Perihelion tutorial No8
4 replies to this topic
#1 Redreamer82 OFFLINE
Redreamer82
    Combat Commando
  • 3 posts
Posted Sun Feb 10, 2019 2:32 PM
Hi!
I'm new to Atari assembly.  I've followed Perihelions tutorials on top of reading Abacus Atari Internals and machine language books. Anyway, in tutorial no8 he explains that the video memory must be on a 256 byte even address, but I dont understand the syntax given in the code.
https://nguillaumin....utorial-08.html
Why does the last three rows make sure that we are on a 256byte even address? Yea, ds.b reserves 256 bytes of data but it does not align me to an even address? I hope I didnt miss read anything in the tutorial and everything was there right in front of me...
move.l  #screen1, d0 ; put screen1 address in d0
clr.b  d0 ; put on 256 byte boundary
clr.b  $ffff820d ; clear STe extra bit
lsr.l  #8, d0
move.b  d0, $ffff8203 ; put in mid screen address byte
lsr.w  #8, d0
move.b  d0, $ffff8201 ; put in high screen address byte
section bss
ds.b  256 ; 256 byte clear buffer
screen ds.b  32000 ; the screen
#2 ggn OFFLINE
ggn
  • 1,453 posts
Posted Mon Feb 11, 2019 1:00 AM
Firstly, that "clr.b d0" does the magic of aligning the address to 256 byte boundary. Since 256 is $100 in hex, it means that if we just make sure that the lower 8 bits of our address are 0 then we're done.
So, what's the extra "ds.b 256"? Well, consider this:
section bss
label1: ds.w 4
label2: ds.l 1
screen: ds.b 32000
If we take "screen"'s address and clear the lower 8 bits then the address will move up in memory (as an example: if "screen"'s address is $60024, it will become $60000). So it's certain that if we use the modified address, label1 and label2 will get clobbered by screen data. (the exception to this is "screen" already being an address with the 8 lower bits 0)
So, to counter that we need to add some dummy bytes before "screen". That's what the "ds.b 256" does. If we knew the address our program will be loaded we could simply reserve as many bytes as needed. But we don't know beforehand the address our program will be loaded so we just put in the maximum amount of bytes we can move back: 256. (well, technically it should be 254 but what's 2 bytes between friends).
Hope this makes sense now.
#3 ParanoidLittleMan ONLINE
ParanoidLittleMan
  • 1,585 posts
Posted Mon Feb 11, 2019 3:43 AM
Code example is flawed.
It should be:
  move.l d0,screenBase
  lsr.l  #8, d0
  lsr.w  #8, d0
*  further code ....
screenBase  dc.l 0
   section bss
screen1 ds.b  32000 ; the screen - not really, it will be lower
MC68000 code is always on even address, so it is assured here. Only if you put some data of even length inside code it will be ruined. Therefore is ASM control statement even .
Like:
   moveq #1,d1
   dc.b  "Even",0  * this is actually odd len since 0 terminator
   even
   bsr  huh
Without that even statement you would get error by assembling.
#4 Redreamer82 OFFLINE
Redreamer82
    Combat Commando
  • 3 posts
Posted Mon Feb 11, 2019 10:44 AM
@ggn
Yea, this really helped me to understand. Ive done some C64 assembly but never done it like this.
@PLM
What you're saying is that I should put an "Even" after a dc.b/ds.b to  be sure that I stay on the "even side" in memory?
#5 ParanoidLittleMan ONLINE
ParanoidLittleMan
  • 1,585 posts
Posted Mon Feb 11, 2019 11:44 AM
@PLM
Sure, it's easier than counting bytes of text string . In case of ds.b  you see is it even or odd ...
C64 - 6502 or Z80 assembly differs pretty much from 68000 ASM. I seen lot of Atari code with traces of 8-bit programming habits.
