Kyle22 Posted April 20, 2019 Share Posted April 20, 2019 IIRC, you squeeze the sides, then pop it open. Quote Link to comment Share on other sites More sharing options...
+mytek Posted April 20, 2019 Share Posted April 20, 2019 IIRC, you squeeze the sides, then pop it open. Tried it, and it didn't work for me. Probably requires some practice to get it right. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted April 20, 2019 Author Share Posted April 20, 2019 Found it! How to open grey ribbed XE carts. 5 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted April 21, 2019 Share Posted April 21, 2019 I discovered that I must disable the hard drive for this to work. Also, it does not boot the 850 R:Handler. Quote Link to comment Share on other sites More sharing options...
Forrest Posted April 23, 2019 Share Posted April 23, 2019 (edited) I placed Atari size cartridge board in a yellow Deluxe Invaders case - fit fine. I chose this cartridge case because I could see daylight between the two case halves and knew it would be simple to disassemble after removing the 1 screw. I tried it today - works great. Edited April 23, 2019 by Forrest Quote Link to comment Share on other sites More sharing options...
Mathy Posted April 23, 2019 Share Posted April 23, 2019 Hello guys (m/f) AtariMax cartridge shells are even easier to separate. And Steve promised to send me the dimensions of his shells. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 24, 2019 Share Posted April 24, 2019 I placed Atari size cartridge board in a yellow Deluxe Invaders case - fit fine. I chose this cartridge case because I could see daylight between the two case halves and knew it would be simple to disassemble after removing the 1 screw. I tried it today - works great. Sacrilege! You did what with a Roklan Cart?!?!?!?!? 1 Quote Link to comment Share on other sites More sharing options...
Forrest Posted April 24, 2019 Share Posted April 24, 2019 (edited) The Deluxe Invaders cartridge is labeled and bagged. What did you do with your Bug Hunt cartridge? I have an M-Audio Midisport 1x1 USB Midi Interface. I wonder if Midi-Maze works under the Altirra emulator using the Midi Interface? I've already confirmed Midi-Maze does work in Solo mode under Altirra. Edited April 24, 2019 by Forrest 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 24, 2019 Share Posted April 24, 2019 (edited) lol bug hunt deserves to be used and abused, squash that bug! when it dies put something else in it's carcass as that is of no consequence! Edited April 24, 2019 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted April 24, 2019 Share Posted April 24, 2019 I squished all my bugs, using a Happy Face to do it . 6 Quote Link to comment Share on other sites More sharing options...
