israelg Posted February 28, 2019 Share Posted February 28, 2019 I got a new lg 4K TV and connected my android tablet (S4) to this TV using HDMI, The TV is stuck on 30hz and emulators run very slow, Disable the vSync causes tearing effect, The problem is: the tablet is streaming in the native TV res. (4K), No problems when connecting to 1080P/720P TV. Can I force 1080P on 4K TV ? by the way CRT shaders look great on 4K TV... Any suggestions ??? Quote Link to comment Share on other sites More sharing options...
Albert Posted February 28, 2019 Share Posted February 28, 2019 I assume you are using an adapter to get HDMI output from your S4? If so, it's possible the adapter only supports 30hz and/or the older HDMI standard. It wasn't until HDMI 2.0 that you could get 60hz 4K video from HDMI. Also make sure you are using a "modern" HDMI cable that supports at least HDMI 2.0. ..Al Quote Link to comment Share on other sites More sharing options...
israelg Posted February 28, 2019 Author Share Posted February 28, 2019 I assume you are using an adapter to get HDMI output from your S4? If so, it's possible the adapter only supports 30hz and/or the older HDMI standard. It wasn't until HDMI 2.0 that you could get 60hz 4K video from HDMI. Also make sure you are using a "modern" HDMI cable that supports at least HDMI 2.0. ..Al I am using a cheap adapter from ebay, not the official Samsung... And the cable is old, but is this make a difference ? I thought all hdmi cables are the same... Quote Link to comment Share on other sites More sharing options...
mr_me Posted February 28, 2019 Share Posted February 28, 2019 Maybe that's the best the tablet can do at 4k. I'd see if there's settings in the tablet to set hdmi output to 1080p60. Quote Link to comment Share on other sites More sharing options...
Albert Posted February 28, 2019 Share Posted February 28, 2019 I doubt the HDMI cable will make much difference, especially over short distances. I'd bet that cheap HDMI adapter only supports 30Hz, though. Do you have a link to the adapter you bought on eBay? ..Al Quote Link to comment Share on other sites More sharing options...
israelg Posted February 28, 2019 Author Share Posted February 28, 2019 I doubt the HDMI cable will make much difference, especially over short distances. I'd bet that cheap HDMI adapter only supports 30Hz, though. Do you have a link to the adapter you bought on eBay? ..Al https://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=123427932340&view=all&tid=2034726953002 Quote Link to comment Share on other sites More sharing options...
israelg Posted February 28, 2019 Author Share Posted February 28, 2019 Maybe that's the best the tablet can do at 4k. I'd see if there's settings in the tablet to set hdmi output to 1080p60. No option in the tablet settings to switch resolution... Quote Link to comment Share on other sites More sharing options...
israelg Posted April 6, 2019 Author Share Posted April 6, 2019 Tab S4 connected to 1080P monitor using USB-C to VGA adapter, 60hz, BUT wrong aspect ratio, which is forced to 16:10 causing borders on left and right, Also connected wired to Anker speaker to prevent audio lags with Bluetooth... Quote Link to comment Share on other sites More sharing options...
