL:
Acer S200HLBbd 1600:900 NTSC / ?
ASUS VE278Q  1280x1024 NTSC / ?                       (Using a DVI to HDMI video only cable, couldn't find a
spare DVI/DVI cable, will update this soon as I do)
BENQ BL3200PT 1280x1024 NTSC / ?
Dell 1905FP 1280x1024 NTSC only
Dell U2412M: NTSC only
Dell U2913WM: NTSC/PAL
Dell U3011 1280x960 & 1280x1024 ?/PAL
Dell U3014: NTSC & PAL
HANNS-G, Modell HC194D 1280x1024 ? / PAL
HP EliteDisplay E241i 1536x960 ? / PAL
HP Compag LA2405x 1536x960 ? / PAL
HP LP2065 1536x960 ? / PAL
HP LP2465 1280x960 & 1280x1024 ? / PAL
LG 24MP47HQ: NTSC only
LG 42LW650S (HD TV) 1600:900 NTSC only
LG 55UH8509 (4K TV) 1600:900 NTSC / ?
LG DM2352D-PZ (HD Monitor) 1600:900 NTSC & PAL OK
LG E2242T: NTSC only
LG E2441V: NTSC only
LG IPS LED 24EB23 1536x960 ? / PAL
LG W2600H: NTSC and PAL
NEC Multisync LCD1970NX 1280x1024 NTSC / ?
NEC Multisync EA190M (Rev 1A) 1280x1024 NTSC / ?
HP LP2465 NTSC & PAL
Samsung SyncMaster 2443BW 1536x960 ? / PAL
Not working:
Acer S243HL monitor
Dell U2713HM
DVDO iScan VP50 scaler (!)
JVC DILA X7500 projector
HDFury Vertex
HP Compaq LA2205wg
Lumagen Vision HDP scaler (!)
Pioneer Kuro KRP-600M (Elite 141 series) television
Edited by Sleepy, Thu Feb 14, 2019 2:49 AM.
#57 Panther OFFLINE
Panther
    Moonsweeper
  • 294 posts
Posted Thu Feb 14, 2019 9:26 PM
Also works well with the NEC AccuSync AS193i.
With NTSC.
#58 Ute OFFLINE
Ute
    Space Invader
  • 30 posts
Posted Fri Feb 15, 2019 1:38 PM
I think I've confused people about what I'm saying. Hopefully this screen shot clears it up. CRT on the left, LCD on the right. You can see the lag, guy on the left has completed his somersault. But more importantly the response time and the point I was trying to make in the other posts, a ghost/fuzzy/blurry image, because the pixels can't update fast enough. ;-)
YouTube video where screen shot was taken: https://www.youtube....h?v=Y1JUbCoLKxs
#59 _The Doctor__ OFFLINE
_The Doctor__
  • 6,246 posts
Posted Fri Feb 15, 2019 2:13 PM
exactly, and the still frame fuzz etc. is what they call motion blurring in an effort to cover for and to fool your brain into thinking the motion is smooth...
thank you for the side by side actual on this, as folks seeing may lead to understanding and believing the truth of the matter....
Edited by _The Doctor__, Fri Feb 15, 2019 2:16 PM.
  • Ute likes this
Also tagged with one or more of these keywords: sophia, dvi, monitor, compatible
