shear_xear Posted February 11, 2019 Share Posted February 11, 2019 Hi everyone! I have an Atari XEGS, and the light gun that came with it seems to have some problems. Im trying to use it with Crossbow on the 7800, but it only works when a few inches from the screen. The screen will flash when the trigger is pulled, but the crosshair only shows when next to the screen. Any ideas what might be wrong? Thanks! Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted February 11, 2019 Share Posted February 11, 2019 it will not work with an LCD. Only a good ol CRT monitor or TV. Oh, but you mentioned it worked close to the screen, so that implies you are using a CRT? Quote Link to comment Share on other sites More sharing options...
shear_xear Posted February 12, 2019 Author Share Posted February 12, 2019 Yeah, Im using a CRT. Quote Link to comment Share on other sites More sharing options...
power Posted February 12, 2019 Share Posted February 12, 2019 (edited) is it actually compatible with the 7800? Does it function normally on your XEGS? Edited February 12, 2019 by power Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted February 12, 2019 Share Posted February 12, 2019 is it actually compatible with the 7800? Does it function normally on your XEGS? Cue for joke! Yes, the unloved XG-1 is compatible with all of Atari’s consoles. And no, it doesn’t work well on any of them. Even if you get the hardware issue sorted out — and it sounds like there’s a problem with the gun — they tend to be wildly inaccurate. I was able to get pretty consistent scores on XE Barnyard Blaster by holding mine about a foot away from my CRT. Just get a modded Sega lightgun. Quote Link to comment Share on other sites More sharing options...
power Posted February 12, 2019 Share Posted February 12, 2019 (edited) Cue for joke! Yes, the unloved XG-1 is compatible with all of Atari’s consoles. And no, it doesn’t work well on any of them. Even if you get the hardware issue sorted out — and it sounds like there’s a problem with the gun — they tend to be wildly inaccurate. I was able to get pretty consistent scores on XE Barnyard Blaster by holding mine about a foot away from my CRT. Just get a modded Sega lightgun. fair enough, i have an XEGS and gun, it wasn't that great but did work was not 100% aligned but worked well enough. not as good as my Saturn gun but functional it wasn't "wildly inaccurate" was just out of alignment so you'd shoot to the right a bit was like that from new. But hey, they were cheap guns and at the time a pretty cool addition especially as my bundle came with two different games for it. Maybe the OP's connection isn't great due to age, that might explain it - would be very hard to clean though. Maybe spray some contact cleaner into the holes or something. Edited February 12, 2019 by power Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted February 12, 2019 Share Posted February 12, 2019 Also depends on the game. Crossbow XE isn’t too bad with the XG-1, but Barnyard Blaster...yeesh. They just should have called that one “Don’t Shoot Gramps!” Quote Link to comment Share on other sites More sharing options...
power Posted February 12, 2019 Share Posted February 12, 2019 Also depends on the game. Crossbow XE isn’t too bad with the XG-1, but Barnyard Blaster...yeesh. They just should have called that one “Don’t Shoot Gramps!” only played Crossbow and the bug one. 1 Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted February 12, 2019 Share Posted February 12, 2019 Well, Crime Buster and Crossbow are by far the best XE light games, so you’ve played half of the XG-1’s greatest hits library of two. 1 Quote Link to comment Share on other sites More sharing options...
Fred_M Posted February 12, 2019 Share Posted February 12, 2019 Don't forget Operation Blood for the lightgun It is great! Quote Link to comment Share on other sites More sharing options...
pjbramley Posted February 12, 2019 Share Posted February 12, 2019 Is it possible to convert the light guns to work on modern TV's/Monitors? Quote Link to comment Share on other sites More sharing options...
Fred_M Posted February 12, 2019 Share Posted February 12, 2019 Not easily.... More info in this topic: http://atariage.com/forums/topic/287918-light-gun-games-on-a-modern-tv-nes-fans-figured-it-out/ Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted February 12, 2019 Share Posted February 12, 2019 Don't forget Operation Blood for the lightgun It is great! Ooh...and I did. You’re right — it is a great game. Quote Link to comment Share on other sites More sharing options...
shear_xear Posted February 12, 2019 Author Share Posted February 12, 2019 Ok. Im only mildly interested in the light gun games, so I might just accept it does work and move on. Thanks! Quote Link to comment Share on other sites More sharing options...
+davidcalgary29 Posted February 12, 2019 Share Posted February 12, 2019 And you can play Crossbow on the 7800 with a joystick, unless I'm mistaken. Quote Link to comment Share on other sites More sharing options...
Swami Posted February 12, 2019 Share Posted February 12, 2019 Hi everyone! I have an Atari XEGS, and the light gun that came with it seems to have some problems. Im trying to use it with Crossbow on the 7800, but it only works when a few inches from the screen. The screen will flash when the trigger is pulled, but the crosshair only shows when next to the screen. Any ideas what might be wrong? Thanks! It could also be that you need to turn up your brightness or contrast on your TV, or you have too much ambient light reflecting on the screen. Quote Link to comment Share on other sites More sharing options...
manterola Posted February 12, 2019 Share Posted February 12, 2019 (edited) It could also be that you need to turn up your brightness or contrast on your TV, or you have too much ambient light reflecting on the screen. Or the light gun "window" is dirty. I also read here in AtariAge that painting the gun barrel mate black inside helps with the precision by eliminating reflections. Reflections supposedly make the gun and the Atari to detect the electron beam too early and offset the pointing position of the gun. Edited February 12, 2019 by manterola Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 12, 2019 Share Posted February 12, 2019 lol a remember a heavy smoker who's lens was full of tar glued dust, it had to be soaked and carefully cleaned to make it work again... Quote Link to comment Share on other sites More sharing options...
shear_xear Posted February 12, 2019 Author Share Posted February 12, 2019 Ok. I will darken the inside of the barrel and clean that lense. Thanks for the advice! Quote Link to comment Share on other sites More sharing options...
